KNOW WHAT?
Between February 12, 2018 and June 18, 2018, this space displayed 13 Million, 871 Thousand and 87 times.
Author Topic: My Timber Frame Home  (Read 4756 times)
Offline flyingparks
  • If my dog doesn't like you, I don't like you.
Re: My Timber Frame Home
« Reply #20 on: February 01, 2018, 09:40:21 PM »
What is the R value of your roof SIPS? I like your build!
R24 in the walls. R49 in the roof
Offline Jim1611
« Reply #21 on: February 02, 2018, 05:18:14 PM »
I'm really looking forward to seeing your progress!!
"Let every man be swift to hear, slow to speak, slow to wrath."
Offline flyingparks
« Reply #22 on: February 03, 2018, 09:59:55 PM »
Here's a bit of an update: SIPs on, windows in, doors in. Plumbing, electrical ready for rough inspection. I decked the second story in 1 1/2" Doug Fir T&G. I am very happy with the way it looks as a ceiling for the downstairs. I'm pouring 1.5" of lightweight concrete on the first and second floor. After its sealed this will be my finished floor.
Offline Brad_bb
    • My timberframe blog
« Reply #23 on: February 04, 2018, 09:32:24 AM »
How dry was your DF T&G?  I had an issue with some I got from out west, pre finished it, it had been out in my shed in ambient conditions for awhile.  Installed it and over the winter it shrank and I have some gaps to deal with.  I should have let it acclimate in heated conditions for a couple months first.
Offline flyingparks
« Reply #24 on: February 04, 2018, 10:35:02 AM »
It averaged 8%, but I was only checking end grain. This particular batch had been sitting in the local lumberyard for a few months so it acclimated enough I hope. Colorado is extremely dry, and my experience is that it really doesn't take too long for lumber to acclimate, especially 6 quarter lumber. But I guess we'll see!
Offline Don P
    • Calculator Index
« Reply #25 on: February 04, 2018, 10:42:35 AM »
I have run into that here Brad. We'll get KD15% delivered for those kind of materials but the house can bottom out at ~8%emc in winter. If at all possible I like to go through at least some of the heating season on sticks before applying.
Offline flyingparks
« Reply #26 on: February 22, 2018, 09:24:28 PM »
Need to build some stairs. Any thoughts / opinions on this? I created this in sketchup. It complies with codes. Treads are 2". Risers are 1/2". Two stringers. 3 feet apart. I guess my main question is if 2" treads are enough to span 36" Material is Doug fir.
And since we like photos, here are a few of the radiant floor heating.
Offline fishfighter
« Reply #27 on: February 22, 2018, 09:52:40 PM »
Looks real nice. Sure glade we don't need that here in the south. Hit a high of 89F today.
Offline flyingparks
« Reply #28 on: February 22, 2018, 10:00:09 PM »
Thanks. 12 degrees today and sunny.
Offline jason.weir
« Reply #29 on: February 22, 2018, 10:34:31 PM »
I'd be surprised if code doesn't require a middle stringer, even if it doesn't I'd certainly add it - maybe it's overkill but it's cheap easy overkill.
Offline flyingparks
« Reply #30 on: March 10, 2018, 04:25:35 PM »
Floor heat in. Rough inspections done. I poured lightweight concrete upstairs and downstairs. This creates a thermal mass which increases efficiency for in floor hydronic heat. It' s a fairly complex system by my standards, but I think will be worth it. It's a 1400 square foot home and there are 12 zones in the heating system. If you don't make enough zones, radiant floor heating can get ugly quick. Some DIY friends of mine have a bathroom that is too hot to walk in when the heat is turned up during cold days. Anyway, I really like the look and simplicity of raw materials and I love the way the concrete looks with the timbers.
Offline flyingparks
« Reply #31 on: March 21, 2018, 08:01:35 AM »
A friend's place. Helped him with some raising.  Beautiful day and a beautiful frame. Grove crane sure helps. I think the crane could lift the entire frame.
Offline flyingparks
« Reply #32 on: April 12, 2018, 08:34:42 PM »
Finally moving again. Sheet rock and paint. Also, put some more tung oil on while I had scaffolding up
Offline flyingparks
« Reply #33 on: April 12, 2018, 10:32:20 PM »
After the house is done, I'll get a better camera.
Offline NorcalMatt
« Reply #34 on: April 13, 2018, 10:39:58 AM »
Great job!  You will be enjoying all this work for decades to come
Offline flyingparks
« Reply #35 on: May 13, 2018, 05:32:30 PM »
Here's a little update. I cut down a nice straight fir tree and milled it up for stair parts. It was amazing how fast everything dried.
I planed everything last week and cut to rough size. They turned out really beautiful. Now I can show my grandpa why I didn't just go to the lumber yard (he asked why  :D).
I hooked up the boiler just in time for summer. It's been really cold in the house and the season changed the day I installed this boiler. It's an all in one unit. It supplies the hydronic floor heat and the domestic hot water. It even has connections for solar thermal which is further, a lot further down the line.
I had a random foot of snow and some little moose stopped by. The snow was completely gone the following day.
I put in the wood stove but won't get to fire it until fall. Or maybe I'll sneak one in
The stucco crew has done their first coat. The color will ultimately be a light gray.
I had two windows break. It was determined there was a mistake at the factory and these windows were charged with argon gas...something you can't do at 8600 feet. Luckily the window company is taking care of everything.
A few electrical and plumbing odds and ends and I can think about moving in. The dog is ready for summer.
Offline samandothers
« Reply #36 on: May 15, 2018, 09:42:29 AM »
Thanks for the update!  Really looks good.
Offline TimFromNB
  • New guy here.
« Reply #37 on: May 15, 2018, 10:36:51 AM »
Looking good!
Log Home and Timber Frame Home Show in Springfield MA 11-18,19,20-05
Started by Jim_Rogers on Timber Framing/Log construction
Last post November 18, 2005, 08:39:31 AM
by Jim_Rogers
exclamation
Last post November 12, 2003, 03:54:14 PM
by Jim_Rogers
Started by Jim_Rogers on Shows, Events and Places to meet
Last post November 12, 2003, 03:55:37 PM
by Jim_Rogers
timber frame home
Started by logman on Timber Framing/Log construction
Last post October 27, 2003, 11:26:39 AM
by UNCLEBUCK
