Author Topic: Chainsaw mill idea?  (Read 2110 times)
Offline GearDrive
Chainsaw mill idea?
« on: November 28, 2017, 11:55:37 AM »
I purchased a Stihl 084 and an Alaskan chainsaw mill.
I have an idea that I would like some opinions on.
I am thinking I can use barn door, square tube tracks, and “hang” the sawmill from them using the rollers that are designed for them. I would use 2 tracks, and 4 rollers on the mill. The ends of the tracks would be attached to  lifting devices to adjust depth of cuts.
I have seen chainsaw mills with the tracks on the ground, and believe that my idea would eliminate a lot of log lifting and maneuvering by positioning the mill over the top of the log where it sits.
Offline sawguy21
Re: Chainsaw mill idea?
« Reply #1 on: November 28, 2017, 12:31:10 PM »
It might work but imho would defeat the simplicity and portability of the mill not to mention the cost. Some band mills straddle the log, you might look there for ideas.
Offline Revival Sawmill
  • making sawdust.
« Reply #2 on: November 28, 2017, 12:48:12 PM »
Some of the swing-blade mills do too.  There's a British hydraulic bandmill that looks like the whole track that the carriage and saw head ride on move up and down above the log deck; I guess you have to put it all the way up and roll the logs in underneath...
Offline TKehl
  • Certified Contrarian
    • Kehlhof Ranch
« Reply #3 on: November 28, 2017, 01:08:50 PM »
Should work.  Would be like building a swing mill frame (kind of) to hang it on.
I could see pallet racking being useful with preset height adjustments built in.
Only concern with the barn track is getting sawdust in.  Overhead will keep most out, but what gets in will be harder to get out.  Not saying don't do it, but it may be worth looking at other wheels and angle iron for track.  I generally think of 3 out of every 2 problems that come up.   ;)
Offline PineHill4488
« Reply #4 on: November 28, 2017, 01:29:22 PM »
Fall 2013 purchased Stihl MS 660 and an Alaskan 36" mill, am happy with the setup, hobbyist not a volume producer, have milled oak, hickory, yellow pine, and power poles.
Offline GearDrive
« Reply #5 on: November 28, 2017, 02:09:54 PM »
http://turbosawmill.com/
This is similar to what I envisioned.
Offline GearDrive
« Reply #6 on: November 29, 2017, 09:18:25 AM »
I have actually started this a couple weeks ago. Most of the materials used are scrap from my work.
Offline GearDrive
« Reply #7 on: May 07, 2018, 09:16:02 AM »
Offline mike_belben
  • Pulp Friction
« Reply #8 on: May 07, 2018, 09:29:07 AM »
Ball screws and barn door track.. How could it not work!
;D
Looks like that settles it.
Revelation 3:20
Offline barbender
« Reply #9 on: May 07, 2018, 09:43:07 AM »
I like it!👍👍
Offline ToddsPoint
  • Stockmaker and Carver
« Reply #10 on: May 08, 2018, 05:25:35 AM »
Logosol M7.  Gary
Logosol M7, Stihl 660 and 290, Kubota L3901.
Offline mike_belben
  • Pulp Friction
« Reply #11 on: May 08, 2018, 07:35:26 AM »
I spy a jacobsen.  :)
Revelation 3:20
Offline Southside logger
« Reply #12 on: May 08, 2018, 08:54:54 AM »
Looks like you made a Saguaro.  8)
Offline SawyerTed
  • Summey Lumber Services, LLC
« Reply #13 on: May 16, 2018, 04:01:35 PM »
You people have mad design and fabrication skills!  My hat is off to you both!  The original post was just bait to show you've already done it! :D
The log furniture multi-tool is awesome!  That is something I believe you could market!  I want one!
Woodmizer LT35HD25, Kubota MX5100, IH McCormick Farmall 140, Granberg Alaskan Chainsaw Mill, Husqvarna 372XP, Husqvarna 455 Rancher
Offline GearDrive
« Reply #14 on: May 30, 2018, 09:31:21 AM »
Walnut countertable.
Crazy chainsaw tachometer idea.
Started by Dave Shepard on Chainsaws
Last post November 09, 2008, 04:57:51 PM
by Cut4fun
Up and down mill idea
Started by moodnacreek on Sawmills and Milling
Last post March 12, 2017, 11:32:49 AM
by reedco
The best idea I had for the mill
Started by lyle niemi on Sawmills and Milling
Last post March 02, 2013, 09:27:59 AM
by DaleK
Bad idea: Hitting the mill with a trailer
Started by SawyerBrown on Sawmills and Milling
Last post March 18, 2014, 09:22:40 AM
by drobertson
