Author Topic: Lucas Slabber cutting downward  (Read 1473 times)
Offline Seaman
  • Still learning as hard as I can go.
    • Uniquewoodcuts.com
« on: December 27, 2017, 10:32:30 AM »
Yet another case of my Lucas not cutting straight! Not the fault of Lucas, it always comes down to the bar, or my chain sharpening. So frustrating!
There are so many variables, I usually do not know what fixed it when it improves.
Did I mention frustrating?
I can find nothing wrong with the chains I sharpen, but if I put a brand new chain on it cuts straight!
Frustrating!
Bar is flat
Chains are at 10%
Rakers are filed to Carlton guage
Just had to rant. One of you may know something I do not.
Lucas dedicated slabber
Woodmizer LT40HD
John Deere 5310 W/ FEL
Semper Fi
Offline sealark37
Re: Lucas Slabber cutting downward
« Reply #1 on: December 27, 2017, 11:14:48 AM »
If a new chain fixes the problem, there must be some difference in the sharpening you do to a used chain.  It is easy to sharpen left teeth slightly different than the angle used on right teeth.  You state that the bar is flat.  Is it possible that one rail of the bar is worn lower than the other rail?  You may need to have the bar rails ground to true.  Don't be discouraged, it's not magic, but it can be a very small problem.    Regards, Clark
Offline terrifictimbersllc
    • Terrific Timbers LLC
« Reply #2 on: December 27, 2017, 11:34:20 AM »
Bars wear out.  The wear can be minimized by always keeping the front edge dressed square, and by running the chain tight.
I believe the wear that destroys a bar and makes it no longer able to cut straight, is the widening of the groove, not at the top, but down deeper, where the bottom of the drive links are contacting. In other words the bar groove is now worn in a trapezoidal shape, the walls are not parallel to each other.  A bar with such widening is no longer able to hold the chain straight at 90 degrees. I would also add that I have observed that when bars are climbing or diving, I have also observed the phenomenon of it not cutting until I push it a bit harder, then observe that the chain "cocks" in one direction or the other, even if ever so slightly, after which it begins cutting again. Once on this path,  one is on a slippery slope of increased bar wear and poorer performance.
I plan to cut a used up bar in two to look at the cross section of the groove, to verify and show what I am saying.
If you haven't, either flip your bar over if the other side is unused, or less used.  The back side of a bar does not wear appreciably in use, compared to the front. Or put on a new bar.
This may not be your problem, but it has been mine.
In my slabbing experience my bar (using both sides) has a life of about 150 slabbing hours or so.  I remember the first time I flipped a bar.  I was 125 miles from home, the sun was going down, and I had used all of the dozen or so chains I had with me trying to finish the customer's log without ruining the work.  It came to me that the only thing I hadn't tried was flipping the bar.  What a difference.
DJ Hoover, Terrific Timbers LLC,  Mystic CT   2001 WM LT40SHDD (42HP Kubota, Accuset2, FAO's, Lubemizer, debarker, hydraulics everywhere), Peterson WPF 10-30 with chain slabber. Logrite fetching arch, WM BMS250 sharpener/BMT250 setter.
Offline Hilltop366
« Reply #3 on: December 27, 2017, 02:39:50 PM »
Worn bar + new chain = less slop.
Worn bar + worn chain = more slop.
Chains, like bars don't always wear evenly.
For what it is worth the ripping chain I had I ended up grinding to 0° after a while, the less angle I used the smoother the cut.
My theory was the less sideways stress on the bar and chain the longer it would last, the smoother the cut and was easier to sharpen (grind) all cutters the same.
Also make sure the bar is parallel to your mill rails.
Offline Don P
    • Calculator Index
« Reply #4 on: December 27, 2017, 04:25:08 PM »
one more to add, we discovered that when the sharpener was swung for the other side we also need to adjust the tooth stop, it was not cutting the teeth the same length from side to side. I picked up a digital caliper to check the tooth length... it isn't what you set, it's what you get that matters.
Offline xlogger
« Reply #5 on: December 27, 2017, 05:46:06 PM »
Keep us informed what you found out Frank. I've been lucky so far with my slabber but not even cranked it up for over a month now. Been able to cut everything on bandmill. Good luck.
« Reply #6 on: December 27, 2017, 06:13:04 PM »
I do the same exactly.
I sharpen at 15 degrees top view,  and 60 degrees from horizontal.
Offline TKehl
  • Certified Contrarian
    • Kehlhof Ranch
« Reply #7 on: December 27, 2017, 08:54:13 PM »
Are you freehand sharpening, using a jig, or a machine?
« Reply #8 on: December 27, 2017, 09:23:46 PM »
Chain grinder and occasional filing with a 15 deg  file holder. Monitor tooth length with digital caliper and keep raker depth .05-.06 “
Offline Chop Shop
« Reply #9 on: December 27, 2017, 11:46:59 PM »
What kind of wood?
I have to run different angles on different chains for soft vs hard wood.
I battle softwood sawdust building up under the bar pushing the cut upwards.  On soft stuff I have to back up every so many inches to clear the cut out.
Is this a Lucas slab attachment or a dedicated slabber?
Offline Seaman
« Reply #10 on: December 28, 2017, 08:00:16 AM »
Sorry fellas, I wrote a long reply yesterday, and somehow it did not post. So here is the short version.
The bar is freshly dressed on both edges, 90 hrs on the machine and the bar has had to be dresses 3 or 4 times already. The bottom edge ( of the drive teeth groove) has started grooving faster than the top.
TT, the inside of the groove may be wearing as you suspect, I will check.
Sharpen on a Oregon electric grinder, and both right and left are 10% and same length. Checked with dial caliper.
Rakers filed down to the lesser slot on a Carlton gage, not sure of the spec.
Set at 10% top and 60 horizontal.
Oil with 30wt.
I emailed Lucas, and Warren was kind enough to get involved. He suggested I get a strip of 16ga sreel to slide into the groove and hammer the edge closed around the still, so I will try that. He also offered to send me a new harder  bar under development to test. I accepted his generous offer of course.
I will keep you posted, thanks for the help.
Woodmizer LT40HD
Semper Fi
« Reply #11 on: December 28, 2017, 12:51:08 PM »
What kind of wood?
I use 15/60 for everything. Mine is a Peterson WPF 10”swing mill with the slabber attachment and a smaller pulley on the gearbox input side to increase the chain speed when using it as a slabber.  I usually back up every 6 to 12 inches to clear sawdust.
Offline DR_Buck
  • Nuff said.....
    • Got Logs?
« Reply #12 on: December 28, 2017, 01:50:09 PM »
This is a long shot, but have you checked where the bar ends mount?    There could be compacted sawdust not letting the bar sit flat against the mounting points on one or both ends, giving you a slight down tilt.
As I have not yet fired up my new Lucas dedicated slabber that I brought home from Paul Bunyan in October, I have nothing else to add, but I am following this thread.  Keep us posed.
Hidden Acres Farm
Been there, done that.   Never got caught
Wood-Mizer LT40HDG38
Lucas Dedicated 60" Slabber
Offline Seaman
« Reply #13 on: December 29, 2017, 07:23:01 AM »
Dr Buck, yes , the mating surfaces are clean and bar is level.
I am sawing more today and will let you know.
Frank
Woodmizer LT40HD
Semper Fi
Offline Grandedog
    • Left Coast Supplies
« Reply #14 on: December 29, 2017, 04:00:57 PM »
Oil with 30wt.
Howdy Frank,
Don't feel pregnant, you're not the only one. We've seen this issue for years. It's really as simple as with the increased amount of people running high powered (not brand specific) mills with bar / chain setups, and the large amount of hours that they're being run, issues will show up sooner than later. These are made by Cannon and have a replaceable tip. http://leftcoastsupplies.com/product-category/forestry-supplies/forestry-supplies-bars-tips-forestry-supplies/forestry-supplies-bars-tips-cannon-sawmiller-bars/
Regards
Gregg
Gregg Grande
Left Coast Supplies LLC
1615B South Main Street  Willits, CA 95490
888-995-7307  Ph 707-602-0141                   Fax 707-602-0134  Cell 707-354-3212
E-Mail  gregg@leftcoastsupplies.com   www.leftcoastsupplies.com
« Reply #15 on: December 29, 2017, 04:35:08 PM »
.......The bottom edge ( of the drive teeth groove) has started grooving faster than the top.
TT, the inside of the groove may be wearing as you suspect, I will check.  .....
IMO this means the groove inside has to be widening at the back, if when in operation the chain is pressed against the bar, with the the bottom edge a bit shorter than the top edge,  then the chain is tilting down a bit and the groove has to be widened down inside.  Otherwise the chain couldnt tilt because of the drive link, and the bottom edge of the bar couildnt wear more than the top.
I think one could detect this if one had one end of a 0.063 feeler gauge in the bar and seeing how much wiggle there is at the other end.  At least compared to a new bar.   I don't have such a gauge i'm just making a point.
Offline DR_Buck
  • Nuff said.....
    • Got Logs?
« Reply #16 on: December 29, 2017, 05:19:57 PM »
If that's the case, would one of these tools fix it?
http://www.baileysonline.com/shop.axd/ProductDetails?item_no=W%2010001&utm_source=googlepla&utm_medium=cse&id=394057828225&gclid=CjwKCAiA7JfSBRBrEiwA1DWSG2t1JdeOIIz1T7tKfNb_4XomomOo9tL68ZpYSbBMN2q0ucHCw48mMhoCF_UQAvD_BwE
Hidden Acres Farm
« Reply #17 on: December 29, 2017, 07:32:58 PM »
It won’t hurt, but that tool, or even hammering, can’t close the widened-by-wear gap at the bottom of the groove, which is the problem. That tool will only squeeze the top back shut, if that (until  the bearings on it break).
Offline xlogger
« Reply #18 on: January 11, 2018, 06:04:17 PM »
Frank, did you get it working good?
Lucas gearbox, and LUCAS SLABBER DRIVE HUB pictures wanted
Started by shelbycharger400 on Sawmills and Milling
Last post September 04, 2011, 11:32:02 PM
by shelbycharger400
Lucas Slabber
Started by Clevelander on Sawmills and Milling
Last post January 28, 2016, 12:23:15 PM
by Grandedog
New Style Lucas Slabber Bar
Started by Lucas_USA on Lucas Mill
Last post April 11, 2018, 06:22:20 AM
by xlogger
How wide will a Lucas slabber cut?
Started by fishpharmer on Sawmills and Milling
Last post July 18, 2009, 08:04:57 AM
by Meadows Miller
