KNOW WHAT?
Between February 12, 2018 and June 18, 2018, this space displayed 13 Million, 871 Thousand and 87 times.
BRUTE FORCE Authorized Dealer
Council Tool
Author Topic: Wheel belts coming apart.  (Read 2292 times)
Offline irvi00
« on: November 02, 2017, 07:30:43 PM »
First off, I tried to search and couldn't answer my question. The pulley belts that came new on my WM lt50 lasted almost 300 hours. Since then they have been coming apart in about 10 to 15 hours. These are wm belts. Last set maybe 5 hours. The only thing I've done different is spray the blade with wd40 before I take it off to clean it up. Is it as simple as the wd40 or do I have an underlying problem?
Offline Chuck White
  • Sawing Mobile since 2005
Re: Wheel belts coming apart.
« Reply #1 on: November 02, 2017, 07:41:11 PM »
Without a doubt, I would be calling Wood-Mizer!
~Chuck~
1995 Wood-Mizer LT40HDG2425 Kohler - Shingle & LapSider, Cooks Cat Claw Sharpener, 4-foot Logrite cant hook.
Basic mechanical skills are all that's required to maintain the Wood-Mizer.
I LOVE MY SAWMILL
Offline POSTON WIDEHEAD
  • Getting old but doing it with Friends.
« Reply #2 on: November 02, 2017, 08:18:17 PM »
Anything with petroleum in it will surely take its toil on a belt.
I'm not saying this is the problem. I clean my blades every once in a while with a spray of diesel.
I can tell my belts will become a little mushy from diesel over time. I change my belts about every 500-700 hours.
However, I have never had a belt separate.
Where's the Spoon?
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #3 on: November 02, 2017, 08:31:47 PM »
Mine never gets anything except a wire brush or the brush scraper tip.
Offline irvi00
« Reply #4 on: November 02, 2017, 08:52:18 PM »
The first set that came with the mill were great. 300 hours and they were fine. A broken blade took them out. Two sets since then. The backs are coming off and causing imbalance. Today one just shredded up it's back. This is getting expensive quick. I've stopped with the wd40. But just to be sure, could there be another problem?
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #5 on: November 02, 2017, 09:36:46 PM »
Be sure to contact WM because there may be a Mfg. defect that needs to be identified.  They may want those old belts.
Offline irvi00
« Reply #6 on: November 02, 2017, 10:03:49 PM »
Definitely will do that. I checked a lot of things and mill looks to be in alignment. Bearings all tight, guides are good. The belts are in the grooves and no buildup underneath. Could the wd40 cause the breakdown?
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #7 on: November 02, 2017, 10:15:59 PM »
I have no idea because I have never sprayed WD40 or anything else on any belts.
Offline Coltbodi
  • Sure, I can fix that
« Reply #8 on: November 02, 2017, 10:16:38 PM »
I doubt it's the wd40 since lots of people including me run straight diesel on there blade for lube. Maybe it's the way you are putting them on. If they where doing well from the factory and now are shredding the only difference (assuming none of the alignmeants moved) are who is installing them. If it's not that I would guess that it's the way the blade is running on the belt, if it's running to far forward than the rear of the blade could be digging into the crown of the belt. Is it both belts?
If I can't fix it, I don't want it.
Timberking 1600 with lots of mods, a 65hp mahindra with a front end loader, a welding shop, and sugarcane mill from 1890 for making syrup
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #9 on: November 02, 2017, 10:30:26 PM »
There is no crown on WM B57 belts which I assume irvi00 is using.  They are flat.  They run loose so there is really no "installing".  Just slip them over the bandwheels.
I am leaning toward a bad batch of belts, but then, I have no idea what WD40 would do??
Offline Coltbodi
« Reply #10 on: November 02, 2017, 10:55:53 PM »
Oh ok, much different than the ones on a timberking. I'd have to agree with you about the belts on that note. Doesn't seem like it could be anything else.
Offline irvi00
« Reply #11 on: November 03, 2017, 08:03:57 AM »
Yup. Woodmizer b57 belts. Both sets that came apart were ordered at the same time so it's very possible they could be faulty. A new set should be here today so I'll try one more time. (With no wd40!)
Offline armechanic
« Reply #12 on: November 03, 2017, 11:15:50 AM »
A few years ago, I installed an upgrade to my 1988 LT 40 which included larger drive pulley on engine and new belts on the blade wheels which are very tight, I mean tight. They have worked real well. I seen the comment about loose belts reminded me about mine.
1989 Lt 40, D6C CAT, Home made wood processer in progress.
Offline irvi00
« Reply #13 on: November 05, 2017, 07:54:07 AM »
Just to show yall what I'm dealing with. @ 8 hours on these belts. Both belts looked the same. Put some new ones on Friday evening and sawed about an hour Saturday morning. So far so good. Will find out more tomorrow when I fire off for a full day. Will no longer use wd40 on the belts and see if that makes a difference. I also watched the blade run for a while and it was tracking properly on the wheels.
Offline terrifictimbersllc
    • Terrific Timbers LLC
« Reply #14 on: November 05, 2017, 10:28:35 AM »
I've never seen anything like that in 3700 hours of sawing. My belts go on oily he from the sharpening setting processbut that gets cleaned off within a minute or two of sawing.  Then all the belts see is cascade in water. Maybe you are loading up and pressing WD-40 into  the belts before taking the band off. I would  stop that practice and wipe the band after taking it off with WD-40 instead if you want to. In any case like mentioned above there must be something different between  WD-40 and diesel if that is causing your problem because others use diesel here.
DJ Hoover, Terrific Timbers LLC,  Mystic CT   2001 WM LT40SHDD (42HP Kubota, Accuset2, FAO's, Lubemizer, debarker, hydraulics everywhere), Peterson WPF 10-30 with chain slabber. Logrite fetching arch, WM BMS250 sharpener/BMT250 setter.
Offline irvi00
« Reply #15 on: November 05, 2017, 10:32:58 AM »
That was my thought too. I was spraying the blade as it ran under tension just before taking it off. So possibly squeezing the wd40 into the belt. Won't be doing that any more. (But it sure cleaned the blade up nicely!) I'll know more by Tuesday if it makes a difference. New set of belts and absolutely no wd40.
Online LeeB
« Reply #16 on: November 05, 2017, 09:09:17 PM »
Did you get the same problem with more than one blade?
Offline irvi00
« Reply #17 on: November 05, 2017, 09:37:23 PM »
Yes. I go through 4 to 5 blades a day. Some are resharpened, some are new. It didn't seem to matter what I ran, they shredded anyway. Judgement time comes tomorrow. New belts, full day. Wish me luck!
Online LeeB
« Reply #18 on: November 05, 2017, 10:29:23 PM »
How much tension are you running on the blade? Is it possible he blade is slipping and causing wear to the belt?
Offline irvi00
« Reply #19 on: November 05, 2017, 10:32:45 PM »
Running at 3000 psi, the specified tension that WM calls for. I haven't heard any slippage. This is a 3 phase electric mill.
Online LeeB
« Reply #20 on: November 05, 2017, 10:39:12 PM »
Looked at the pic of the belt and it looks to me like it could be from the blade slipping, quite possibly caused by the WD40. I've had the blade slip before when really flooding the water to it on a wide cut in live oak. Where you cutting anything different than normal?
Offline irvi00
« Reply #21 on: November 07, 2017, 06:00:31 PM »
Sorry for the delay. LeeB, it's been all my normal cutting which is anything and everything. But today I have around 6 hours on new belts and so far so good. They still look fine. No breakdown at all. Unfortunately I don't know if it was bad belts or the wd40. But oh well, eliminate one factor. No more wd40 on the blades. I'll follow magicman and just use a brush to clean em up.
Offline Darrel
  • Never throw an unopened log on the burn pile.
« Reply #22 on: November 07, 2017, 11:25:29 PM »
I've been watching this thread, glad that things appear to be worked out.  Hoping that the good fortune continues.
1992 LT40HD
Offline YellowHammer
  • Always taking steps to save steps
    • Hobby Hardwood Alabama
« Reply #23 on: November 07, 2017, 11:48:56 PM »
The suspense is killing me.  I've got half a mind (that's full capacity for me) to remount some old belts I have for spares, spray some WD on them and get to sawing.   ???
What exactly were you doing?  Spraying them to clean them at the end of the day or?
HobbyHardwoodAlabama.com
Online LeeB
« Reply #24 on: November 08, 2017, 12:41:46 AM »
Another question comes to mind. Are both belts failing or only the drive side?
Offline Kbeitz
  • Never enough time...
    • My Hobbies
« Reply #25 on: November 08, 2017, 07:31:46 AM »
Love machine shop work
and Wood work shop work
And now a saw mill work
Offline irvi00
« Reply #26 on: November 08, 2017, 07:38:20 AM »
Before taking a blade off I would spray between the guides while it's still running under tension. Right on the surface of the blade. Then took a stick and rubbed it clean. The blades came off clean as a whistle. And the belts would be clean too! But no more of that.
Offline irvi00
« Reply #27 on: November 08, 2017, 07:39:59 AM »
Both sides would come apart equally.
Online LeeB
« Reply #28 on: November 08, 2017, 08:51:29 AM »
Ok then, I give up on the idea of the blade slipping on the belts.
Offline Darrel
« Reply #29 on: November 08, 2017, 10:28:41 AM »
t
Which gives me the idea that centrifugal and other forces of physics along with the fact that WD40 softens rubber and makes both belts have a major come-apart.
Anxiously awaiting the results of 4x4's half brained experiment! :P :D
1992 LT40HD
Offline ladylake
« Reply #30 on: November 09, 2017, 07:40:19 AM »
 Lee had a good question, if the drive side was slipping it sure wouldn't make the idle side wear.  Steve
Timberking B20 12000 hours +  Case75xt grapple + forks+8" snow bucket + dirt bucket   770 Oliver   Lots(too many) of chainsaws, Like the Echo saws and the Stihl and Husky     W5  Case loader   1  trailers  Wright sharpener     Dino setter Volvo MCT125c skid loader
Band wheel belts
Started by onorato on Sawmills and Milling
Last post April 17, 2016, 06:15:09 PM
by Dave Shepard
Band wheel belts
Started by Bruno of NH on Sawmills and Milling
Last post April 27, 2017, 07:42:04 PM
by Dave Shepard
Urathane wheel belts?
Started by macpower on Sawmills and Milling
Last post June 04, 2012, 12:58:18 PM
by Peter Drouin
Blade wheel belts
Started by TimJr on Sawmills and Milling
Last post April 05, 2010, 01:03:21 AM
by logwalker
