KNOW WHAT?
Between February 12, 2018 and June 18, 2018, this space displayed 13 Million, 871 Thousand and 87 times.
Author Topic: Timberjack 1010  (Read 1544 times)
Offline Airgrower
Timberjack 1010
« on: November 20, 2017, 03:26:19 PM »
Does anyone have any experience or knowledge of a Timberjack 1010 6 wheel forwarder?  Mainly the transmission and gear ratios. Looking at doing a custom build.  I donít want to kill the rear end on the machine I will be mating the back of 1010 to.
Offline snowstorm
Re: Timberjack 1010
« Reply #1 on: November 20, 2017, 05:43:09 PM »
isnt it hystat?
Offline Pulpwood mafia
Re: Timberjack 1010
« Reply #2 on: November 20, 2017, 06:35:40 PM »
It is hydrostatic with a transfer case with a Hi Low shift. Whatís wrong with the front half.
Offline Airgrower
Re: Timberjack 1010
« Reply #3 on: November 20, 2017, 08:39:56 PM »
I am looking at purchasing the back half off of a machine.  Front half doesn't come. I am trying to learn if I can mount the back half to a 2003 548 G3. I don't want to mess the transmission up in the skidder. I need a LGP machine that can apply fertilizer   Not many choices for the woods. Hoping I can custom build one.
Offline barbender
Re: Timberjack 1010
« Reply #4 on: November 20, 2017, 10:34:31 PM »
I think it would be way easier to just get a forwarder that has both ends. I'm sure with enough time and money you could mate the 548 up, if the gearing is wrong, I'm not sure how you would match that up. Different gears in the 1010 diff?
Offline Airgrower
Re: Timberjack 1010
« Reply #5 on: November 21, 2017, 06:55:20 AM »
Most forwarders are too tall and have really exposed cabs. We may move the machine up to 5 times a day and I don't want to deal with being 15 feet tall.  Deere 548 is still relatively easy to get parts for throughout the SE. The tigercat 615 skidder is close to what I need. Just trying to avoid spending $300k.
Offline lopet
  • Do not climb any higher your comportable falling !
Re: Timberjack 1010
« Reply #6 on: November 21, 2017, 06:55:12 PM »
You mean moving it from job site to job site ?  :o :o  Are you from Europe ?
Offline 1270d
Re: Timberjack 1010
« Reply #7 on: November 21, 2017, 09:12:31 PM »
Have you ever seen a fabtek or cat forwarder?  They're virtually the same cab set up as a skidder.   Just buy a forwarder and take the crane off.   Ive a fabtek I'd sell you.  Then the height will be the same or lower than a skidder.    One of our ponsse forwarders used to be a spray rig.
Offline Maine logger88
  • Don't force it get a bigger hammer
Re: Timberjack 1010
« Reply #8 on: November 21, 2017, 09:42:16 PM »
1270 wasn't the 546 fabtec a 540g deer front half?
Offline Airgrower
Re: Timberjack 1010
« Reply #9 on: November 21, 2017, 09:45:07 PM »
When one machine will cover up to 150 acres per day it isn't uncommon to move several times. We do small 10 acre tracts and tracts up to 1000 acres. The fabtek concerns me about parts. The cat 564 looks the size of what would work. Both options exceed the $15k forwarder back end. The price is a moot point if I can't figure out matching gear ratios.
Offline mike_belben
  • Pulp Friction
Re: Timberjack 1010
« Reply #10 on: November 21, 2017, 11:17:26 PM »
Could a 6x6 military truck do the job?  With AG tires perhaps?
Revelation 3:20
Offline Neilo
Re: Timberjack 1010
« Reply #11 on: November 22, 2017, 05:03:37 AM »
Won't the weight distribution be different on a skidder front frame? So on a forwarder, the load might make it fall over in corners.
Offline 1270d
Re: Timberjack 1010
« Reply #12 on: November 22, 2017, 05:20:40 AM »
It would be interesting to have an occilating center section paired up with a movable front axle like a skidder has.   I think it would just tip over
Offline teakwood
  • Switzerland
Re: Timberjack 1010
« Reply #13 on: November 22, 2017, 07:30:45 AM »
X2 on that thought!
Offline Airgrower
Re: Timberjack 1010
« Reply #14 on: November 22, 2017, 08:07:35 AM »
I'm afraid a military truck wouldn't hold up. It would be difficult to turn around at the end of the rows.  Unless you put a bogie up front I don't think you can have a single axle oscillating and a center section oscillating.
Offline mike_belben
  • Pulp Friction
Re: Timberjack 1010
« Reply #15 on: November 22, 2017, 12:55:46 PM »
Cut two mil trucks in half and put a center articulation joint. The differential chunks are flippable so rotation doesnt matter.  Tires are cheap and have very high load rating.  I cant think of what else wouldnt last one them.
Drive it from job to job.  8)
Revelation 3:20
Offline Airgrower
Re: Timberjack 1010
« Reply #16 on: November 22, 2017, 03:35:18 PM »
If the image came through this is one of the units I built. It will easily walk on any ground we need to without harming pine tree roots or rutting. We just couldnít keep the tracks  on it.
Offline mike_belben
  • Pulp Friction
Re: Timberjack 1010
« Reply #17 on: November 22, 2017, 08:03:56 PM »
Niiice.   Whatd you source the tracks from?
Revelation 3:20
Offline Airgrower
Re: Timberjack 1010
« Reply #18 on: November 22, 2017, 08:09:18 PM »
The machine is a prinoth Panther t8.
Online Skeans1
Re: Timberjack 1010
« Reply #19 on: November 28, 2017, 06:59:37 AM »
I run older Fabtek stuff and one nice thing is all parts are off the shelf so they're easy to come by, but for application wouldn't an 8 wheel forwarder tracked up do better? Most of the time hauling our we use a non ground bearing trailer and without the stake extensions we're under 13'.
TimberJack 1010 forwarder
Started by ehp on Forestry and Logging
Last post January 03, 2016, 08:48:50 AM
by supertrucker
timberjack or john deere 1010 or 1110
Started by logger444 on Wanted
Last post June 27, 2009, 10:11:40 AM
by logger444
JD 1010
Started by Kcwoodbutcher on Forestry and Logging
Last post August 09, 2007, 12:27:42 AM
by ibseeker
Timberjack 205---to buy?
Started by amberwood on Forestry and Logging
Last post April 23, 2007, 06:19:38 PM
by amberwood
