Arborwear
Author Topic: Sothern Yellow Pine standing dead is it rotten?  (Read 1483 times)
Offline Georgia088
  • New to all things sawmill
« on: December 06, 2017, 08:09:21 AM »
I had a standing dead SYP that I cut down yesterday.  Not sure how long its been dead, possibly a year, but I would think no longer.  I was hoping to put it on my homemade mill to saw it up, but after cutting it, I am not sure if the lumber would be good.  Its about 20 inches in diameter at the bottom.  You can definitely tell that the core looks different once you get 8' 16' up the tree.  It looks like the core is solid, but the outside looks questionable.  Any way to check to see if its good?  Don't have many logs to saw so I hate to waste it, but don't want to have lumber that is no good.
Thanks!
Online WV Sawmiller
    • Green's Sawmill Services
Re: Sothern Yellow Pine standing dead is it rotten?
« Reply #1 on: December 06, 2017, 08:12:30 AM »
   I always found it easy enough to tell with a hatchet or ax. Just start chopping into the sapwood to determine how solid it is. I'd always expect the heart of a pine to be much denser and more solid than the sapwood. Good luck.
Offline Savannahdan
  • Retired.
« Reply #2 on: December 06, 2017, 08:21:04 AM »
Can you post some pictures of some of the lumber you've cut?  Others may be more familiar with what you might get with standing dead SYP.  Where are you in Georgia?  There might be a FF member close by that can look at it.  I see WV Sawmiller has responded while I was preparing my response.
Husqvarna 3120XP, Makita DCS7901 Chainsaw, 30" & 56" Granberg Chain Saw Mill, Logosol M8 Farmers Mill
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #3 on: December 06, 2017, 08:25:59 AM »
If it did not break when felled is a good sign that it is OK, but you still may have to slab heavy.  Bad wood also acts like a mini sponge and holds excess water.  Yes, chopping into it will determine if it is solid.  If a knife point goes much deeper than 1/8th" slab deeper.
Offline Georgia088
« Reply #4 on: December 06, 2017, 08:58:47 AM »
I will try and get some pictures up, but I haven't cut into it yet.  It did break when it was cut down.  However, where I cut the log to saw was several feet toward the base from where it broke.  Thanks!
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #5 on: December 06, 2017, 09:14:16 AM »
Some of it may be OK depending upon the use, but the tree breaking tells you that it is certainly not structurally strong.  I mostly saw framing lumber and normally do not saw logs from trees that break.  Wall paneling, etc. would be OK.
The loss will be great but slab heavy and get into the heartwood.
Offline Don P
    • Calculator Index
« Reply #6 on: December 06, 2017, 09:35:59 AM »
A quick way we check suspect old structural lumber is the "pick test". Take an ice pick, awl or I prefer one of those very tiny flat screwdrivers. Drive it under the wood and lift a flake. If it lifts a long fiber the wood is good. If it breaks over the pick, short and brash, it's decayed.
Offline drobertson
« Reply #7 on: December 06, 2017, 12:03:26 PM »
I've seen it both ways, mostly standing ones however are much more likely to be solid than ones that are laying.  Fact is I've sawn some standing dead pine that was pitch perfect,,and as well as I've seen logs that had really soft wood on portions it where as the opposite side was rock solid. Pretty much is a fall and buck to length, often times you can tell its integrity while cutting to length, all in all, its worth the effort most of the time,
Offline Den-Den
    • Dennis Wood Art
« Reply #8 on: December 06, 2017, 12:43:08 PM »
Good advice above.  My "rule of thumb" is it will be good if the bark, branches and pine cones are still on the tree before it is cut down.  If it still has needles, it will be very good.  If some of the bark has fell off, I expect it to be junk.
Offline crowhill
« Reply #9 on: December 06, 2017, 05:10:16 PM »
I cut a standing white pine once had brown needles and a lightning strike mark from top to bottom. Needles hadnt been brown for many weeks. There was no moisture or sap in that tree, was as solid as could be. Also had a balsam on my Dads lawn that was struck by lightning turning it into millions of toothpick sized pieces but the needles stayed green.
TimberKing B-20, Kubota M-4900 w/FEL with tooth bar, hyd thumb and forks, Farmi winch, 4 chain saws, 26 chickens and Hereford beef cattle.
Online Peter Drouin
    • A&P Saw mill LLC
« Reply #10 on: December 06, 2017, 06:04:31 PM »
Imo, Dead trees are junk. Mills don't buy them for a reason. I don't buy them.
2008 LT40 super,2008 edger, Cat telahandler, JD 5410 And can cut up to 45' long
http://www.forestryforum.com/sanbornton     NH Timberland Owners Association supporter.
And a license NH soft wood grader.
Sawing since 1987
Offline drobertson
« Reply #11 on: December 06, 2017, 06:27:10 PM »
What many folks don't know about SYP, meaning "southern" is many times the pitch in these petrify, when sawn, they almost if I may use the comparison to treated telephone poles, they are solid, and stout. As to dead standing red and white oak, I've seen the same too, some crap, others, bad to the bone rich in color and strength.  And often time with character that can't be mimicked any other way,, just saying I would give it a look, it should not be rocket science to see if its solid or dote,
Offline Kbeitz
  • Never enough time...
    • My Hobbies
« Reply #12 on: December 06, 2017, 07:01:25 PM »
I'll take a dead standing tree anyday... You never know until you open it up.
Each of these pictures come from trees that has been dead for a long time.
Some was still standing and some was on the ground.
Maple.
Walnut...
W.Pine
Hemlock...
Love machine shop work
and Wood work shop work
And now a saw mill work
Offline Drarnold
« Reply #13 on: December 06, 2017, 08:36:26 PM »
Georgia088 I picked up a longleaf pine log from a neighbor that said it had been standing dead 2 years before they had a tree service take it down.  Terrible looking on the outside.  Dry, soft, and full of worm and sawyer beetle holes.  Didn't think I would get much but once I got past the first 2 inches of sapwood and into the heart it was almost solid heart pine. The boards would make great fat lightered but just it was just as beautiful as the old growth stuff.  I reckon if the heartwood looks solid you ought to give it a shot.
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
« Reply #14 on: December 06, 2017, 08:57:47 PM »
A SYP has to be pretty old to develop heartwood.  Since the stem broke when you felled it, that indicates that it is not old enough to have had heartwood formation.  Sounds like an iffy proposition to me.  I saw lots of dead pine, and when the stem breaks upon felling, I have found that it is best to let it lay.  Once the bark starts falling off while the dead tree is still standing, the stem is already pretty far gone in our Georgia climate, hot and humid.  In other parts of the country, trees can stand dead a year or two, sometimes more, and still be sound.  It depends a lot on where you are and the climate.
Offline Ga Mtn Man
  • Y'all can call me GMM
« Reply #15 on: December 07, 2017, 07:07:06 AM »
WDH-  What do you mean by "stem"?
2012 LT40HDG29 with "Superized" hydraulics,  2 Logrite cant hooks, home-built log arch.
Offline WDH
« Reply #16 on: December 07, 2017, 07:45:49 AM »
The "bole" of the tree.  The sawable section of the tree.
Offline pineywoods
« Reply #17 on: December 07, 2017, 10:22:44 AM »
A large percentage of the logs I saw are standing dead southern yellow pine. If there are dead limbs on the ground around the base, leave it be. Otherwise, the only way to tell for sure is to put a sawblade to the log. Time doesn't seem to be much of a factor, some will go punky in just a few months, others shed the bark and stand much longer, and are still solid. My opinion is it depends on how the tree died, slowly from a bug infestion or suddenly from a lightening strike..
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #18 on: December 07, 2017, 01:23:27 PM »
Yes, there are good and bad dead trees.  Probably 75% of my sawing is Beetle Killed SYP, and a great majority of that is framing lumber.
Offline drobertson
« Reply #19 on: December 07, 2017, 02:25:41 PM »
No doubt about it, they just have to be cut into, I mean many folks are not sawing thousands of board feet a day, day in and day out, so logs do at times get soft, and I will say each one unless just absolutely obviously just rotted out, its a potential gem. I will also say, I've sawn some dead standing, SYP that honestly, at first glance of the boards that came off, you would think I sawed treated lumber.  I've also found its always been the pine with the orange(ish) heart center, I'm no expert, I just know I messed with stuff that was a waste of time, while others made me smile.  I wish I still had my mill, bout all have to say about that.
Using dead standing hemlock, red pine and white pine & best transport in forest
Started by LoggingOn on Ask The Forester
Last post July 28, 2011, 03:19:12 PM
by LoggingOn
Issues when sawing dead Southern Yellow Pine
Started by grweldon on Sawmills and Milling
Last post November 21, 2012, 08:00:43 AM
by grweldon
standing dead pine
Started by hunterbuild on Sawmills and Milling
Last post February 15, 2012, 07:28:09 AM
by WDH
Standing dead pine
Started by brooksmill on Sawmills and Milling
Last post April 07, 2007, 08:09:51 AM
by Minnesota_boy
