TURBOSAWMILL GIANT SALE ON NOW UNTIL OCTOBER 31st
BRUTE FORCE Authorized Dealer
Council Tool
Author Topic: WM claim "Special two-plane clamping system simplifies sawing of stressed logs"  (Read 2284 times)
Offline RIMwood
I pulled this quote from the Woodmizer web site "Special two-plane clamping system simplifies sawing of stressed logs".
I'm new to the forum, not sure why I have not joined years ago, so much incredible information!
I have a 2002 LT40 manual mill, and I have been thinking of converting my manual to a hydraulic mill. There are great posts on doing the conversion. I really like  pineywoods conversion for the log turner and clamp, such a clever and simple design. Then I saw the WM claim on sawing stressed logs and now I'm thinking the 2 plan clamp might be worth the effort, not sure my skill level is up to it, you have to cut the frame to install it like WoodenHead and others have done.
I have a lot of Ash blow down from hurricane Sandy in 2012 that I have not yet milled. It milled fine back then, but now, not so much. I guess the logs are developing stress from drying over the years. Seems like the ability to apply downward pressure to a cant and hold it while on the mill might actually help to get a straighter cut.
So, my question is to WM sawyers with 2 plane clamps, does the 2 plane clamp actually help sawing stressed logs?
Online pineywoods
Rimwood, I did some serious looking at adding the factory hydraulic parts to my manual lt40. There are a couple of guys on here who have done that, but be aware there are some not-so obvious gottcha's. Even if you are good enough a welder to successfully modify the frame, the parts don't just bolt on, welding is required in other places. Real easy to mess up a good mill. That frame is constructed using a heavy steel jig to hold everything in place during welding. Next, the electrical system is nowhere near robust enough to support hydraulics. The pump motor will pull upwards of 200 amps. As to the 2 plane clamp, I admire the design, but it does have limitations. It's not designed to apply a lot of downward pressure, mostly sideways against the backstops. In the hands of an experienced sawyer, it can be used for a lot of other useful tricks besides just clamping...
Offline terrifictimbersllc
    • Terrific Timbers LLC
I don't actually know what they mean by that.  But guessing that it means that the clamp can hold the cant tightly to the bed. To prevent the center from lifting.  It won't prevent the ends from doing so.  I'd say generally when I'm down to 4-5" on the cant then I clamp tight and go for it.  The larger the cant or the more the stress, it can pop loose and then you could lose a board if you're sawing that way.
DJ Hoover, Terrific Timbers LLC,  Mystic CT   2001 WM LT40SHDD (42HP Kubota, Accuset2, FAO's, Lubemizer, debarker, hydraulics everywhere), Peterson WPF 10-30 with chain slabber. Logrite fetching arch, WM BMS250 sharpener/BMT250 setter.
Offline RIMwood
Thanks for your input pineywoods. I can probably handle the welding but like you said "Real easy to mess up a good mill", which is why I really like your design. Not worried about the electrical system, plane on hooking up to my tractor hydraulics or maybe a log splitter I'm not using.
Offline RIMwood
 terrifictimbersllc, I'm not sure what they meant either, good point about the ends, although it seems they bow up in the middle most of the time. I'll try clamping it and see how that works. Not use to these stressed logs, most of what I have cut in the past lays nice and flat on the mill. Do you run across this problem a lot?
Generally the cant will bow up in the middle as one is taking boards off the top,  as one goes towards the pith.  Cant now has a concave face pointing down (lifted up in the center).  On flipping it, the ends are up now, as boards are taken off, the ends go down to the bed. Right after it is flipped, if the cant can be held to the bed in the middle by very firm clamping, it can be finished off into mostly uniform thickness boards.
Online barbender
You would have to have spiked backstops, and some kind of spike on the clamp to bite into the cant to hold it down. I think Cook's mills have something along those lines. I usually just keep flipping the cant as I'm sawing, no big deal when you have hydraulics. Maybe that's what WM meant by that statement? You can flip a cant quick with that 2 plane. If you're having to flip the cant after every 3rd cut on a manual mill it would be a pain.
Online Magicman
  • A "Traveling Man"
    • Knothole Sawmill
I find that it is much better to flip the cant and prevent the bowing than to deal with a cant that has bowed.
Ease of flipping is a better example of how the clamp helps in sawing stressed lumber than the one I gave.  Nevrertheless the clamp on my LT40 has ridges in the side to give some bite, and what it clamps against directly opposite the clamp, also has a ridge.  The two together can indeed hold a the cant tight to the bed, within reason.  For example if I have 4 1" boards left to go, to finish off, I am usually going to clamp the cant tight to make the last 3 cuts rather than consider flipping it again.
Offline Chuck White
  • Sawing Mobile since 2005
Not to sidetrack this topic, but I have a question!
My friend bought a new LT35HD last year and while giving him a hand with it one day, I noticed that when he was edging some flitches, that the 2-plane clamp can't clamp a one inch board!  It will only close to about 1½ inches!
Is that normal?
If so, wonder what the idea was behind it!   :-\
~Chuck~
1995 Wood-Mizer LT40HDG2425 Kohler - Shingle & LapSider, Cooks Cat Claw Sharpener, 4-foot Logrite cant hook.
Basic mechanical skills are all that's required to maintain the Wood-Mizer.
I LOVE MY SAWMILL
Do you mean the clamp doesn't go in far enough to clamp a 1" board standing vertically?  For example if you were wanting to edge a 1" board.  Or are you talking about a 1" board lying flat on the bed?
My mill needs three 1" boards standing on edge to clamp tight, unless I swivel the head by hand or use another board lying on the bed.  It's because the cylinder when closed leaves the clamp open about 2-3/4".
Offline Dave Shepard
  • Geometrically proportional
    • My homepage
That's normal on my LT40. I just toss a 3x4 piece of dunnage on the deck.
Wood-Mizer LT40HDD51-WR Wireless, Kubota L48, Honda Rincon 650, TJ208 G-S, and a 60"Logrite!
Offline scully
  • Orange Mills Matter
On stressed logs there is not much that can be done bye clamping in my opinion . At least not on a LT40 hd . I've trieed to suck down cants for the last 2 or 3 cuts and seldom have success . If a log moves on me allot I sometimes re-flatten the face before the next board cut . I don't feel that the clamp offers a big advantage other than hold .
I bleed orange  .
Offline Peter Drouin
    • A&P Saw mill LLC
I can pull in down if I have to.
Fangs,  ;D
2008 LT40 super,2008 edger, Cat telahandler, JD 5410 And can cut up to 45' long
http://www.forestryforum.com/sanbornton     NH Timberland Owners Association supporter.
And a license NH soft wood grader.
Sawing since 1987
Online Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Yes, I quite often grab a board to use as a supporting spacer when I have less than three 1" flitches, but my "stick" is always there when needed.
My present White Oak stick replaced the broken Cherry stick several years ago.  It's painted stripes distinguishes it as a tool.  It sees service both in the horizontal and vertical position.
Offline 4x4American
  • Team red, white, blue and orange
    • Website Link
Fast forward to 40 seconds in to this video, we need these cant hold down clamps in america.  The bi plane clamp is great but it does little to eliminate stress you have to saw in a manner to level the stress out.  Then go to 2:25 and see the powered rollers, another thing we need in America!
Boy, back in my day..
Offline paul case
  • Original wearer of the PCM.
I cant edge 1 1'' board on my 94 model lt 40 or on the 2013 lt 40 super.
I think the clamp on the '13 is awesome  but it may not straighten a bowed cant.
We  have been sawing some 10''x10'' timbers and sawing 3'' thick side lumber. We can place the 3'' flitches on the loader arms and with the 2 plane clamp Scott can move over and stand those heavy boogers up and edge them without touching them by hand most of the time. That thing is awesome!
PC
pc
Offline WV Sawmiller
    • Green's Sawmill Services
Chuck,
   Even 2" is a bit thin to clamp tightly on my LT35. I mentioned this at a seminar to Marty Parsons who was there and he showed me the trick of putting a 1" flitch on the mill to be edged then laying a finished 1X4 or 1X6 down as a spacer. Before I had stood my spacers up beside the flitch to exceed a 2" width but the ends before and after the clamp still tended to shake badly at times. Laying it down flat like that put more pressure on the whole length of the flitch to make it more stable to edge and I assume that is what Lynn is doing with his Magic stick he shows above.
Offline drobertson
as far as handling stress in logs, well, some just don't and won't behave, they are bad boys,, I had to take a cut off the bark side, then 90° clamp and another cut off the bark side,, then flip to the third side, bark only working towards maybe a 4" face, a little more maybe,, watching how it's laying on the bed of course, then the fourth, thin slab cut again.  Some logs that I knew may be bad, I flipped a few times, just to let the know I had the horns you see, ( my Festus) poor at that impression, :D but all kidding aside, logs are or can be really good and really bad, and bout everything in between.  The clamp will help on many logs, if you know what to do and what to look for.  It does take time,,and a few long bows,, :D  Just saying.  Bad logs with off centered piths, well I'm sure I can have a chorus of support on sawing these horn toads,, ;D it's a match and a pile of the best of whatever you can make of them :D
Online Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Exactly Howard.  It is about 1"X2½" X 5'.  The length is so that it will nest in the back of the truck with the cant hooks, and the dimensions work out perfectly for edging.
In 15 years of sawing, that is probably my 4th stick.  Broke my Stick  I see in this 2013 topic where I said that my present stick is Red Oak.  Maybe so, but at over 4 years old, it is a good one.   ;D
    • A&P Saw mill LLC
You will always have 4 or 5 boards to edge per log unless you leave the 1x4,6 in the slab.
As you work your way down leave one edged board on the deck to clamp if you have too.
That worked well for me.
Sawing since 1987
Offline Chuck White
I understand that the 2-plane clamp was designed that way, but it would be nice to be able to edge a 1" board all by itself!
I edge 1" boards on my mill, daily with my old "flipper" style clamp!  Makes it nice to be able to do that rather than throw another piece on the mill to hold it in place!
~Chuck~
I LOVE MY SAWMILL
Offline Stuart Caruk
  • Gender: Female
  • Woodmizer LX450 DieselStationary timber processing
With their design, you could move the clamp in to edge a 1" board, but then you would lose that travel when you wanted to clamp a larger log. Me I already think my clamp doesn't open far enough, and with an edger I see no reason to edge 1x's on the mill.
Stuart Caruk
Wood-Mizer LX450 Diesel w/ debarker and home brewed extension, live log deck and outfeed rolls. Woodmizer twin blade edger, Barko 450 log loader, Clark 666 Grapple Skidder w/ 200' of mainline. Bobcats and forklifts.
Offline 4x4American
    • Website Link
Hey did you get the lx450 yet
Offline RPowers
    • NWA Sawmill
I pulled this quote from the Woodmizer web site "Special two-plane clamping system simplifies sawing of stressed logs". ...
RIMwood,
I use my 2-plane clamp all the time for this. I saw 99% hardwoods, most of which are low-grade or sub-optimal trees for customers who want lumber made from "their" trees. I've sawn high-stress things like ash, small white oaks and hickories, and leaners and limbs of all kinds. You aren't going to avoid stress in the lumber, this is built-in to the way the fibers grew, so once a board is released from the cant it is going to bow or crook depending on how you laid the cuts out. You have to try and read the log and plan accordingly, but MOVE they will. The trick is to keep the cant itself from deforming while you are cutting which will produce boards that are thick-and-thin and not consistent. My method is thus:
1st face -  center log mass parallel to mill deck make cuts to get 50% of my desired board width from center if that doesn't take too much material from one side. Flip log 180 degrees to 2nd face
2nd face - with log flat on deck on 1st face, cut down to get desired board with in cant. Flip log 90 degrees to 3rd face
3rd face - center log mass parallel to mill deck, take just enough cuts down to get a nice square top, plus maybe one or two boards down from there if the log is large enough. Flip to last face
4th face -  If you haven't taken too many boards from the 3rd face the cant shouldn't be able to bend itself yet, so make sure both ends are supported by a bunk or roller and then clamp the crap out of the bottom and pull the clamp down to put slight down pressure on the bottom as well. Now I've found that I can start at the top and take the whole cant down one board at a time all the way to the bottom or "dog" board without any issues, because the 2-plane clamp holds the middle down and both ends are supported so they can't drop below the mill deck.
You have to do it this way, otherwise you are flipping the DanG thing every board or two to keep it flat. This way it isn't able to move, ever. Works great and less turning. Hope this helps someone. No one with the power of hydraulics on their mill should ever have to worry about flipping and turning to keep the stress out of a cant unless you make the mistake of letting the thing loose halfway through, then you get a banana. I know.....  :D
2013 Woodmizer LT28G25 (sold 2016)
2015 Woodmizer LT50HDD47
Offline RIMwood
Thanks to all for the great input.
I have experimented flipping the cant but without the ability to get a good clamp on, it just don't work.
RPowers, yep thats the way I want to do it, good to hear it works for you. One question, do you leave the boards on the cant or do you take each board off as you cut?
I always mill by myself and I find it quicker and a lot less handling if leave the boards on then pick up the whole bundle with the loader. It does take more time for the up/down travel of the head height as you work your way down the cant, but those 2" x 12" x 16' are real busters to handle by yourself.
Offline mikeoverbey
  • LT40G18 converted to Hyd
RIMwood,
I did the conversion http://www.forestryforum.com/board/index.php/topic,96848.20.html and am so happy with the outcome. I believe if you have the knowledge of electrical circuits and hydraulics and know how to weld, it becomes a straightforward process. It takes some time and thinking, but can be done. It depends on what your time is worth and if you like doing projects yourself, as I do.  Just don't let the idea of cutting and welding on a frame discourage you. Mine cut just as true after all the welding as it did before with absolutely no adjustments. In my opinion, this issue gets overrated. I've yet to hear of anyone messing up a frame. If you are familiar with jigs for assemblies, you'll immediately recognize that the woodmizer is basically built like one. By simply welding a piece across the cut, you'll assure yourself proper alignment. In theory, if you did get some welding shrinkage where the welds were able to pull against the frame, it MIGHT bow the frame toward the weld.  I tried to use the cutout to bridge the gap on the outside of the frame and didn't like the overlap---oops. I ended up welding another 2" strip around my bump-out for security.  I still didn't get any bowing in the frame.  All of my backstop dogs still line up.  I even took angular measurements with a digital inclinometer while doing this, to check the frames and saw no difference.
I'm not a real experienced sawyer but have hit the wrong control once or twice. The clamp doesn't pull down much when clamped on a cant. The two plane clamp is amazing and that is one thing I couldn't have had in a purchased mill of this vintage. My joystick setup really makes maneuvering the cants/logs easy.
Mike
Mike
Offline RPowers
    • NWA Sawmill
I usually cut a few boards, then drag them off the can't so I don't have to raise and lower the head so much. I rarely have equipment on portable jobs so this works for my needs. I forgot to clamp hard of the last face on a tall WO can't today and it jumped up an inch halfway through.That was a pain.
Sawing pattern for 14" to 20" diameter hardwood logs
Started by WoodenHead on Sawmills and Milling
Last post May 21, 2014, 05:45:46 AM
by WoodenHead
Sawing "big" short logs
Started by kelLOGg on Sawmills and Milling
Last post July 29, 2018, 08:05:08 PM
by WDH
"Sled" jig for small diameter "logs"
Started by Full Circle on Sawmills and Milling
Last post September 03, 2012, 10:58:22 AM
by barbender
Husqvarna 365 Special to 372xpw conversion for "Newbie's" & 372 triva as well
Started by weimedog on Chainsaws
Last post September 04, 2018, 09:45:07 PM
by caveman
