Arborwear
Author Topic: Wood Mizer Power feed LT35 and LT40 new design  (Read 869 times)
Offline MartyParsons
  • Wood-Mizer Service and sales PA, VA, MD, WV others
« on: December 03, 2017, 09:24:40 PM »
Hello,
  There was a post about the power feed driven pulley coming loose. There has been a design change on all new mills and you can retro fit the earlier mills. Here is the picture.
This is a picture of the old shaft notice there is no nut on the larger pulley.
Wood Mizer recommends replacing the bearings.
Hope this helps. If you need the part # I can post them also.
Marty
A pessimist sees difficulty in every opportunity; an optimist sees opportunity in every difficulty. -Winston Churchill
Offline Chuck White
  • Sawing Mobile since 2005
Re: Wood Mizer Power feed LT35 and LT40 new design
« Reply #1 on: December 04, 2017, 08:09:50 AM »
More "good info" !
You're a good man for posting this kind of info!
Thanks Marty!
~Chuck~
I LOVE MY SAWMILL
Online Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #2 on: December 04, 2017, 08:25:25 AM »
Marty, you said retrofit for older sawmills.  Are you speaking of '98 models?
Offline WV Sawmiller
    • Green's Sawmill Services
« Reply #3 on: December 04, 2017, 08:30:37 AM »
Marty,
   How far back were the machines that had the older design you are talking about that needs/recommends replacing?
Offline Kbeitz
  • Never enough time...
    • My Hobbies
« Reply #4 on: December 04, 2017, 08:36:56 AM »
Don't worry Magicman... Your mill is so old that it's rusted on.
Your's will never fall off...  :D
Love machine shop work
and Wood work shop work
And now a saw mill work
Offline samandothers
« Reply #5 on: December 04, 2017, 10:24:13 AM »
Kbeitz, Glad I was not drinking something!
Offline pineywoods
« Reply #6 on: December 04, 2017, 10:36:26 AM »
good upgrade. I see a lot of those bearings go bad, go un-noticed and ruin the shaft. I have welded up a few shafts and turned them back to correct size. I think most of the failures are from running the drive chain way to tight.
Offline Chuck White
« Reply #7 on: December 04, 2017, 12:43:54 PM »
Piney;  If I remember, my book says allow 2" drop at the center of the drive chain when the sawhead is at either end of the mill!
~Chuck~
I LOVE MY SAWMILL
Online POSTON WIDEHEAD
  • Getting old but doing it with Friends.
« Reply #8 on: December 04, 2017, 06:44:25 PM »
You may have to call OMAR'S COVERED WAGON SALES AND PARTS.
Where's the Spoon?
Online Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #9 on: December 04, 2017, 09:52:03 PM »
I think that I am on my third assembly, but I ride it hard.
Offline Percy
  • Resident trouble maker
« Reply #10 on: December 04, 2017, 10:45:59 PM »
  I ride it hard.
Thats what my motorcycle said....
« Reply #11 on: December 05, 2017, 12:11:12 AM »
Hello,
 Magic you have a Super, they are different.
WV You may have direct drive power feed on the LT35? Early LT35 are direct drive with no belt. If it has a belt then you could replace the shaft with the new design. I would not change this unless you are having issues keeping the pulley tight.
Marty
Wood Mizer single blade edger power feed
Started by Luke_Eames on Sawmills and Milling
Last post July 04, 2016, 11:42:06 AM
by Luke_Eames
power feed on LT35
Started by MTMALONEY2 on Sawmills and Milling
Last post November 21, 2017, 12:52:53 AM
by MobileSawMilSlo
power feed LT40
Started by head block on Sawmills and Milling
Last post April 12, 2009, 04:51:36 PM
by head block
LT40 Power Feed Question
Started by Ga Mtn Man on Sawmills and Milling
Last post October 23, 2014, 08:23:25 AM
by Ga Mtn Man
