Author Topic: Prentice 120 Log Loader  (Read 599 times)
Offline David-L
  • present and accounted for.
« on: December 23, 2017, 07:01:57 AM »
Whats the correct Hydraulic oil for winter time use in this 120 Loader. Is it aw46 or can I use the hyd/tran combo. Its a straight 120. Trucks running good, added alot to the end number. Nice to load up and go when you want. Merry Christmas all.
Offline David-L
Re: Prentice 120 Log Loader
« Reply #1 on: December 23, 2017, 07:14:07 AM »
Just read the Hydraulic oil thread, sounds like 32 unless someone says otherwise. Whats the viscocity of say 303 oil.
Offline mark_h
« Reply #2 on: December 27, 2017, 06:23:40 PM »
I don't know much about that loader in particular, but I have used hy-tran oil in hyd systems year around. I know the 303 fluid says its not for cold weather use, but i've used some older machines in the winter with it in and had no problem. I cant imagine it's heavier than maybe aw46 weight
Is there a reason you should not use hy-tran in a straight hydraulic system?
Offline David-L
« Reply #3 on: December 27, 2017, 06:28:53 PM »
I am going to switch out to AW32 soon. Especially with this cold snap were having.
Offline North River Energy
« Reply #4 on: December 27, 2017, 07:14:58 PM »
David,
Unless I'm mistaken (a possibility), one of my cohorts has been running atf in his Serco loaders for many years.
Offline ga jones
« Reply #5 on: January 06, 2018, 05:32:11 PM »
The cheapest stuff you can find David. Cause when you blow a couple hoses you loose a lot. Tractor fluid from TSC. I buy it at the Black Friday sales. 16.00 5 gallon pails. I got a pallet of it.
380c timberjack c4 treefarmer international trucks jonsered saws. Sugi hara bars d31 komatsu 350 tj grapple
Offline mike_belben
  • Pulp Friction
« Reply #6 on: January 07, 2018, 08:39:49 AM »
I never thought about stocking up on BF. Thats brilliant.
