Author Topic: castiron  (Read 7538 times)
Offline coxy
castiron
« on: December 12, 2017, 08:16:35 PM »
what is the best way to clean one and how often do you season them
Offline newoodguy78
Re: castiron
« Reply #1 on: December 12, 2017, 08:37:29 PM »
I just simmer water in mine and scrub with a Brillo pad at the same time. Pour it out and let the residual heat dry it then wipe a light coat of oil and it's ready for next time. Haven't actually seasoned any of mine in years.
Whatever you do don't use detergent while cleaning
Offline Jeff
  • Fearless Leader
  • I know that I do not know.
    • THEE Forestry Forum
Re: castiron
« Reply #2 on: December 12, 2017, 09:14:41 PM »
I Heat that bugger up hot then pour a smll bit of water in it so it sizzles and loosens stuff up. Wipe it out, repeat if nessesary. Once you get everything out, while the pan is still hot, spray in some pam, or a little oil and wipe that out. never use soap or cleaner and never put it in the sink.  We keep ours all in the oven, as we don't use the oven all that much and don't have any place else for them. For the most part, probably 85% of the time, the cast iron is what we use.
Online Chuck White
  • Sawing Mobile since 2005
Re: castiron
« Reply #3 on: December 12, 2017, 10:53:35 PM »
I have a 3" deep X 8" dia. (at the bottom) frying pan that I'm trying to get adjusted!
I cook my eggs in it in the mornings, then when they're done, I wipe it out with a paper towel and then I take another paper towel with some Crisco on it and wipe the entire inside of the pan with it!
The pan is getting a little better and don't stick quite so much as it did at the start!
I've been told "don't be in a big hurry" it takes time to do it right!
I'd really like to get this pan right, those old Teflon pans just don't quite get it!
~Chuck~
1995 Wood-Mizer LT40HDG2425 Kohler - Shingle & LapSider, Cooks Cat Claw Sharpener and single-tooth setter, 4-foot Logrite cant hook.
Offline Roxie
  • Gender: Female
  • I'm your huckleberry
Re: castiron
« Reply #4 on: December 13, 2017, 06:41:50 AM »
Peanut oil is the absolute best conditioner and protector of cast iron.  I have two cast iron skillets that are 45 years old, and a few that are more recent additions.  Once they are seasoned properly, I do use a scrubby sponge and detergent and water.
I wouldn't recommend peanut oil for frying if you have a cholesterol problem, but it makes the best fries, fish, and chicken known to man.
Save a farm today or starve tomorrow.
Offline WDH
  • Forester
  • April 1998 - August 2008
    • hamsleyhardwood.com
Re: castiron
« Reply #5 on: December 13, 2017, 07:58:37 AM »
Mine are so seasoned after being passed down through several generations that it does not matter anymore how you clean them.
Online 69bronco
Re: castiron
« Reply #6 on: December 13, 2017, 08:16:09 AM »
Ours are well seasoned and usually wipe right out, if anything stick we rub it with salt and a paper towel. Wipe on a little oil and good to go. That was per my grandmother 30-40 yrs ago.
Online Weekend_Sawyer
  • Jack of all trades, master of fun
Re: castiron
« Reply #7 on: December 13, 2017, 08:20:21 AM »
I love cast iron and have quite a bit of it.
Cast iron is porous so don't use soap.
For light stuff I just wipe it out.
For heavier stuff I scrape it out with a metal spatula.
For baked on I do like others have said, put in some water and heat it up.
Oil and store.
Imagine, Me a Tree Farmer.
Jon, Appalachian American Wannabe. ... and it looks like my dream will come true!
Offline LaneC
  • Traveling Man
Re: castiron
« Reply #8 on: December 13, 2017, 11:51:50 AM »
 I love cast iron and do as everyone else has said except I have a pretty Italian wine bottle with olive oil in it right by the stove, and after I heat it hot enough to evaporate all the water after cleaning it, I sling some olive oil in it and wipe it down with a napkin, and the lid also, until the next use.
Man makes plans and God smiles
Offline LaneC
  • Traveling Man
Re: castiron
« Reply #9 on: December 13, 2017, 12:01:39 PM »
  I didn't read the question well enough :) I think you only have to really season it one time. After that, by not cleaning with detergent and soap, it continues to build up a non stick surface from each use. There are a couple of methods you could use but either way you will have to get it very hot the first time and then start with what type of oil you will use for the initial seasoning. If you just got one, you may want to scribe a date on it somewhere if you plan on passing it down. Mine is probably 20 years old (not old for most folks) and I wish I would have dated it so when I pass it on they can say, that is Paw Paws old pot, look at the date on it.
Re: castiron
« Reply #10 on: December 13, 2017, 12:06:53 PM »
Season it once, use it a lifetime!
Offline drobertson
Re: castiron
« Reply #11 on: December 13, 2017, 01:25:55 PM »
I love them too, we have 4, small skillet, pretty big shallow (lodge), and a deep dish wagner, one like WDH's it sounds like, now the lodge was a bit of a pain getting it right, and I've tried the steaming off method, it seemed to just create another round of seasoning all over again for me.. I just cooked everything in it for a while,, mainly bacon and sausage,,and I do what many folks don't, but I use hot tap water and one of those soap filled scrubbers, lightly cleaning and rinsing with the hot water, it now will bake and fry anything without sticking..the little one was a pain as well, its a pioneer woman skillet, picked it up at a walmart for 10 bucks, same as above, lots of cooking. To your question, I believe you can use dish soap, just don't soak it, and for seasoning, I cleaned them good, coated with oil, and placed in the oven upside down baking at 350* for over an hour, the dutch oven cleans out good too, they can be cantanceraus (spelling) but with patience they will come around and serve you well,
Offline petefrom bearswamp
  • 70-12 still feel pretty good and going to retire
Re: castiron
« Reply #12 on: December 14, 2017, 09:33:05 AM »
No soap here, just hot water, wipe out with a plastic scrubber, dry on the stove and wipe with a little oil.
OUr oven is the storage place too.
LT40SHDD51
Kubota 900 RTV
Polaris 550 Sportsman ATV
241 acres of woodland
Offline DanG
  • DanG, The Official ForestryForum Cussword
Re: castiron
« Reply #13 on: December 14, 2017, 09:41:11 AM »
I'm a member of "Cast Iron Cooking" on Facebook. The group has over 270,000 members and has all kinds of info on whipping your cast iron into shape.  For seasoning, they recommend coating lightly with lard or shortening and placing upside down in the oven at 450-500 for a couple of hours. The trick is to get the temp up to the "smoke point" and hold it there until all of the volatiles are burned out of the coating. You can also use your grill if you don't want to smoke up your house.
Offline 21incher
Re: castiron
« Reply #14 on: December 15, 2017, 07:20:48 PM »
I purchased 2 Chinese  cast iron frying pans at tractor supply a couple years ago and they were junk. The pores were big enough to loose a grain of rice in and everything stuck no mater what I tried. Tossed them and got some lodge pans from Costco.  What a difference. Lesson learned, quality costs. :)
Thanks everyone for sharing these pointers to a new cast iron user.
Hudson HFE-21 on a custom trailer, Deere 4100, Kubota BX 2360, Echo CS590 & CS310, home built wood splitter, home built log arch, and a Logrite cant hook.
Offline coxy
Re: castiron
« Reply #15 on: December 15, 2017, 08:23:02 PM »
yes thanks I'm new to this  my mom had one that was at least 20in with 2 handles  after dad and mom passed away my sister through it in the garbage because it was black  >:( >:( >:( >:( I was not happy  that pan made the best p chops and steak I ever had not to mention the fried taters that came out of it  the pan that a friend got me is preseason and its from Cabela's not shur where it was made haven't seen it yet another guy told me cook as much bacon in it as I can eat for a few months then try frying an egg if it sticks cook more bacon  :o :D
Offline Ianab
Re: castiron
« Reply #16 on: December 15, 2017, 09:39:40 PM »
Quote
Yup, that will work  :D
I did have to re-season one of my pans, but that was after it was in a house fire at the Ex's. (I'd left her a frying pan when I moved out) Fire was so hot we found the pan on the ground, with a puddle of aluminium solidified in it.  :D She was getting all new stuff from the insurance, so I salvaged that. Took some wire brush on a power drill work to clean it up. But wiped it down with oil, baked it in a hot oven for a couple of hours, then cooked some bacon. Good as new  ;D
And that's just a cheap Chinese set, although it does seem to be decent quality, and has lasted well.
Offline WV Sawmiller
    • Green's Sawmill Services
Re: castiron
« Reply #17 on: December 15, 2017, 09:51:57 PM »
   I never heard of re-seasoning one unless it was old and rusted. I confess I have used detergent on mine but mostly I just scrub briskly with a stiff plastic bristled brush or scrubby pad under scalding hot water and occasionally wipe with cooking oil.
   We have a big selection of cast iron including some that belonged to my grandmother and possibly she got them from her mom. Dad sent us a 4" and a 2" deep oval roaster with a lid that fits both about a year after we got married (When we returned from an overseas USMC tour). He sent them by Greyhound bus from Fla to SC. I'd speculate we have used that 4" roaster on average at least once per month for the 39 years we have had it.
Offline samandothers
Re: castiron
« Reply #18 on: December 16, 2017, 10:43:00 AM »
My brother found an old rusted cast iron skillet.  I sand blasted it to clean.  He seasoned and used it.
If a pan/skillet is warped is there a method to flatten?  We have a skillet that is bulged in the center that came from mom and dadís.  We speculate it was too hot and placed in water.
Re: castiron
« Reply #19 on: December 18, 2017, 05:49:21 AM »
If you have a junk pan it will make a nice plinking target for a 22 or pellet rifle.
I bought a couple from a junk (antique) shop and was going to plink with them but they turned out to be nice pans so I kept them. Go figure.  ::)
Jon
