Author Topic: Fix the LTAGA Sharpener or Buy a New CBN Sharpener?  (Read 641 times)
Offline Mountain_d
« on: November 28, 2017, 12:46:14 PM »
I have been in the FF for a while now, but over in the Logging and Chainsaw forms.  I just purchased a new-to-me LT40HD (1995) and find this Sawmilling form very interesting!  A LTAGA sharpener came with the mill, but the previous owner said the auto-sharp control box is non functional.  Woodmizer gave me a replacement price for the box at $400 plus (Canadian).  Those of you that have sharpening experience, if you were me, would you fix the LTAGA or take the $400 and put it towards a new CBN sharpener?  If you think CBN is the way to go, would you get the BMST50 (manual) at $1800 Canadian or the BMS250 (automatic) at $2700 Canadian?  At this point I am mostly sawing for myself and would likely sharpen about 50 blades a year.  In a few years I plan to do some custom work.  I would be ok with the slower rate of sharpening the BMST50, but am curious if there is much difference in the quality of sharpening between the manual and automatic CBN sharpeners?  Are there other companies make sharpeners?  I see Cooks do, but I think they are not CBN wheels?  One more angle, I may be able to get a retired instrumentation tech to check the board for me, but I cannot find a schematic for the printed circuit board.  Woodmizer does not have it.  Anyone out there every repair the printed circuit board on the auto-sharp control box?  Maybe a resistor or something is bad and can be soldered in by someone with those talents - not me that is for sure!
Thanks and looking forward to hearing back.
Mountain D
1978 TJ 230E 3.9L Cummins 4B, Husky 372XP, Husky 61, Husky 266XP, JRed 625, Husky 265RX clearing saw,  Woodmizer LT40HD 1995, Kubota 4950DT (53hp 4WD), Wallenstein V90 Skidding Winch, John Deere 610 backhoe, 1995 Volvo White GMC WCA42T SA Dump Truck, 2004 Ford F-250SD 4WD, , Central Boiler OW
Offline starmac
Re: Fix the LTAGA Sharpener or Buy a New CBN Sharpener?
« Reply #1 on: November 28, 2017, 02:31:49 PM »
I have been looking at those sharpeners, and if I understand it right, the manual is a combo, it comes with a setter, and the auto does not.
I have not heard any differences in the quality of their performance, but have no first hand experience.
Offline YellowHammer
  • Take Steps to Save Steps
    • Hobby Hardwood Alabama
« Reply #2 on: November 28, 2017, 10:48:56 PM »
I've had a drag sharpener and now have a BMS250.  It's a fine machine, I wish I had bought it first.
HobbyHardwoodAlabama.com
Offline LeeB
« Reply #3 on: November 29, 2017, 03:08:55 AM »
For only 50 blades a year you may be better served to use a resharp service. That said, if you have a sharpener you will likely find that you sharpen more often and get better cuts. I can't speak to the CBN sharpener, don't have one. I do have an old LTAGA that I no longer use since getting a Cooks that came along with my mill when I bought it used several years ago.
Offline Peter Drouin
    • A&P Saw mill LLC
« Reply #4 on: November 29, 2017, 05:36:04 AM »
CBN in an oil bath is the way to go. Or Wood Mizer resharp.
A&P saw Mill LLC.
License NH softwood grader.
LTAGA Sharpener question(s)
Started by KirkD on Sawmills and Milling
Last post April 20, 2018, 07:09:15 AM
by ladylake
WM pro series sharpener and Cooks sharpener with pics.
Started by customsawyer on Sawmills and Milling
Last post May 29, 2012, 08:45:10 PM
by Chuck White
sharpener help
Started by LeeB on Sawmills and Milling
Last post November 18, 2003, 08:00:41 AM
by LeeB
New Sharpener...
Started by boman1 on Sawmills and Milling
Last post October 10, 2010, 01:23:31 PM
by boman1
