Arborwear
Author Topic: Advice on sawmill design  (Read 1459 times)
Offline Jrpitdog
Re: Advice on sawmill design
« Reply #20 on: November 09, 2017, 02:17:28 PM »
So if youall could have a couple hydro functions what would they be? Log lifter? Turner? Saw travel?
Have the hydraulics to the heavy or repetitive work
i would say these, in this order
Saw travel
log stops/log clamp
Turner
Log leveler, toe boards
a Log lifter can be a tractor to load the log onto the mill
a good source for hydraulic parts is
http://www.surpluscenter.com/
Ah yes surplus center I know it well, its where i ordered most of my log splitter parts years ago. I also know the boneyard at my work well😉
Offline Kbeitz
  • Never enough time...
    • My Hobbies
« Reply #21 on: November 09, 2017, 04:23:39 PM »
Wheelchair motors are great for Saw travel...
Love machine shop work
and Wood work shop work
And now a saw mill work
Offline moodnacreek
  • Sawin by the notches
« Reply #22 on: November 09, 2017, 06:03:55 PM »
Build high off the ground, even 2 story, in the back corner of the lot under a shed roof that sheds the snow out of the way. The mill should feed a nice lumber yard where it's easy to get around. I wish I had do ne this everyday.
Offline bandmiller2
« Reply #23 on: November 09, 2017, 08:26:25 PM »
Pitdog, I built my own band mill about 15 years ago and really had to change little. Have the bed of the mill at a handy working height. If you will have hydraulics you might as well have a turner and power feed. I chose to build a two plane clamp/turner and it does 90% of my clamping and turning. Leave yourself enough room around the band wheels to make band changing easier. Frank C.
Offline thecfarm
« Reply #24 on: November 09, 2017, 08:48:43 PM »
 Picture of the bunk out.
Picture of it in place. This is the 2x3 track that the heads rides on.
Offline Crusarius
  • Lost in....
    • RockModified.com
« Reply #25 on: November 09, 2017, 09:30:02 PM »
I like it. I may have to integrate that on mine. But I think I have the spacing pretty good to make it so I won't need it.
I knew what I thought I meant.
Offline DbltreeBelgians
« Reply #26 on: November 09, 2017, 10:58:08 PM »
Welcome to the Forestry Forum Jrpitdog.  I am a sawmill user not a sawmill builder, but following your progress will be interesting.
I have often visited Montrose and have a fascination for the Uncompahgre having hunted 61 once and 62 many times.  Grand Mesa is also a favorite spot.
Thanks,  my family and I love the western slope. I usually hunt 65, otc archery for me 😁
Welcome to the Forestry Forum Jrpitdog. Im envious of you living in Montrose. I grew up in Grand Jct and I got married in Gunnison Co up the Alpine Plateau Road at my parents place at Arrowhead Ranch. I hunted  fudd-smiley in 66 and some on Grand Mesa but not for quite a while now. I have a sister that still lives in Jct and someday Id like to come back to the Western Slope when I retire.
Brent
Offline ljohnsaw
« Reply #27 on: November 09, 2017, 11:34:22 PM »
Make it high enough.  Mine is about mid-thigh height.  If I have to turn a BIG log (manually), I hop up on the rail or even the bunk.
I have moveable bunks designed after theCfarm's:
Sorry for the blurry pictures.  The 2x3 rail is supported by cutoffs of the material I used (IIRC 5# structural steel channel).  I had to grind off a little on the bottom of the channel on the bunks so they could slide in.  I use a 1/2" bolt to lock them in place.  The uprights are 3# structural along with a 2-" square tube to hold the log stops.
The T handle is a bolt to lock the log stop at the desired height.  The horizontal 2" tube has a slider for the log clamps.  The 2x3 angle is the actual log bunk.  The space between was supposed to have a jack to lift a toe roller - never got around to making them.
What I would do different (and will make them this winter) is better log clamps.  I have a not so good cam-like system that tends to move and lift the log a little.  I'm going to make the simple push down cam lock that someone posted on here - just have to find it again for the name credit.
John Sawicky
SkyTrak 9038, Davis Little Monster backhoe, Case 16+4 Trencher, Home Built 38" cut Bandmill up to 64' - using it all to build a timber frame cabin.
Advice on knock down storage shelves design?
Started by Brad_bb on General Woodworking
Last post August 19, 2009, 01:23:58 AM
by Brad_bb
Log Home Framing Design Advice.... on Different Designs i.e. Listed Below
Started by H60 Hawk Pilot on Timber Framing/Log construction
Last post November 19, 2010, 11:49:16 AM
by H60 Hawk Pilot
Sawmill design question?
Started by Gundog on Sawmills and Milling
Last post December 19, 2016, 09:05:16 PM
by thecfarm
A Different Design for a Sawmill Roof
Started by AlaskaLes on Sawmills and Milling
Last post September 23, 2016, 01:31:46 PM
by AlaskaLes
