Baltic Abrasives Technologies
Author Topic: Question for the CTL guys.  (Read 3561 times)
Offline wannaergo
  • Work while I'm young, sleep when I'm dead!
Re: Question for da CTL guys.
« Reply #20 on: December 31, 2017, 11:07:28 AM »
I hear that now that cat is dealing logset they are discontinuing the forwarders. Not really a bad thing as far as I知 concerned. The European machines are far superior to the cat stuff.
As far as the timber king goes, I would honestly be nervous. That wasn稚 a common Machine, so I think parts would be a bugger to get.
2016 Ponsse ergo 8w
2014 Cat 564
Husky 385
Offline North River Energy
Re: Question for the CTL guys.
« Reply #21 on: December 31, 2017, 11:42:12 AM »
..but you need a water pump for your turdbox 1966 volkswagen beetle.. JCwhitney and rock auto will swordfight for your $19.
All the irony.
^Fake news.
Type 1,2,3 Volkswagens are air cooled.  :D
I blame russia.
The Russia ate your homework?
Offline deastman
« Reply #22 on: December 31, 2017, 12:19:46 PM »
so did peter say cat was out of the forwarder business now?? sounded like it
Cat told me at the show last spring that you can still get a new Cat forwarder but you have to special order it and it has to be built for you. Milton Cat is now selling Logset forwarder's and stocking parts for them, they had one at the show and it looked like a nice rig
Samsung 130 LCM-3 with Fabtek 4-roller and Cat 554 forwarder, Cat EL 180 excavator, Cat D3C dozer, Cat D7E dozer, '92 Ford LTL 9000 dump, Easy-2-Load 25 Ton tag-a-long, current project under construction: '91 Peterbilt 379 with a Hood 8000 w/extenda-boom loader
Offline deastman
« Reply #23 on: December 31, 2017, 12:24:55 PM »
Two contractors I know up here run Log Max heads and they swear by them. I would check with Milton Cat about parts availability for the carrier, wouldn't think it would be a problem and they're a Log Max dealer also
Offline Skeans1
« Reply #24 on: December 31, 2017, 12:35:03 PM »
They look like a beautiful machine but how long till they drop that line or cat buys them out just like Ecolog, Fabtek, and Timber King that'd be my worry with an Logset for the long run.
Offline BargeMonkey
« Reply #25 on: December 31, 2017, 08:50:49 PM »
 I'm waiting to hear back from the forestry salesman, he sold it to this guy, find out exactly on parts, they still make that class of buncher. Yeah you can order a new cat forwarder still, salesman at Boonville tried to talk us into a 564 that was sitting there for 380k new.
 140 miles north of me, wasn't a bad ride. I'm going to go back up after talking to Cat and he will get it going. This machine wasn't beat, not all banged up, got in the cab, hit the switch and the engine door opened. I see a few little things, missing the roller covers and 1 cover on the stick. It is the large cable, not a 4 wire computer from what I see. He bought it for a job, used it and kept it as a back up, I think for the money it's not a bad deal. It's not small, I think it's a touch wider than my Timbco and longer track base, he has the books for the machine and the head, said it weighs 57,800 which isn't to bad.
 Now... and I'm under the impression that this is the dumbest thing possible....  this guy has a new Ponnse processor... owns 2 grapple skidders and a 384 prentice slasher, cut and delimbs for the skidder, zero forwarder. Says a couple other guys up that way also do it.
Offline 1270d
« Reply #26 on: December 31, 2017, 08:55:36 PM »
He bunches with a ponsse?   That's interesting..   doesn't seem like it would be at all competitive with a tracked buncher
Offline Skeans1
« Reply #27 on: December 31, 2017, 08:56:31 PM »
We do that from time to time doing long log I'll the longer wood into the center or slightly off row center for the logs then pulp I'll put into the thinning for the forwarder.
Offline Skeans1
« Reply #28 on: December 31, 2017, 08:58:17 PM »
Would it be much different then what we do out here doing CTL long logs?
Offline BargeMonkey
« Reply #29 on: December 31, 2017, 09:11:00 PM »
The guy didn't even blink, stutter, nothing. I said I was under the impression that it doesn't work, he said 2-3 other guys are doing it, he has 2 big grapples, had a pull thru down by his shop he uses when on small redpine.
Offline barbender
« Reply #30 on: January 01, 2018, 02:39:15 AM »
There's a few guys around here that run a buncher, and then a 703 Deere processor behind it, delimbing in the woods tree length, then skidders and slasher. I tell some of these guys, you already have that wood in the head you might as well cut it to length and forward it.
Offline Skeans1
« Reply #31 on: January 01, 2018, 03:21:16 AM »
All I have to say is Robyn at Fabtek had set ups like this for 30 years it's nothing new I still do 36' fir CTL in the woods a short log is 20' pulp length if you're interested contact me.
Offline bushmechanic
  • Someone else has it worse than you.
« Reply #32 on: January 01, 2018, 08:03:04 AM »
Looks like a nice machine and I can't get over the low hours on it. I have to disagree with snowstorm on the computer cable size being an issue. I used a Logmax for the last three summers with the larger cable and never had any problems with the wiring. Actually found it to be simpler than the canbus system to troubleshoot, not that either bothers me. One ground for everything and then a single wire to operate a function, simple. As for the carrier most parts are off the shelf for whatever machine make. For example on a 1010D John Deere all the hydraulic pumps and motors are Bosch Rexroth. Wish that machine was close to me I might buy it and go into business for myself  :D
Offline 1270d
« Reply #33 on: January 01, 2018, 07:17:38 PM »
I've bunched/limbed with the harvester a little.  It didn't seem to work at all but maybe we didn't do it long enough to work it out.  It was a good way to get a few edges that the buncher couldn't get and clean up the softwood without moving the pull through to the site.
Offline 1270d
« Reply #34 on: January 01, 2018, 07:20:41 PM »
I'm interested in learning more bargemonkey.  What kind of wood are they operating in and what production level?
Offline BargeMonkey
« Reply #35 on: January 05, 2018, 01:31:19 PM »
I can PM you the guys #, I think they cut alot of hardwood and softwood.
Offline BargeMonkey
« Reply #36 on: January 05, 2018, 01:33:09 PM »
Finally tracked down the Cat salesman and doing the paperwork for it, salesman says it's going for a steal, it sold for 150k 3yrs ago. Milton handles logmax, salesman told me there is no issue for parts on the machine.
Another question for the WM guys
Started by delvis on Sawmills and Milling
Last post October 05, 2014, 05:48:47 PM
by Dave Shepard
question
Question for Electronics guys
Started by Fla._Deadheader on General Board
Last post February 19, 2003, 04:53:02 AM
by Fla._Deadheader
OK Stihl guys...I've got a question...
Started by Captain on Chainsaws
Last post November 10, 2005, 07:26:34 PM
by Captain
question for guys skidding with tractors
Started by oldbones on Forestry and Logging
Last post February 25, 2011, 11:24:47 PM
by woodmills1
