Arborwear
Author Topic: Blades  (Read 1023 times)
Offline Furrfactor
Blades
« on: December 05, 2017, 06:50:19 AM »
Good Morning. I use a Enercraft 30 full hydro and need to buy some blades. what is the best out there? I saw a lot different wood and want the most durable blade out there. I was raised on a circle saw and kind of new to the band style mill.
Offline Southside logger
  • Sawing so I can afford to farm.
Re: Blades
« Reply #1 on: December 05, 2017, 07:08:23 AM »
Welcome to the Forum.  I guess a couple of questions that would help to provide you with opinions to that questions are in order, and remember these are opinions.
What species a you looking to saw?
How many HP is your mill?
What is your market for your lumber?  IE - personal use, selling to a pallet shop, etc?
Personally I have gone to the Wood Mizer Turbo 7 as my go to band.  I don't know what it is about that design but my mill cuts better with those, less wavy cuts, no issues at all with hard knots and I find they keep a sharper edge longer.  I do have some others but this is what I buy as replacements these days.  Just curious, what part of Virginia are you in?
Jim
'92 Franklin 170 grapple skidder
'92 Franklin 5000 wheeled buncher
Wicked Awesome Basset Hound * 2
JD 490D with 4 roller FabTek processer / hydraulic hose breaker
Hot wife
Wood Mizer LT35HDG25, Re-saw attachment
Official Member of the BBFC
Offline Chuck White
  • Sawing Mobile since 2005
Re: Blades
« Reply #2 on: December 05, 2017, 07:20:32 AM »
Welcome to the Forestry Forum, Furrfactor!
~Chuck~
I LOVE MY SAWMILL
Offline Furrfactor
Re: Blades
« Reply #3 on: December 05, 2017, 10:44:39 AM »
Lake Gaston. Kinda center of Va but on southern Border to NC. We run a excavation company and used to sell all our logs. now days that's hard to impossible to do so I found a mill. 24 HP Silva Saw ( Ener craft)  Baker I guess bought out the orginal mill design. I repaired a lot of things but over all its a fun mill and very little labor. we sell some and use the rest for building rental cabins and other things. I'm also in re market for a edger if there may be one for sale.
Re: Blades
« Reply #4 on: December 05, 2017, 09:31:47 PM »
We are just up the road from you, basically on the edge of Ft Pickett.
Hot wife
Offline scsmith42
    • Whispering Pines Farm
Re: Blades
« Reply #5 on: December 07, 2017, 12:10:07 AM »
Im a couple of hours south of you. Weve been very pleased with the Kasco 7/40s on Tom (Baker 3638d).
Welcome to the FF!
Tom's 3638D Baker band mill
Re: Blades
« Reply #6 on: December 07, 2017, 07:42:40 PM »
scsmith,
Are those more or less the same as the WM Turbo 7 band?  I think it's a 7-39, but I really don't know what the 39 means.
Hot wife
Offline terrifictimbersllc
    • Terrific Timbers LLC
Re: Blades
« Reply #7 on: December 07, 2017, 07:46:03 PM »
7 is angle of face of tooth from vertical.
39 is angle of back of tooth from horizontal.
DJ Hoover, Terrific Timbers LLC,  Mystic CT   2001 WM LT40SHDD (42HP Kubota, Accuset2, FAO's, Lubemizer, debarker, hydraulics everywhere), Peterson WPF 10-30 with chain slabber. Logrite fetching arch, WM BMS250 sharpener/BMT250 setter.
Re: Blades
« Reply #8 on: December 07, 2017, 07:53:37 PM »
Thanks terrifictimber,
So if I understand you correctly a 7-40 would be just a tad bit thinner at the tooth than a 7-39?
Hot wife
Re: Blades
« Reply #9 on: December 07, 2017, 08:06:37 PM »
The back of the tooth would have a 40 degree angle from horizontal.  I guess if you measured the included angle between the back and face of the tooth it would be 1 degree less (more pointy) than a 7/39, if that's what you mean by thinner.
Offline JB Griffin
Re: Blades
« Reply #10 on: December 07, 2017, 08:10:11 PM »
The Kasco7/40 is like the WM turbo7, only better.
It has a slightly deeper gullet that is shaped a little different and 40deg back angle instead of 39.5deg. I believe that it cuts smoother and stays sharp much longer than the WM silvertip blades that they stick us 2" blade users with.
2000 LT40hyd remote 33hp Kubota, 160 Prentice, Frick 2 saw gang edger, Wright W-37 ABG, Suffolk dual tooth setter, Cat claw single tooth setter,'96 F-250 7.3 PSD 4x4, CS-590 Echo, MF 20c, M681 Memo.
1.8 million bdft sawn with a Baker Dominator and counting.
Offline Kbeitz
  • Never enough time...
    • My Hobbies
Re: Blades
« Reply #11 on: December 07, 2017, 08:31:47 PM »
Love machine shop work
and Wood work shop work
And now a saw mill work
Re: Blades
« Reply #12 on: December 08, 2017, 07:37:41 PM »
JB Griffin
How do the Kasco's compare with dust removal?  I am not all that impressed with the amount of dust left on the boards.
Hot wife
Offline JB Griffin
Re: Blades
« Reply #13 on: December 08, 2017, 07:40:48 PM »
Southside, they're about the same which don't bother me, all I want is flat and fast.
Re: Blades
« Reply #14 on: December 08, 2017, 07:45:45 PM »
Thanks,
Green wood does not bother me so much, but the reclaimed will come off the mill and head into the edger then planer and eventually the moulder so I am trying to get it as clean as possible.
Hot wife
question
Bandsaw Blades - Who sends sample blades to try out?
Started by Ozarkian on Sawmills and Milling
Last post April 01, 2012, 06:50:08 PM
by Magicman
question
Sharpening blades vs shipping blades
Started by Deese on Sawmills and Milling
Last post April 10, 2015, 07:39:09 AM
by Chuck White
Peterson Blades, vs Lucas Blades
Started by Nate Surveyor on Sawmills and Milling
Last post May 07, 2007, 12:26:56 AM
by Firebass
Band saw blades vs circle saw blades
Started by Arkyrick on Sawmills and Milling
Last post February 17, 2017, 07:55:52 AM
by longtime lurker
