Arborwear
Author Topic: 353 blower busted  (Read 375 times)
Offline larry1
  • TJ Forever
353 blower busted
« on: December 06, 2017, 02:13:01 PM »
Sorry guys no pics.  I aquired a 230 with a 353 that's been sitting for quit some time uncovered, but did run. It is stuck (I think ) . Took the blower off and one impeller is broke with a small chunk out of it , one drive gear is sheared off and somewhere ? Was told the gear could be jammed up inside causing the engine not to turn with a 4 ' bar . Took the valve cover off and everything looks okay , sprayed release oil into it and letting it sit. Probably going to pull the engine in the spring .
Offline bushmechanic
  • Someone else has it worse than you.
Re: 353 blower busted
« Reply #1 on: December 06, 2017, 05:18:46 PM »
More than likely water seeped into the blower and froze busting the rotor, when trying to start it the gear stripped. Blowers aren't cheap, good luck!
Offline pdxh20
  • small woodlot owner
    • American painting
« Reply #2 on: December 09, 2017, 12:58:45 AM »
Had the exact same problem with the 353 on an IH S-8 I bought last March after it sat for 3 years with no air filter cover...Made one blower out of two (bought a spare junk engine) and got 'er unstuck after draining 3+ gals of water out of the crankcase. Changed out the injectors and adjusted the valves and off she went. Runs like a clock now. I have extra drive gears but no extra rotors...
'56 American crawler crane, Komatsu mini-ex, multiple Stihl saws, '75 IH S-8 cable skidder, 2000 F450 30' bucket truck, '95 Chev 4 x 4 2500 p/u, '05 Sprinter SHC 2500 van
Busted AGAIN!!!!
Started by IMERC on General Board
Last post January 29, 2010, 09:20:08 AM
by Planman1954
busted 290
Started by woodsteach on Chainsaws
Last post March 21, 2006, 11:00:08 AM
by woodsteach
Busted saw.
Started by customsawyer on Chainsaws
Last post April 26, 2011, 01:14:04 AM
by downunder Trav
sad
Busted elbow
Started by Bro. Noble on General Board
Last post June 12, 2011, 08:32:14 PM
by Warbird
