Author Topic: Advice on Chainsaw Mill  (Read 516 times)
Offline HRTULL
  • Member*
« on: November 30, 2017, 05:09:13 PM »
I have several 20 to 24 inch walnut , ash and white oak 10 to 12 feet in length.  I want to mill some of this for personal use and cant justify a bandsaw mill. Would like to mill at about 2 1/4 x 6 and stack dry. For under $700 I can purchase a MS 070 from Huztl with a 36 inch bar as well as their 36 inch chainsaw mill and buy  well known brand rip chains from another source. Just wanting to mill about a dozen logs and am in no great rush doing it and when finished have a big saw to keep. From watching many  youtubes it seems do able but also looks like it could be punishing. Would greatly appreciate some insight, advice on this subject. Thanks  HR Tull    OHIO
Offline Kbeitz
  • Never enough time...
    • My Hobbies
Re: Advice on Chainsaw Mill
« Reply #1 on: November 30, 2017, 05:21:10 PM »
I don't want to discourage anyone but have you ever tried chainsawing
wood against the grain ? It's tough...
Love machine shop work
and Wood work shop work
And now a saw mill work
Offline Klicker
    • www.freespiritfarm.ca
« Reply #2 on: November 30, 2017, 05:48:50 PM »
Have you checked for a local  sawer to mill it. It might be cheaper and  give better wood and more wood. But I have my own mill and have thought about getting a chainsaw mill for the ones that don't fit my mill. Rod
2006 LT 40 HD
Offline TKehl
  • Certified Contrarian
    • Kehlhof Ranch
« Reply #3 on: November 30, 2017, 06:06:52 PM »
Don't forget the Gatorade and extra strenght Asprin.   ;D
Offline Flyingpig
« Reply #4 on: December 05, 2017, 10:01:51 PM »
Chainsaw milling can be a lot of fun, sometimes frustrating and always hot, hard work. I've done a fair bit of it in the last two years. You will want at least a 100cc saw if you can get one. I run 2100 Husqvarna saws on my Alaskan. I gave a 36" bar and a custom built mill that allows for a 34" cut width with my dogs removed. As stated above, rip cutting is a tough go, especially with a standard grind. I run a lot more hook(like 45*), a 0* top plate angle and my rakers at 0.045". With the 2100 it basically self feeds with those numbers. If you only have a few hundred board feet to do I say go for it. But get into your set up as cheaply as you can, and get a good straight guide board at least a foot longer than your longest cut on each end.
Enjoy!
Need Advice Concerning the Alaskan Chainsaw Mill
Started by vcbotto on Sawmills and Milling
Last post February 06, 2017, 11:24:43 PM
by Brucer
Cheap first chainsaw mill advice
Started by WoodworkerIA on Sawmills and Milling
Last post April 06, 2018, 01:42:48 PM
by RPF2509
question
advice - chainsaw mill for ~36"+ doug fir, currently have stihl ms 290
Started by kgreene on Sawmills and Milling
Last post January 19, 2014, 04:31:58 PM
by mad murdock
question
Request Chainsaw , bar and chain advice for a Logosol Big mill
Started by woodlearner on Sawmills and Milling
Last post April 01, 2013, 11:05:57 PM
by piller
