Author Topic: Source for toe board rollers?  (Read 503 times)
Offline alan gage
« on: December 05, 2017, 04:12:30 PM »
Have found a ton of old posts about adding toe boards and rollers but haven't seen anyone mention a source. I can find rollers at Mcmaster Carr but the heaviest ones are rated at around 1000 pounds and are 3 1/2" in diameter. I'd think more capacity would be wanted.
https://www.mcmaster.com/#standard-rollers-for-conveyors/=1ak0yi8
What's everyone been using?
Alan
Timberking B-16
Offline Larry
Re: Source for toe board rollers?
« Reply #1 on: December 05, 2017, 04:27:22 PM »
Shop made out of heavy wall pipe, solid bar, or even wood.  They don't need bearings, crude bushings with a shot of grease work well.
Offline Crusarius
  • Lost in....
    • RockModified.com
« Reply #2 on: December 05, 2017, 04:31:14 PM »
drop from any steel place. solid bar stock then drill holes in the ends.
I knew what I thought I meant.
Offline pineywoods
« Reply #3 on: December 05, 2017, 09:06:26 PM »
I have added toe rollers to 3 different mills. 3 inch heavy wall pipe, 1/2 inch plate on the ends, 3/4 inch hole to take 3/4 steel axle. Look in my gallery for pics and dimensions...
Offline Kbeitz
  • Never enough time...
    • My Hobbies
« Reply #4 on: December 05, 2017, 09:22:44 PM »
I use heavy wall pipe and flange bearings .
Love machine shop work
and Wood work shop work
And now a saw mill work
Source for rebuilt/aftermarket feed rollers
Started by Northern Timber Harvesting on Forestry and Logging
Last post March 10, 2013, 03:43:42 PM
Toe Board Rollers
Started by red pine on Sawmills and Milling
Last post December 06, 2011, 08:57:06 AM
by Magicman
LT40 with board return & conveyor/powered rollers ?
Started by DGK on Sawmills and Milling
Last post June 15, 2017, 08:12:56 AM
by Magicman
blade rollers
Started by steve phillips on Sawmills and Milling
Last post February 07, 2012, 08:04:31 PM
by steve phillips
