Author Topic: Load of logs now need blades help  (Read 3398 times)
Offline thecfarm
Re: Load of logs now need blades help
« Reply #20 on: October 26, 2017, 04:43:39 PM »
I think I could count the spruce I have on 2 hands on my land. Than on one hand I could count how many would make logs.
I only cut spruce once. More electricity was being put in above me. A good size spruce log was going to rot beside the road. Me,being the hate to see logs go to waste,went and got it. I should've used it for firewood before I cut it. It went into the burn pile. No sense in me buying a blade to saw some spruce when I don't have many logs.
Offline terrifictimbersllc
    • Terrific Timbers LLC
« Reply #21 on: October 27, 2017, 06:28:10 AM »
Customer needed one more 8x8 at 4:30 pm last Saturday.
I look up and see him bringing a 25" spruce toward me, knots everywhere could have been the national Christmas tree.
Shook my head and pointed him back to the log pile. Found another pine instead.
DJ Hoover, Terrific Timbers LLC,  Mystic CT  2001 WM LT40SHDD (42HP Kubota, Accuset2, FAO's, Lubemizer, debarker), Peterson WPF 10-30 with chain slabber. Logrite fetching arch, WM BMS250 sharpener/BMT250 setter.  2001 F350 7.3L PSD 6 spd manual ZF 4x4 Crew Cab Long Bed
Offline Kbeitz
  • Never enough time...
    • My Hobbies
« Reply #22 on: October 27, 2017, 06:46:08 AM »
I don't think spruce is good for nothing more than paneling.
Around here we don't have any clear spruce. It's all knots.
Love machine shop work
and Wood work shop work
And now a saw mill work
Offline Chuck White
  • Sawing Mobile since 2005
« Reply #23 on: October 27, 2017, 08:37:40 AM »
Spruce makes good framing material & beams, the trick is to cut it straight!   ;)
~Chuck~
I LOVE MY SAWMILL
Offline Kbeitz
    • My Hobbies
« Reply #24 on: October 27, 2017, 12:00:16 PM »
I would not use it in any beams for my buildings. With all the knots it can't
be strong...
Offline crowhill
« Reply #25 on: October 29, 2017, 11:26:46 AM »
All the knots intertwined is what makes it strong🤡.
TimberKing B-20, Kubota M-4900 w/FEL with tooth bar, hyd thumb and forks, Farmi winch, 4 chain saws.
Offline smoker62
« Reply #26 on: October 29, 2017, 11:30:23 AM »
Anyone try the Ripper 37 blades in Pine ? I have all tall straight Red Pine on my property and just purchased a sawmill. Have yet to try it out but I bought some Rippers from Jerrys Resharp , hell of a nice guy .
Offline crowhill
« Reply #27 on: October 29, 2017, 11:37:46 AM »
I just tried some. My saw sharp guy made them up for my B20 to saw EWP and I’m very happy.
Offline crowhill
« Reply #28 on: October 29, 2017, 11:42:32 AM »
be strong...
My grandfather(s) used to make the runners for their log scoots out of spruce, “shoe” them with iron wood, yellow birch or rock maple and the bunks were made of oak. They were pretty rugged sleds.
Offline Chuck White
« Reply #29 on: October 29, 2017, 08:38:39 PM »
be strong...
To each their own, but the knots in Spruce are usually quite small and wouldn't affect strength very much!
~Chuck~
I LOVE MY SAWMILL
Offline crowhill
« Reply #30 on: October 30, 2017, 01:25:19 PM »
There are many old barns and sheds standing in New England with a lot of spruce in the framing. I think the biggest issue of using spruce is the tendency of it to rot quickly from moisture. Even when used in log scoots for runners one didn’t want to leave it out in the weather unused for long.
Offline Kbeitz
    • My Hobbies
« Reply #31 on: October 30, 2017, 01:37:53 PM »
I had to make some stickers today... All with knots just fell apart.
No. 1 Common. Highest quality of common lumber. No. 1 Common lumber will have a few small, tight knots.
No. 2 Common. Has larger knots than found in No. 1 Common. No. 2 is often used for paneling and shelving and is suitable for general woodworking projects.
No. 3 Common. Has more and bigger knots than No. 2. The wood is typically damaged and blemished. Well-suited for fences, boxes, and crates.
Select Structural. Pretty much clear of knots. The knots that do exist are small and tight. Strongest of the four grades.
No. 1. Small, tight knots up to 1-1/2” allowed. Loose knots can only be 1” wide and can only appear once every 3 feet.
No. 2. Well-spaced knots of any quality up to 2” wide. Can have knotholes that are 1-1/4” wide every 2 feet.
No. 3. Knots of any quality can be up to 2-1/2” wide. Knotholes allowed every 1-3/4” foot.
Offline hturner12
« Reply #32 on: September 10, 2018, 10:41:30 PM »
Yes he is. I was by there last week. He gave me a  couple  to try. He also gave me the name of a shop very close to my house. I like the fact I do not have to  buy 15 at a time and he makes them on  site
Hugh
Ezbordwalk Jr
Offline Bruno of NH
« Reply #33 on: September 11, 2018, 12:36:57 AM »
I use Jerry for bands and like the Ripper 37's in 7° he also has Kasco's in 4° if you ever need the 4°
The Ripper 37's perform great on my mill and can't beat the price.
thomas 8013 mill ,Mahindra 3540 cab tractor loader  Dump trailer  and lot of contracting tools
Offline logs2lumber
  • 2005 WM Lt40 Super Hyd 51 cat
« Reply #34 on: September 11, 2018, 07:41:11 AM »
Great info guys. When I bought my mill, it came with 30 or 40 blades and I've no clue what they are. All I now is they are wood mizer and I've been having them sharpen them. In the future I would like to keep records and start to see what works best but not knowing I'm sawing blind.
A gauge from WM can help you determine what degree blade you have.
Do Happen to know the Part number for the Degree Gauge?
Offline ladylake
« Reply #35 on: September 11, 2018, 07:42:43 AM »
be strong...
Plus the knots  are spaced out real good, not in a group like red pine.  Steve
Offline ladylake
« Reply #36 on: September 11, 2018, 07:53:01 AM »
  After Simonds ruined their 3/4 pitch Red Streak blades I've tried Lennox 7/8   Kasko 3/4  Kasco 7/8  Dakin Flather 7/8 rippir 37  Dakin Flathers 3/4 Ripper s.  I think my favorite is going to be the Dakin Flather ripper s 3/4 sharpened to 4 degrees, they cut nice and straight pushing hard .  You will have no trouble cutting pine straight plus they cut spruce real nice under 12" and on a 20" cut just a hair of  a wave that will plane out on the first pass.  Steve
Online barbender
« Reply #37 on: September 11, 2018, 08:29:55 AM »
How did Simonds ruin their 3/4 blades, Steve?
Offline ladylake
« Reply #38 on: September 11, 2018, 10:43:29 AM »
 Their using different material and made the gullet deeper, I didn't even try them but a mill south of did and he said they are junk, wont cut straight . Both of us had been running 3/4 pitch Simomds Red Streak for years. He is the reason I tried 3/4 Simonds and found them to be the straightest cutting blades until now. I was just out cutting large WO with the 3/4 Dakin Flathers and they're working good.  Steve
A Different Load of Logs
Started by pappy19 on Forestry and Logging
Last post September 30, 2013, 07:48:37 PM
by Peter Drouin
Best way to load BIG logs?
Started by Verticaltrx on Sawmills and Milling
Last post April 22, 2015, 08:19:00 AM
by gww
how much $ for a load of logs?
Started by bigred1951 on Forestry and Logging
Last post November 29, 2013, 01:08:30 PM
by bigred1951
where to get a load of logs
Started by JamieT on Sawmills and Milling
Last post April 22, 2014, 08:53:54 AM
by kczbest
