Arborwear
Author Topic: Another TJ project  (Read 778 times)
Offline Upnorth
Another TJ project
« on: December 02, 2017, 04:49:19 PM »
Started a project in the garage a while back. Finally got it outside today. It came a long ways from the day it showed up on the float.
I do need a turbocharger for it if anyone has one for sale - Detroit 353T.
TJ 205
TJ 240E
TJ 350A x 2
TJ 230D x 2
Offline mike_belben
  • Pulp Friction
Re: Another TJ project
« Reply #1 on: December 02, 2017, 06:40:36 PM »
How handy is that blade grapple?
Revelation 3:20
Offline Puffergas
    • Puffergas
« Reply #2 on: December 02, 2017, 06:59:16 PM »
Wow! Nice!
Somewhere 20 miles south of Lake Erie.
GEHL 5624 skid steer, IHC 300 Utility, Timberjack 225D, Burg Bandsaw mill, Steiger Bearcat II
Offline lopet
  • Do not climb any higher your comportable falling !
« Reply #3 on: December 02, 2017, 07:05:51 PM »
Nice paint job, ex hydro bucket unit ?
Offline bushmechanic
  • Someone else has it worse than you.
« Reply #4 on: December 02, 2017, 09:31:45 PM »
Nice old machine, I see it has the bullet proof planetary wheel ends too. Good luck with it.
Offline Logger RK
« Reply #5 on: December 05, 2017, 08:21:31 AM »
Nice looking machine. I also am looking for a turbo charger for a 353T. Have you had the valve cover off of it? If so is there a plugger type device on yours? We a a few 353N's,but this is the first Turbo. We're putting it in a Hahn Harvester. Wondering what it is? Low oil pressure shut down? Also the blower is different. My Son Phil looked that up,and it sounds like that's a fuel saving feature?
Offline Upnorth
« Reply #6 on: December 05, 2017, 08:33:44 AM »
Fortunately I haven't had to take the valve cover off, not sure what that plunger you described would be for without seeing it. This engine is actually very tight and clean, once the turbo is bolted on it will be ready to go to work.
TJ 205
TJ 240E
TJ 350A x 2
TJ 230D x 2
Offline Upnorth
« Reply #7 on: December 05, 2017, 08:37:47 AM »
Thanks Lopet,
No not a bucket unit, but it does have a fuel tank and pump mounted between the fenders. It's purpose for many years prior was as a fuel buggy to deliver fuel to the bunchers. I bought it after it had sat for a while. It's actually in great shape all around. I guess delivering fuel is easier on it than pulling wood all day.
TJ 205
TJ 240E
TJ 350A x 2
TJ 230D x 2
Offline lopet
« Reply #8 on: December 05, 2017, 06:44:30 PM »
Good for you, so what's with that frame on top of the hood ?  Looked liked a crane resting on it to me, obviously I am wrong.
With all the blade winch and arch setup, don't you think it was a skidder in it's first live ?
Offline Upnorth
« Reply #9 on: December 06, 2017, 08:05:30 AM »
Yes it is set up as a cable skidder as well, always had been. The fuel tank is small enough that it can still pull wood without it getting in the way too bad. The frame built over the engine area is to protect it from falling trees I suppose. Seen lots of similar setups around here.
TJ 205
TJ 240E
TJ 350A x 2
TJ 230D x 2
New project
Started by samdland on Sawmills and Milling
Last post July 31, 2005, 02:25:48 PM
by Timburr
230 D Project
Started by larry1 on Forestry and Logging
Last post August 04, 2015, 08:46:02 PM
by logman81
My Next Project
Started by Burlkraft on General Woodworking
Last post January 19, 2010, 10:26:46 AM
by BcWoodWorks
A little project
Started by Crow99 on Chainsaws
Last post May 14, 2014, 09:28:48 PM
by Crow99
