Arborwear
Author Topic: Opinion on backhoe  (Read 3196 times)
Offline mike_belben
  • Pulp Friction
Re: Opinion on backhoe
« Reply #40 on: November 06, 2017, 11:02:24 AM »
 :D
Revelation 3:20
Offline ohiowoodchuck
« Reply #41 on: November 06, 2017, 08:15:15 PM »
I got a couple case 580e's to go look at. Anybody got any pointers on them.
Education is the best defense against the media.
Offline BargeMonkey
« Reply #42 on: November 06, 2017, 09:15:35 PM »
Case isn't a bad machine, biggest killer of a TLB is abuse and rot. If it's seen manure or salt just get back in your truck.
Offline mike_belben
  • Pulp Friction
« Reply #43 on: November 06, 2017, 09:59:20 PM »
Are there any that havent seen manure or salt?
Revelation 3:20
Offline BargeMonkey
« Reply #44 on: November 06, 2017, 10:05:18 PM »
A little bit is one thing, I've seen some 4-5yr old machines that are just rotted to pieces. We bought a low hour 644K deere loader that had loaded salt for 1yr, never again, brake issues, literally tear the whole machine apart.
Offline snowstorm
« Reply #45 on: November 07, 2017, 07:09:09 AM »
look the front axle over king pins center pivot . do a stall test 4 th gear lock the brakes hold it to the floor. shouldnt be ant tinny sound. look for excessive blow by. breaks work?
« Reply #46 on: November 07, 2017, 07:00:07 PM »
Thanks ol buddy. I'll keep it all in mind when I go check them out.
Offline woodmaker
« Reply #47 on: November 08, 2017, 09:01:56 PM »
The 580 E was famous for rust. Look under the rear fenders,the bottoms of the doors,pick up the floor mats if you can. The E series backhoe doesn't
 have as much lift as the k series(two smaller hydraulic cylinders vs. one large one) . I can't remember if the e series has a case or a cummins diesel,but both are good engines. As snowstorm mentioned, check for blow-by.I had a k series with a cummins that got tired enough that it would not  start at 10 degrees,which doesn't work well to load sanders.
If you find one that is in good shape but needs engine work,remember that the case engines are sleeved,but the cummins are not,so a cummins would have to be bored .
franklin q80,builtrite 40,husky 372,sachs dolmar 123, dozers,excavators,loaders,tri-axle dump trucks ,autocar tractor with dump,flatbed and detachable trailers, and 8  f350 diesels
@#$#%$#&* backhoe
Started by BW_Williams on Sawmills and Milling
Last post March 23, 2004, 03:35:01 AM
by Fla._Deadheader
backhoe
Started by LeeB on Sawmills and Milling
Last post September 21, 2004, 12:08:06 PM
by MrMoo
backhoe
Started by justintimemoto on Forestry and Logging
Last post August 21, 2009, 06:55:05 PM
by customsawyer
Jumpy Backhoe
Started by Qweaver on General Board
Last post May 16, 2006, 12:18:45 PM
by submarinesailor
