Author Topic: Load of logs now need blades help  (Read 3399 times)
Offline LoneDuck
« on: October 23, 2017, 10:00:07 PM »
Nice load of Beatle killed pine but need a blade that will cut it. I would like to try the kasco but don't know how to contact cutting edge. When I pull him up in members I get an message saying that I do not have access. So any help would be appreciated. My current blades dive like crazy on the knots and hope kasco has a blade that will cut it.  Thanks
Offline btulloh
Re: Load of logs now need blades help
« Reply #1 on: October 23, 2017, 11:17:12 PM »
You can buy from kasko. Have to buy 15 though. But that's a good thing. 7 degree or 4 degree.  Seven degree is a good general purpose blade. If you put the type of mill in your profile it will help people give better input too.
HM126
Offline gmmills
« Reply #2 on: October 23, 2017, 11:18:31 PM »
    Send him a PM or call him at 304-878-3343.
Custom sawing full-time since 2000.
WM LT70D62 Remote with Accuset
Sawing since 1995
Offline btulloh
« Reply #3 on: October 23, 2017, 11:20:51 PM »
Sawing fast causes more diving. I push my mill and it helps to slow down for knots. Don't know how that works with power feed.
HM126
Offline JB Griffin
« Reply #4 on: October 23, 2017, 11:50:49 PM »
I believe that you will find that 4deg blades would be better than most in knotty pine.
2000 LT40hyd remote 33hp Kubota, 160 Prentice, Frick 2 saw gang edger, Wright W-37 ABG, Suffolk dual tooth setter, Cat claw single tooth setter,'96 F-250 7.3 PSD 4x4, CS-590 Echo, MF 20c, M681 Memo.
Over 2.5 million bdft sawn with a Baker Dominator and counting.
Offline LoneDuck
« Reply #5 on: October 24, 2017, 12:35:10 AM »
Thanks. I'm now able to pull them up in members. Thought I had my mill in but I must not but it's a 98 lt40 Hd. This is my second load a neighbor gave to me. Tried to cut some slabs but just to meany dips and didn't want to waste any more.
Offline Kbeitz
  • Never enough time...
    • My Hobbies
« Reply #6 on: October 24, 2017, 02:56:15 AM »
I use 4 deg.  kasco blades. This summer I cut a lot of pine. I was getting some dives at knots.
I had nothing to loose so I almost doubled my set. It made a world of difference. No more dives
until I got a sap buildup on the blades. A little diesel took care of that. I'm making a lot of saw
dust but I'm getting so much of a better cut. My set is around .030 +/- now for pine for a .045
blade. After messing with the set I'm getting my best cuts ever.
Love machine shop work
and Wood work shop work
And now a saw mill work
Online Jeff
  • Fearless Leader
  • I know that I do not know.
    • THEE Forestry Forum
« Reply #7 on: October 24, 2017, 04:59:29 AM »
You didn't have access to any member profiles because you didn't have any posts. You can't see member profiles until you have a level of participation.
Offline LoneDuck
« Reply #8 on: October 24, 2017, 07:44:37 AM »
Thanks Jeff but I have posted before but maybe too much time has past. Haven't had much time to stay up to date.
Online Jeff
  • Fearless Leader
« Reply #9 on: October 24, 2017, 08:00:38 AM »
You now have 4 total posts because of this topic.
Offline Chuck White
  • Sawing Mobile since 2005
« Reply #10 on: October 24, 2017, 08:10:01 AM »
I cut mostly W/Pine and Hemlock, and I use 10 blades set at .025-.030 with good results!
If a log is knotty, such as Spruce, I  s l o w  down my feed speed!
~Chuck~
I LOVE MY SAWMILL
Offline GAB
« Reply #11 on: October 24, 2017, 08:17:03 AM »
I changed my pressure gauge for one that is 0 to 5000 psi.
Running with 3200 psi has helped me to get straighter cuts.
Gerald
Offline alanh
« Reply #12 on: October 24, 2017, 08:28:24 AM »
I`m still kinda new at this but I`ve cut about 3500 bd ft of knotty pine with Woodmizer 4 degree blades with little to no diving. I`ll add that most of the logs had been down a while so the sap buildup was minimal. I use a little dawn or simple green in the water tank. It also could have something to do with I only have the 18hp(?) gas motor so I have to go pretty slow.
Offline LoneDuck
« Reply #13 on: October 24, 2017, 08:50:45 PM »
Great info guys. When I bought my mill, it came with 30 or 40 blades and I've no clue what they are. All I now is they are wood mizer and I've been having them sharpen them. In the future I would like to keep records and start to see what works best but not knowing I'm sawing blind.
Offline delvis
  • "I jus' 'bout 'magine"
« Reply #14 on: October 25, 2017, 08:33:28 AM »
4 degree blades work well in knots and dense hard wood.  I use the Turbo 7 for just about everything else.
If I never saw another board I will at least die happy having spent the last few years working with my dad!
Offline esteadle
    • Steadwood Forest Products
« Reply #15 on: October 25, 2017, 08:41:14 PM »
So let's summarize:
Kbeitz says widen the set for knotty pine. around .030 +/- for a .045 thickness blade. I agree!
Adding soap to the drip mix helps. Or use diesel or kero.
And letting more drip go thru to help keep the blade cleaner.
Tighter band tension should help on the knots.
And slower feed speed.
And 4 blades.
All of those should help.
Timber Harvester 30HT26 (setworks, hydraulic) Stihl 880 (36" bar).
Offline larrydown60
« Reply #16 on: October 25, 2017, 09:32:23 PM »
LoneDuck I am new to milling I have been cutting white pine and spruce I get really smooth cuts with the 10 degree and I can cut faster with the 7 degree with not as smooth cut I have a 20hp kohler command homemade mill
Offline Sixacresand
  • John and Nancy
« Reply #17 on: October 25, 2017, 10:17:52 PM »
A gauge from WM can help you determine what degree blade you have.
Offline redprospector
« Reply #18 on: October 26, 2017, 01:13:25 AM »
I saw more Pine than anything else, and a Pine without knots is pretty rare around here.
When a tooth removes wood (sawdust), the piece of wood expands. Pine will expand a lot more than hardwoods do, so the Pine will need more set. I set most of my blades at 25 thousands each side. The more pitch a log has, the more set you'll likely want. I just slow down on pitchy logs instead of trying to keep track of a bunch of different blades. I'm using Cook's Supersharps, I think 8 degrees.
If you don't have to slow down for the big knots, you may not be sawing fast enough between them.  :D
Offline Kbeitz
    • My Hobbies
« Reply #19 on: October 26, 2017, 08:17:42 AM »
From my experience spruce is so much harder to cut than pine.
I just cut some that had knots every 6". What a pain. Talk about slow...
Nice looking wood.
how much $ for a load of logs?
Started by bigred1951 on Forestry and Logging
Last post November 29, 2013, 01:08:30 PM
by bigred1951
where to get a load of logs
Started by JamieT on Sawmills and Milling
Last post April 22, 2014, 08:53:54 AM
by kczbest
How I load logs...
Started by spokeshave on Sawmills and Milling
Last post September 07, 2004, 12:27:54 AM
by TN_man
Load of Logs
Started by POSTON WIDEHEAD on Sawmills and Milling
Last post November 04, 2013, 09:29:40 AM
by dboyt
