Arborwear
Author Topic: Kohler EFI woes  (Read 366 times)
Offline pineywoods
Kohler EFI woes
« on: November 10, 2017, 10:07:06 PM »
Working on a neighbor sawyers wm lt40  equiped with a 28 hp fuel injected kohler engine. They ran it all day monday, but said it sounded like it was running on one cylinder and was down on power. Next morning it cranks over but wouldn't start.
Spark plugs look ok, but swapped them out anyway. Electric fuel pump cycles up, builds up pressure, then shuts off normally. Hooked up a test light (the on-board malfunction indicator light is burned out) and went through the proceedure to display fault codes. Flashed code 61 which says no fault codes. I downloaded and read the kohler service manual and talked to Mike at woodmizer Indy. We've about come to the conclusion that both injectors are plugged up. Circumstantial evidence. Thieves stole the fuel tank off the mill. Owner hooked up a fuel tank from his boat outboard motor. Probably still full of OLD ethanol gas with  lots of 2 stroke oil in it. Current plan is to bring the mill to my shop and continue trouble shooting where I have tools and equipment. I will follow up post what we find...
Offline MartyParsons
  • Wood-Mizer Service and sales PA, VA, MD, WV others
Re: Kohler EFI woes
« Reply #1 on: November 12, 2017, 06:45:23 PM »
Hello,
   Do you have spark at each cylinder? Should have a modified spark plug to check for spark. Never seen a coil go bad on one of these engines on a WM but have seen them fail on lawn equipment. I have also seen push rods come off if the valve sticks.
Will it start on 2+2 carb cleaner sprayed into the intake?
Marty
A pessimist sees difficulty in every opportunity; an optimist sees opportunity in every difficulty. -Winston Churchill
MD VW Woes
Started by Paul_H on Sawmills and Milling
Last post October 04, 2005, 09:13:08 AM
by Frank_Pender
thumbdown
AT&T Woes
Started by chet on General Board
Last post March 29, 2006, 05:50:32 PM
by SwampDonkey
allison woes
Started by woodmills1 on General Board
Last post June 10, 2010, 07:50:43 AM
by Meadows Miller
Deere woes
Started by thenorthman on Forestry and Logging
Last post September 27, 2014, 11:41:11 PM
by Duhnis
