Arborwear
Author Topic: A Little Rain  (Read 483 times)
Offline Autocar
A Little Rain
« on: November 13, 2017, 03:02:32 PM »
Last night  it may have broke the camels back working on corn stubble and it was wet. I was hoping on pulling logs tomarrow but my better judgement says to forget it ! Farm ground it is packed down so hard every bit of the rain lays on top . This time of year it dosen't want to dry worth a darn. Sure can be a bummer sometimes  :D.
Offline mills
Re: A Little Rain
« Reply #1 on: November 13, 2017, 08:12:04 PM »
Dang, hate to hear that for you. Not to be mean, but maybe you'll get lucky and it'll will freeze up fairly soon. (I hate cold weather. >:() We don't get very many days during the winter that freeze hard enough to get you through the bad spots. On Friday I pulled off the steep hill job I was working, and then we finally missed a rain. Could have hit for another week. :-\ Oh well, couple of baths, oil and filter changes, and I'll head out to work with some farmers on tiled bottom ground. Other than a few deep thawing days I can run most of the winter if the ground has been tiled.
Offline Autocar
Re: A Little Rain
« Reply #2 on: November 14, 2017, 10:27:24 AM »
Freeze up seems like it dose't come here like it use to. When I was a young man January and Febuary it was blue bird days and wouldn't get above 15 degrees . Most of the ground around here it titled but they no till there crops and they only use about four inches of ground for planting. That turns to slim and your get in hot water with the landowners if you track it up. And before you know it your have ruts and once water is in them well I don't have to tell anyone about ruts and water form there it goes down hill  :D
Bill
Offline mike_belben
  • Pulp Friction
Re: A Little Rain
« Reply #3 on: November 14, 2017, 08:49:15 PM »
Can you run a subsoiler through the mushy spots without hitting the drainage lines?  Ive had very good luck breaking up compaction to get surface water into the ground with a few slices.
Revelation 3:20
Enough Rain
Started by jargo432 on General Board
Last post June 25, 2014, 08:47:59 PM
by jargo432
Rain again
Started by CLL on General Board
Last post June 25, 2008, 11:33:20 AM
by leweee
Rain, Rain, go away.....
Started by Faron on General Board
Last post March 13, 2006, 03:42:53 PM
by flip
After the rain
Started by jwilly3879 on Forestry and Logging
Last post January 12, 2014, 08:16:53 PM
by jwilly3879
