TURBOSAWMILL GIANT SALE ON NOW UNTIL OCTOBER 31st
Author Topic: New to me Clark skidder  (Read 8134 times)
Offline celliott
« on: November 26, 2017, 05:16:19 PM »
Well, I just bought a Clark 666c. Price was right, figured I couldn't go too wrong for a machine that runs good and pulls wood, I can always sell it and get my money back  :D
It's got a 4-53 detroit that fired up real good, a clark winch, 2 speed clark trans, 23.1x26 tires (pretty bald) and ring chains on all 4. The cradle pins are a bit loose, but not terrible. Arch needs some welding, someone got rowdy with the tree pusher  :laugh:
I'm intending to pull wood on the weekends with it as a side job. We'll see how it goes after running tubing and tapping trees on snowshoes all week.
Anyways, a few questions- Where do you add transmission fluid and hydraulic fluid? Straight weight oil for Detroit I've heard? (4-53) Regular transmission fluid?
I know, I know, you want pics. Smart ole me left my cellphone right in the truck and forgot all about it. I'll get some when I get it trucked home. It's gonna go to my boss's shop so I can take care of a few things before it hits the woods.
Chris Elliott
Clark 666C cable skidder
265rx clearing saw
Offline longtime lurker
Re: New to me Clark skidder
« Reply #1 on: November 26, 2017, 05:27:24 PM »
Straight weight oil for detroit and has to be compatible with detroit. 2 stroke diesel oil isnt like 4 stroke diesel oil - different additives.
Lift the foot plate hyd oil reservoir will be on the left hand side. Trans and convertor are integrated and have a cap right about under your right heel. Transmission and convertor are a hot check.
Offline celliott
« Reply #2 on: November 26, 2017, 07:30:07 PM »
Thanks lurker.
Any idea on width height and length? Width being most important... 23.1x26 tires. Shoulda measured when I looked at it... I know it weighs around 18k lbs
Chris Elliott
265rx clearing saw
Offline ScottAR
  • eat mo' ribs...
    • n/a
« Reply #3 on: November 26, 2017, 11:03:27 PM »
Delo 100 sae 40 matches the specs the closest.
Scott
[Magicman]
Offline treeslayer2003
« Reply #4 on: November 27, 2017, 08:13:55 PM »
Thanks lurker.
with 23s it should be a little over 8' wide
Offline celliott
« Reply #5 on: November 27, 2017, 09:26:12 PM »
Thanks for the info guys. Hopefully getting it trucked home this weekend, it's gonna be at my boss's place so I can tinker on it there before putting it into the woods, I'm sure I'll have lots of questions once I get into this thing.
Definitely first on the list is an oil change, would like to change the transmission fluid and filter as well, should I get into the rearends and change the gear oil out in those?
The front cradle pins are a bit sloppy, how hard of a job is that? I don't want them to egg out the parent metal, but not sure how bad they really are (and how they would hold up to just occasional use)
There's a seal leaking on the trans, not bad but it's something. Not sure which seal.
I'm just hoping I don't have any tire trouble. Two of them are pretty bald, there's 3 new tubes in them, the chains are pretty worn too (rings all 4) I just can't see buying new tires for weekend use. Someone told me ice chains might give a bit more protection for the tire, definitely more traction than worn out rings.
Chris Elliott
265rx clearing saw
Offline Maine logger88
  • Don't force it get a bigger hammer
« Reply #6 on: November 27, 2017, 09:57:31 PM »
My 540 with 23.1s is 9'2" wide not sure on a Clark but I would think it would be somewhere around that. I would definitely drain the rear ends and planetarys and put in fresh with a machine you just bought cause you don't know how long it's been. Ice chains are my preference but I know many who prefer rings
Offline celliott
« Reply #7 on: December 02, 2017, 03:44:59 PM »
Well it made it home this morning  8)
Chris Elliott
265rx clearing saw
Offline celliott
« Reply #8 on: December 02, 2017, 03:47:11 PM »
It says 666D but it's definitely a C by the serial number, don't know why someone painted the D on there.
Gonna get the arch welded, change the oil, trans fluid, diff oil, etc. soon, and take a close look at the front cradle pins and see if I should tackle those now or if it can stand to be put into the woods and done later. I'm more inclined to do it now as I have a shop I can work in.
I'm on the hunt for a set of used 23.1x26 ice chains. Maybe a tire too...
Chris Elliott
265rx clearing saw
Offline thecfarm
« Reply #9 on: December 02, 2017, 04:54:13 PM »
Good luck with it. Post some action pictures!!!!
Offline mike_belben
  • Pulp Friction
« Reply #10 on: December 02, 2017, 06:37:22 PM »
<--Jealous.
Revelation 3:20
Offline Puffergas
    • Puffergas
« Reply #11 on: December 02, 2017, 07:01:27 PM »
That's a keeper!
Somewhere 20 miles south of Lake Erie.
GEHL 5624 skid steer, IHC 300 Utility, Timberjack 225D, Burg Bandsaw mill, Steiger Bearcat II
« Reply #12 on: December 02, 2017, 07:25:02 PM »
Looks good! Also if it were a D it would have a 3 speed trans. There's a used set of double diamonds on maine cl
Offline celliott
« Reply #13 on: December 02, 2017, 07:39:34 PM »
Thanks Ill check the chains out.
It has a slot for work and travel but no lever. I assumed it was just removed years ago. Its fine, high and low are plenty
Chris Elliott
265rx clearing saw
« Reply #14 on: December 02, 2017, 09:03:35 PM »
The D series were 3 work speeds. Every Clark I have ran has had the work travel unhooked as well. I was told they were dangerous in travel cause they went way faster than you wanna go with stick steer. Those b and c series with a 2 speed are a simple tough machine!
Offline celliott
« Reply #15 on: December 03, 2017, 07:12:36 AM »
So Delo 100 straight weight for oil, dexron for atf, regular 80-90 for the rear ends? Anything Im missing?
Totally green to owning equipment. Been around it plenty, ran a few skidders but this is my first machine. I want to take care of it and avoid or at least help prevent expensive repairs.
Chris Elliott
265rx clearing saw
Offline mike_belben
  • Pulp Friction
« Reply #16 on: December 03, 2017, 07:35:12 AM »
Dont forget a 55gal drum of Good Luck!   ;D
Revelation 3:20
Offline Stephen Alford
« Reply #17 on: December 03, 2017, 08:56:10 AM »
  Very nice.. first glance at that tree pusher on the back would indicate she may have pushed more than she pulled.. ;D   Couple things that you may want to add to your list ..install block heater they are cheap and with a little bend on the element an easy install. This would give you a chance to change out the antifreeze and add a bit of that conditioner. Change the air filter and check air kill on intake to make sure its all good.  Power kill switch  and secondary back up kill switch; so it cannot be started by a stranger easily. 20 LB abc fire extinguisher. Keep an eye out for an ol school cable cutter. Suck out the fuel tank and check for debris . Not a big job but can save you hours of grief.   :)  Hope to see some action shots.  Good luck !
logon
Offline celliott
« Reply #18 on: December 03, 2017, 10:49:59 AM »
You're definitely right about the pusher  :D Someone pushed too hard trying to free a stuck saw was the story I got and it peeled the arch right off the frame. It's rebolted and welded with two pieces of plate, but the welds are coming undone. Gonna get it welded and it should be fine from here on out, I tend to cut using wedges, I don't anticipate pushing many trees with the arch.
Chris Elliott
265rx clearing saw
Offline celliott
« Reply #19 on: December 03, 2017, 01:59:18 PM »
So I'm doing some searching to find out what fluid to run in the trans and found a post saying to run straight weight engine oil in the trans? Doesn't seem right to me. It has ATF in it now, any specific type of ATF to get or stay away from?
Chris Elliott
265rx clearing saw
Will a 664c Clark Tranny fit a 664b clark ranger skidder?
Started by delimberboy on Forestry and Logging
Last post December 22, 2015, 01:23:05 PM
by oldseabee
thumbup
664 Clark skidder
Started by vatkins on Forestry and Logging
Last post March 26, 2017, 08:31:18 PM
by allaboutsawdust
Clark 664 Skidder
Started by nippy2010 on Forestry and Logging
Last post February 17, 2012, 08:16:29 AM
by oldseabee
Old Clark skidder
Started by country on For Sale
Last post January 23, 2016, 10:53:24 PM
by jmouton
