Arborwear
Author Topic: 548GIII  (Read 619 times)
Offline Nemologger
548GIII
« on: November 23, 2017, 08:13:55 PM »
On my 548GIII there is times when I start it and it will suddenly go to half throttle. If I shut it off and re start some times it will do it again or sometimes it will be ok. I think it has to do with the switch on the dash that is the throttle control . Is there a Selenoid or something that could be bad? It will only do this if the machine has sit a few days.
Clean and Sober
Offline OH logger
  • livin the dream
Re: 548GIII
« Reply #1 on: November 23, 2017, 09:19:54 PM »
I assume it revs higher than the preset warm up idle?? if so I think your on the right track thinkin about the throttle speed switch on the dash. that's where id start if mine did that. pull that fuse out if it has one (I think it does) and put it or a new one back in. that's about the extent of my electric fixing abilities!!  ;D
john
Offline Gearbox
Re: 548GIII
« Reply #2 on: November 23, 2017, 09:21:07 PM »
Could it be a low voltage thing ? Take a meter reading on each battery unhooked cold befor starting after sitting for a couple days . Newer stuff does not like low voltage .
Offline kiko
Re: 548GIII
« Reply #3 on: November 24, 2017, 12:26:34 AM »
I have little experienced with 548g3.    6 and 7 yes.  On all but the early g3s the foot feed has a potentiometer on it.   The rubber boot below the pedal will get a hole in it and let dirt collect down in there where the potentiometer is.   Could be hanging up or the potentiometer it self could be bad.  There were two styles of the electric foot feed if I recall correctly.
Offline Firewoodjoe
Re: 548GIII
« Reply #4 on: November 24, 2017, 06:09:49 AM »
I know on the 648s (boss has 3) that foot pedal control has been a common problem. But I've never had one rev up only not work when u push the pedal.
Offline finding the trail
Re: 548GIII
« Reply #5 on: November 29, 2017, 06:04:24 PM »
  It may be part of the warm up. My machines run at 1050 rpm's at startup after a minute or two they idle down. They have done this from day one.
My new to me 548gIII
Started by Nemologger on Forestry and Logging
Last post December 22, 2014, 06:41:01 PM
by wannaergo
Vent on 548gIII
Last post December 23, 2014, 10:13:45 AM
by Gadrock
