Arborwear
Author Topic: Winches broken  (Read 577 times)
Offline ga jones
Winches broken
« on: November 30, 2017, 07:29:01 PM »
What are the chances of having 3 skidders with 3 broken winches at the same time??
  by the way you cannot buy a new ring and pinion for gearmatic 19-119. No one makes it....
380c timberjack c4 treefarmer international trucks jonsered saws. Sugi hara bars d31 komatsu 350 tj grapple
Offline pdxh20
  • small woodlot owner
    • American painting
Re: Winches broken
« Reply #1 on: November 30, 2017, 07:38:31 PM »
Try Northwest Tractor in Boring OR: http://www.nwtractorparts.com/  or Nor Can in Spokane: http://www.norcan-parts.com/default.htm Either one might have used or surplus or know where to get 'em...
'56 American crawler crane, Komatsu mini-ex, multiple Stihl saws, '75 IH S-8 cable skidder, 2000 F450 30' bucket truck, '95 Chev 4 x 4 2500 p/u, '05 Sprinter SHC 2500 van
Offline ga jones
Re: Winches broken
« Reply #2 on: December 01, 2017, 11:46:14 PM »
I bought used from golden rule here local. The bitch about it is the ring gear is riveted on the main shaft. No one rivets anymore and there is nothing available aftermarket so you have to change the whole shaft. The shaft is the whole problem to begin with. The stupid setup with the bearings sandwiched together and 20 different shims in 1 thousandth incriminates. You cant get them just right it wears the shaft and you have to get the bearing surface spray welded and re machined.the worst engineering Ive ever seen.
Offline ga jones
Re: Winches broken
« Reply #3 on: December 01, 2017, 11:49:43 PM »
Oh yeah and you have to completely disassemble the entire winch to change the ring and pinion. 😤 its no wonder Paccar scrapped it.  I got it all done works better than new. It
Offline Skeans1
Re: Winches broken
« Reply #4 on: December 02, 2017, 12:04:33 AM »
Another one to add to the list would be Fraley tractor in Wenatchee.
Offline celliott
Re: Winches broken
« Reply #5 on: December 02, 2017, 05:01:07 AM »
Boy, this is why I didnt want a Skidder with a gearmatic. I want to just pull wood on weekends occasional use. Didnt want to work on a winch all the time, so I wasnt too keen on a gearmatic.... glad I have a big Clark winch
Chris Elliott
Clark 666C cable skidder
265rx clearing saw
Offline ga jones
Re: Winches broken
« Reply #6 on: December 02, 2017, 09:20:25 AM »
Ive always heard good things about the Clark. Never had the opportunity to run one or work on one.
Offline coxy
Re: Winches broken
« Reply #7 on: December 02, 2017, 05:14:44 PM »
need another clark winch  :)
Offline celliott
Re: Winches broken
« Reply #8 on: December 03, 2017, 07:14:24 AM »
Nope mine works fine  ;D
Chris Elliott
265rx clearing saw
question
winches
Started by cando on Forestry and Logging
Last post January 30, 2010, 02:22:30 PM
by Ed_K
question
Winches??
Started by willmyers0169 on Sawmills and Milling
Last post July 11, 2015, 04:49:34 PM
by 5quarter
Winches
Started by Paddy on Forestry and Logging
Last post October 14, 2013, 10:17:22 AM
by Paddy
Winches
Started by Keltic on Forestry and Logging
Last post November 28, 2003, 02:47:35 PM
by rebocardo
