Arborwear
Author Topic: Proper way to saw these big logs  (Read 1642 times)
Offline Mcavvie
« on: October 29, 2017, 07:07:26 PM »
I bought these logs from a local home owner. I donít have a use for them right now, but want to saw them for later use. Was thinking about sawing into live edge planks and sticking them. What are your suggestions?
Wood-Mizer LT15, Bolens 1900H Eliminator, JD 4110/FEL/forks, Komatsu PC18MR2 mini ex.
Offline Stuart Caruk
  • Gender: Female
  • Woodmizer LX450 DieselStationary timber processing
Re: Proper way to saw these big logs
« Reply #1 on: October 29, 2017, 08:09:59 PM »
Some people prefer brunette's, others red heads, me I prefer blonds...
Personally I hate live edged slabs. I rather trim the boards into a cant for storage, or saw the can'ts into boards. Unless you have an edger, then slabs that will fit through it work great.
Stuart Caruk
Wood-Mizer LX450 Diesel w/ debarker and home brewed extension, live log deck and outfeed rolls. Woodmizer twin blade edger, Barko 450 log loader, Clark 666 Grapple Skidder w/ 200' of mainline. Bobcats and forklifts.
Online GAB
« Reply #2 on: October 29, 2017, 08:23:28 PM »
You could make some Poston flower boxes and be the envy of your neighbors.
With the inside pieces you could make some live edge on one side and straight edge the other side pieces.  These fit against a wall nicely.  The possibilities are only limited by ones lack of imagination.
Gerald
Offline POSTON WIDEHEAD
  • Getting old but doing it with Friends.
« Reply #3 on: October 29, 2017, 08:49:13 PM »
If you have the tools to make tenon legs,
I'd take these aged logs and make rustic benches. Saw into 3 -4 inch slabs. You can stain some, or let them darken on their own.
You have hundred's of dollars in benches there.
Where's the Spoon?
Offline Mcavvie
« Reply #4 on: October 29, 2017, 09:00:13 PM »
I wonít be making furniture out of them. Iím thinking about sawing them into 2 or 3Ē slabs, a size so I can resale later into 2x4ís, boards or whatever,then store them to dry, until I find some that wants them, or use them myself. Just donít want to saw them into lumber right now.
Offline Kbeitz
  • Never enough time...
    • My Hobbies
« Reply #5 on: October 29, 2017, 09:20:06 PM »
When i don't know what to do with the log I have I cut them into the biggest
square cant that I can... I can always cut them again later.
Love machine shop work
and Wood work shop work
And now a saw mill work
Offline TKehl
  • Certified Contrarian
    • Kehlhof Ranch
« Reply #6 on: October 29, 2017, 09:38:29 PM »
Hard to make money (or even break even) competing with automated sawmills and big box stores on dimensional lumber.  (Theirs is also kiln dried and planed.)  There have been several sawmill "confessionals" about buying 2x4s etc.
Since you say you bought them and mention resale, I'll bet you don't want to sell lumber at a loss or sit on it forever.  Best to make stuff you can get a better return on.
Personally, I also see benches or name signs for a yard.  Whether you build them or sell the slabs to someone that does, that's one of the best returns.  Especially since they look like they may be spalted.
Offline 47sawdust
« Reply #7 on: October 29, 2017, 09:54:13 PM »
Any wood bores in them logs yet?
Mick
Offline drobertson
« Reply #8 on: October 29, 2017, 10:20:59 PM »
If you get a good sticker job, and the logs and lumber behave, it may be a good idea to saw out live edge and especially if you are planing on resawing later, those should make some nice workable lumber once sized to dimensions, sticker good,,be sure to weight them down,
Offline Brad_bb
    • My timberframe blog
« Reply #9 on: October 29, 2017, 10:48:37 PM »
I found with hardwood cants, that it's better to saw it to the final product than to cut it into the biggest cant and let it sit.  I had too much checking that reduced the quality of any boards.  Sawing it into the final sizes right off, be it 1x, 2x or slabs, better to do it right up front.  This will helps reduce checking.
Offline Ianab
« Reply #10 on: October 29, 2017, 11:14:10 PM »
If you saw them live edge, say 2" thick, then they can be stickered to start drying now, and should stay good, indefinitely if they are stored correctly. As opposed to leaving them in log form where they wont dry properly, and will probably stain / check / be eaten by bugs etc.
Then once dry you have to option to resaw them in dimensioned boards, or sell them as wide slabs, with or without the live edges. Some folks wont straight edges, some live, some with one live edge, and one straight.
You have the options either way.
Making 2x4s would be my last choice because they can be bought so cheap it's hardly worth the effort to saw them. But good 12 x 2s are actually worth money, a LOT more than three 2x4s.
But I guess it depends what your customers want.
Offline js2743
« Reply #11 on: October 30, 2017, 07:54:20 AM »
from a home owner, was they yard trees?
Offline 69bronco
  • Location: Upstate New York when it's warm, southwest Fl when it's cold!
« Reply #12 on: October 30, 2017, 07:55:11 AM »
Looks like a little blue stain, maybe some worm holes. I'd go live edge for benches, bar tops etc. Make sure you've got dry stickers, pine and sticker burn go hand and hand.
Lt 25, New Holland 555e backhoe, Ford 2120 and a sore back
Offline WV Sawmiller
    • Green's Sawmill Services
« Reply #13 on: October 30, 2017, 08:16:57 AM »
   I'm with Ian on cutting into slabs and stickering. Can always edge them later if needed for framing or you can sell to others to make benches and such. I bought a tenon cutter and make live edge 2" mortise and tenon benches. I used to make them thicker but they were too heavy and 2" is plenty sturdy.
   When I do saw stock I make it a little oversized and as big/wide as I can. I can always resaw a 2X12 into 2X6's or 2X4s or a 2x8 & a 2X4, etc. Like they say - You can always make them smaller.
Offline Mcavvie
« Reply #14 on: October 30, 2017, 06:33:09 PM »
Iím with Ian too, was kinda thinking that was what I was going to do.
Offline Mcavvie
« Reply #15 on: November 12, 2017, 05:29:04 AM »
Finally got those logs sawed. A big letdown tho, worms had ate into the outside 6Ē of each log, but was able to get some nice 2x 16ís and 2 2x18 , and 4 2x6ís from the center with no worm holes. All the boards and 2x4ís are full of worm holes. Sawed them by myself, what a job! My left wrist and left elbow are feebly it know.
 http://www.forestryforum.com/gallery/albums/userpics/47399/5C4D59AF-FC5D-426A-80DD-948376B27B9D.jpeg
http://www.forestryforum.com/gallery/albums/userpics/47399/ED75CD9E-3F13-49AF-9436-E8E2F77E350E.jpeg
Offline Kbeitz
    • My Hobbies
« Reply #16 on: November 12, 2017, 07:08:37 AM »
worm hole wood can bring in big money...
Offline 47sawdust
« Reply #17 on: November 12, 2017, 07:11:46 AM »
Some people like the character of boards that have worm holes in them.It's like blue stained pine boards.If you call it blue denim pine designer types really go for it.
Kbeitz was faster on the trigger.
Mick
Proper bucking of logs
Started by Mesquite Man on Sawmills and Milling
Last post October 26, 2002, 07:43:37 AM
by Frank_Pender
Proper way to find sawyer --- NJ --- Logs to big for LT-10
Started by cwimer973 on Sawmills and Milling
Last post March 15, 2016, 07:27:11 PM
by Magicman
First time loading logs with out proper tools.
Started by Joe Hillmann on Sawmills and Milling
Last post July 04, 2014, 05:27:34 PM
by dboyt
question
what is the proper cut?
Started by land_owner on Forestry and Logging
Last post November 21, 2004, 12:44:03 PM
by SwampDonkey
