Author Topic: Buick-Powered Sawmills  (Read 3903 times)
Offline jwade
Re: Buick-Powered Sawmills
« Reply #20 on: December 04, 2017, 05:38:40 PM »
wow all that would be a real barn find.
Offline Darrel
  • Never throw an unopened log on the burn pile.
« Reply #21 on: December 04, 2017, 11:48:59 PM »
I remember riding in a Pontiac as a vary young boy and my mother complaining that it burned too much gas. It was probably about the same age as the Buick pictured by kbietz. I don't know for sure that it had the straight 8 but I'm guessing that it did.
1992 LT40HD
Offline bandmiller2
« Reply #22 on: December 05, 2017, 08:39:05 AM »
If you really want gasoline engine torque find an old Walkeshaw (sp) 6 cylinder they were common in fire apparatus and some in old cranes and shovels. They are torky but will eat you out of house and home. Frank C.
Offline slanted6
« Reply #23 on: December 05, 2017, 07:46:12 PM »
My dads first saw mill was a circle mill powered by a straight 8 Buick.  Had a 3 speed transmission behind it that was wired to stay in first gear. Shaft off the transmission had a flat belt pulley on it.  Had a governor on it which we could not get to work so dad ran a cable from the engine to a pedal below the stick.  Sawed many a load of ties and pallet lumber on the old mill, all with the straight 8 powering it.  Only problem I remember was when an ant clogged the carb.  Shame we didn't have a video camera to record it at work.
Offline Resonator
  • Board Footage and Cord Woodage
« Reply #24 on: December 05, 2017, 08:10:56 PM »
Spelled Waukesha, not Walkeshaw. Named after the city in Wisconsin. (Sorry, had to correct that bandmiller, I'm a cheesehead).  :)
Card carrying Wood-Mizer owner - 2017 LT28G19
Kubota MX5800 4WD HST, '07 Dodge Ram 2500 4WD 5.7 Hemi with 8'-2" Boss V-XT plow, a couple of Stihl chainsaws,
18 acres of trees, 7 guitars, and Class A CDL licence with about a million miles in a semi truck.
"Chasing the sawdust dream..."
Offline bandmiller2
« Reply #25 on: December 05, 2017, 08:59:46 PM »
No offence taken mate, I was just too lazy to look it up. Today there are really no big gasoline engines today. I had a 1959 White dump truck with a flathead gas engine that would have done yeomen duty on a mill but I was too cheap to feed it. Frank C.
Offline ArkansasRick
« Reply #26 on: December 05, 2017, 10:15:58 PM »
Ran my 54" circle mill with an inline 292 Chevy engine for a year or so. Found a 2 stroke turbo charged 471 Detroit and never regretted the change.
Rick
Offline Al_Smith
« Reply #27 on: December 06, 2017, 05:08:29 AM »
In the little podunk town of Harrod Ohio I grew up in the local hardwood mill originally used a big Allis-Chalmers in line 4 cylinder power unit .It was not a tractor engine ,much larger .That thing would really roar  going through a big oak log .It was later replaced with a 75 HP three phase electric motor .
Chevy 292 and Ford 300's were hardy engines used in a lot of power applications also Ford 429 V8's .
Offline Al_Smith
« Reply #28 on: December 06, 2017, 05:13:24 AM »
The most odd mill I ever saw was in Roundhead Ohio .It used a D2 Caterpillar belted up .That crawler had never left that mill until the mill was  scrapped out,never pulled a plow just used for power .The tracks etc looked brand new .Sadly the guy who  bought the crawler let it sit in a woods to rust up .Might still be there as far as I know .
Offline Crusarius
  • Lost in....
    • RockModified.com
« Reply #29 on: December 06, 2017, 07:46:24 AM »
I have a couple straight 6's out of jeeps that I bet would make great sawmill power plants. I think they are both 258's but they are torque monsters. If I was going to setup a stationary setup it may be worth using. Right now they are just sitting. anyone want them? :)
I knew what I thought I meant.
Offline moodnacreek
  • Sawin by the notches
« Reply #30 on: December 06, 2017, 01:07:44 PM »
Any body run a v6 gmc  [gas] from the sixties ?
Offline wascator
« Reply #31 on: December 06, 2017, 03:04:46 PM »
GMC in the '60s had a V-12 as well. All were truck engines so probably were torque monsters.
Offline Al_Smith
« Reply #32 on: December 06, 2017, 04:24:36 PM »
They called that V12 gasser a twin 6 .That monster was 702 cubic inches .Must have had pistons the size of a coffee can . :D
Offline Al_Smith
« Reply #33 on: December 06, 2017, 04:30:47 PM »
GMC also had a 503 in line 6 .It was used on fire trucks among other things .It was claimed to have more low end torque than a 427 V8 .Those huge gasoline engines fell out of grace with diesels .You couldn't afford to run those big gassers today .
Offline Kbeitz
  • Never enough time...
    • My Hobbies
« Reply #34 on: December 06, 2017, 05:03:50 PM »
This rod had TWO 12 cylinders engines in it...
Love machine shop work
and Wood work shop work
And now a saw mill work
Offline starmac
« Reply #35 on: December 06, 2017, 05:25:47 PM »
I do not recall ever seeing the v 12 gas rigs in a truck, I have seen them on wells. The logger I haul for still has a buzzin dozen in a log truck. The thing is hard to feed though.
Offline Darrel
« Reply #36 on: December 06, 2017, 09:38:42 PM »
My 1971 Jeep CJ5 has a v6 made my GM.  225 CI odd fire.  That thing has a 32 lb. flywheel and tons of low end torque.  It would make a lousy sawmill engine though because by time you get the rpm up to where the horse power is, the torque drops way off.
1992 LT40HD
Offline Al_Smith
« Reply #37 on: December 06, 2017, 10:31:35 PM »
The V6 GMC's came out early 60's under the idea they had the low end torque of an inline 6 with the RPMs of a V8 .They didn't .They had big bearings and lots of torque but not like an inline .They certainly liked gasoline though .You have to remember the time period .
Offline Don_Papenburg
  • I need money
« Reply #38 on: December 06, 2017, 11:02:50 PM »
I have a 401 magnum with just over 500 miles on a complete overhaul . it is in a cabover jimmy with a sandblasting rig on the back .  And a half tank of ga...varnish now .
Kb I like your old Buick , I bought a 37Pontiac that was black . One day I took it to the carwash droped in my quarter and started spraying . all of a sudden something big and black flew through the air .  About 20 quarters later I drove away with a tan Pontiac.
Offline moodnacreek
« Reply #39 on: December 08, 2017, 05:36:10 PM »
D.P.  An820 diesel on the sawmill; I'm jealous.
Any Buick Mechanic's ?
Started by bama20a on General Board
Last post July 30, 2015, 05:29:41 AM
by jcbrotz
Diesel powered MD????
Started by karl on Sawmills and Milling
Last post February 05, 2006, 11:15:38 AM
by DanG
Powered Polesaws
Started by jokers on Chainsaws
Last post January 10, 2002, 08:50:16 AM
by swampwhiteoak
Stihl 880 under powered
Started by Ivestertree on Chainsaws
Last post September 30, 2014, 11:24:44 PM
by sawguy21
