TURBOSAWMILL GIANT SALE ON NOW UNTIL OCTOBER 31st
Author Topic: light duty by pass grapples  (Read 910 times)
Offline h2ofwlr
« on: December 26, 2017, 12:48:05 PM »
Good afternoon.  Looking for some advice from others that have gone done the path of  searching for the best grapple to put on a mini excavator,  12k lb  machine.    Going to be used for handling small logs 3 to 12 inch  and 16 foot long  and piling brush. thanks for your time and knowledge. Mark
Offline DDW_OR
Re: light duty by pass grapples
« Reply #1 on: December 26, 2017, 01:42:49 PM »
following
I have a bobcat 331 and a E80. going to be putting a stroke harvester on the E80
saw this
http://www.forestryforum.com/board/index.php/topic,67465.0/all.html
Multitek 1610EZ, TimberKing 2000 & Talon Sharpener,
Online mike_belben
  • Pulp Friction
« Reply #2 on: December 26, 2017, 01:52:45 PM »
If you are hand thinning dense small stems from around crop trees, id find a bypass shear.  They have a little stationary blade nested in between the grapple palm and pull the tree into it making your mini ex into a baby feller buncher.  Lift tree, swing around and lay it in a pile for the bobcat to grapple onto the truck.
But they cant rotate, pins are fixed in the stick so its a rigid head, not dangle.
Revelation 3:20
Offline North River Energy
« Reply #3 on: December 26, 2017, 05:30:41 PM »
Was at the big trade show in Boston right after Thanksgiving. Noticed a lot of those compact track loaders that the operator stands behind. Most were kitted with some variation of a bypass grapple. I think one brand was maybe Ryan's?
Anyhow, you might look into whatever is being used by the tree removal crowd, as many companies use those loaders with grapples to remove debris from residential yards.
Offline chubby
  • Staying busy is the only way to stay sane.
    • GRAPPLEPROS
« Reply #4 on: December 30, 2017, 04:31:48 PM »
Forum members actually get a 10% discount on FARMA grapples since theyre a site sponsor. Complete kits for excavators are available.
http://www.forestryforum.com/board/index.php/topic,97870.0.html
Offline h2ofwlr
« Reply #5 on: January 10, 2018, 07:46:29 AM »
Thanks  for the leads guys I will follow up Mark
Offline 47sawdust
« Reply #6 on: January 10, 2018, 09:15:19 AM »
I bought a Farma 34'' grapple w/o the rotator for my tractor.Right now it is hung from a 10k # lifting ring that I can lock  for picking up firewood logs to buck to length.Seems well made,made in Latvia.Mine is probably the smallest size.
Gallery is currently not available or I would post a pic.
Mick
Light Duty Grapple, pictures, sketches or plans
Started by Gilman on Wanted
Last post January 04, 2006, 05:30:22 PM
by Gilman
Kaufman Trailers Deluxe Light Duty 10000 GVWR Dump Trailer
Started by submarinesailor on General Board
Last post November 28, 2016, 11:07:02 PM
by submarinesailor
Grapples...Grapples...Grapples
Started by sticks on Forestry and Logging
Last post December 18, 2005, 10:24:51 PM
by J_T
10% off FARMA grapples
Started by chubby on FARMA
Last post September 19, 2017, 02:14:19 PM
by chubby
