KNOW WHAT?
Between February 12, 2018 and June 18, 2018, this space displayed 13 Million, 871 Thousand and 87 times.
Author Topic: Setter  (Read 3404 times)
Offline ladylake
Setter
« on: December 30, 2017, 05:27:19 AM »
 After setting maybe 7000 blades my old Dino setter is wearing out so what to do or get, replacement parts for the Dino around $300  or a new Cooks or Suffolk, also on Ebay they have a new older model Suffolk for $650 shipped. Both the new model Suffolk and Cooks are around $1200  shipped.  Steve
Offline xlogger
Re: Setter
« Reply #1 on: December 30, 2017, 07:17:39 AM »
At the $1200 price if you do it again that's around $.17 each set.
Offline JB Griffin
Re: Setter
« Reply #2 on: December 30, 2017, 09:58:08 AM »
Don't buy a cooks. The Suffolk setters are much more accurate.
2000 LT40hyd remote 33hp Kubota, 160 Prentice, Frick 2 saw gang edger, Wright W-37 ABG, Suffolk dual tooth setter, Cat claw single tooth setter,'96 F-250 7.3 PSD 4x4, CS-590 Echo, MF 20c, M681 Memo.
1.8 million bdft sawn with a Baker Dominator and counting.
Online gmmills
Re: Setter
« Reply #3 on: December 30, 2017, 10:04:14 AM »
From the two setters you mentioned the Suffolk setter is the most accurate. This is based on the fact that it has the ability to clamp deflection from the blade prior to the anvils contacting the tooth to set it. The Cook's does not do this. The setting anvils are bending the teeth prior to the setter jaws even contacting the blade. The blade is actually twisting between the jaws as the teeth are being set. The WM dual tooth setter is another option to consider. It also clamps the blade deflection prior to bending the teeth.
   Out of all the dual tooth setters on the market the Cook's is the least accurate of all. The blade body has to be held static prior to bending the teeth to assure accuracy.
  The Suffolk also has less moving parts to wear over time compared to a Cook's.
Custom sawing full-time since 2000.
WM LT70D62 Remote with Accuset
Sawing since 1995
Offline ladylake
Re: Setter
« Reply #4 on: December 30, 2017, 10:38:56 AM »
 Sound like Its going to be a Suffolk .  Thanks   Steve
Offline PAmizerman
  • Just Another Day In Paradise!!
Re: Setter
« Reply #5 on: December 30, 2017, 11:36:57 AM »
I looked at the one for sale on eBay about a month ago. It does not have the capability to backset and does not have the guage to check set. Suffolk does have an upgrade kit but I'm not sure if it will fit that one. I thought pretty hard about the one on eBay but I'll just be buying a new Suffolk.
Traverse 6035 telehandler and a lot of back breaking work!!
Offline barbender
Re: Setter
« Reply #6 on: December 30, 2017, 12:13:19 PM »
Steve, I gave the EBay old model Suffolk, I haven't set but maybe 50 blades with it but I am very satisfied with the consistency of the set, and the sawn finish of freshly set blades. In fact, I had one blade I set, I almost didn't bother with it as it looked like it had hit a nail. It was missing a few teeth, but what the heck. Well, then I ended up having that on my mill when a guy showed up and wanted some cedar sawn, I figured I'd have to get another blade but even missing the teeth that blade sawed with a beautiful finish. The cedar was being used rough sawn for paneling so the appearance was important. The customer was happy, and so am I👍🏼
Offline Chuck White
  • Sawing Mobile since 2005
Re: Setter
« Reply #7 on: December 30, 2017, 12:45:55 PM »
If this is the case with your Cooks setter, you really need to do some adjusting on it to make it right!
I have the Cooks setter and the blade "is clamped before" the anvil contacts the teeth!
I suggest that you call Cooks and ask for help adjusting your setter properly!
~Chuck~
I LOVE MY SAWMILL
Offline Cutting Edge
    • Rix-Saws CBN Wheels
Re: Setter
« Reply #8 on: December 30, 2017, 02:00:25 PM »
Chuck,
gmmills is referring to the Cooks Dual Tooth Setter... also what ladylake was comparing at approx $1200 investment.
It was not stated as such, so I figured a little clarification might help.
"Winning an argument isn't everything, as long as you are heard and understood" - W.S.
Cutting Edge Saw Service, LLC -
 - Sharpening Services
 - Portable/Custom Milling and Slabbing
 - On-Site Sawmill Maintenance/Repair Services
Factory Direct Kasco WoodMaxx Blade Distributor
Ph- (304) 878-3343
Offline kelLOGg
  • Still learning more than I'm teaching
Re: Setter
« Reply #9 on: December 30, 2017, 06:49:48 PM »
Early on I experienced an insufficient clamp force on my Cooks single tooth setter but found out I didn't have it adjusted right. Corrected it and it really clamps the blade body tightly and has need no readjustment in 10 or so years.
Bob
Cook's MP-32, 16HP, 20' (modified w/ power feed, up/down, loader/turner)
DH kiln, CatClaw, setter, tandem trailer, log arches, tractor, thumb tacks
Offline Chuck White
Re: Setter
« Reply #10 on: December 30, 2017, 07:42:45 PM »
Thanks for the clarification Cutting Edge!
Wasn't quite sure, but I knew my single tooth setter worked very well!
Thanks again!   :)
~Chuck~
I LOVE MY SAWMILL
Offline irvi00
Re: Setter
« Reply #11 on: December 30, 2017, 08:03:46 PM »
My cooks dual tooth setter works great. When adjusted properly it does clamp securely before setting. Very accurate.
Offline xlogger
Re: Setter
« Reply #12 on: December 31, 2017, 05:04:08 AM »
On my suffolk setter I've really not use it to down set when setting blades, maybe I should. Does anyone use this much?
Offline Grizzly
  • I wanna go camping!
Re: Setter
« Reply #13 on: December 31, 2017, 11:42:33 AM »
Thanks. I've been a little confused reading here. I'm no where near a seasoned pro like a bunch of you guys are but I've run about a hundred or more bands through watching closely (trying to learn from Cutting Edge's teaching and all the forum info). And that was my observation. It clamps, brings up the setters and dial gauges, then sets and measures. I then cycle it to the next ones. But I'm pretty ignorant compared to the average guy here on the forum and not near as experienced.
2011 - Logmaster LM-2 / Chinese wheel loader
Jonsered saws - 2149 - 111S - 90?
Cooks Cat Claw & Dual tooth setter
2000 Miners 3-31 Board Edger
Offline Percy
  • Resident trouble maker
Re: Setter
« Reply #14 on: December 31, 2017, 11:52:49 AM »
When I first got my Suffolk, I used it as you do, just for setting teeth as in increasing set. I did not even have the down setting anvils installed .  It was a tad finicky and my accuracy was not very good.  On the advice of someone here, cant remember who, (Im a siv-head), I installed the down setting anvils, set them correctly for the thickness of my blades, yaddayadda and ...wala.....the thing became very consistant and accurate.....not as accurate as my old slow poke single tooth setter, but acceptable.
Offline 4x4American
  • Team red, white, blue and orange
    • Website Link
Re: Setter
« Reply #15 on: December 31, 2017, 12:05:44 PM »
I made this video about 4 months ago when this same question came up on here, I think it will help clear things up a bit:
Boy, back in my day..
Offline 4x4American
    • Website Link
Re: Setter
« Reply #16 on: December 31, 2017, 12:10:29 PM »
Percy what is the difference in the up-setting anvils vs the down setting anvils?  Is it just the location in which they are mounted which makes it so you can double down-set in one go round da jimmy-do?  I use my Cooks DTS mainly for down setting teeth as it's quick and works good enough, but you can only do one side at a time and have to set the anvils distance for each side each time cause you have to take one away to do one side...if ya foller what imer sayin...The DTS is faster than the STS cause it has the feed arm and you don't have to invert the blade so it is my weapon of choice for downsetting.  I try to downset it to my target set on the first shot and if I have alot of blades to do that are the same ting I'll set it up to do say the outside teeth and I'll put one blade on, do the outside, take it off and do the rest of them all on the outside, then I'll set it up for the inside and go go go.  Helps keep it consistent as well as less fiddlefarting around with the settings.  But if you get it wrong on this then that'll put ya in a vlasic jar eh.
Offline Chuck White
Re: Setter
« Reply #17 on: December 31, 2017, 02:28:25 PM »
4x4, I see it now, the dual-tooth setter actually does the clamping and setting at the same time, compared to the single-tooth setter clamping and setting in two steps!
~Chuck~
I LOVE MY SAWMILL
Offline Percy
Re: Setter
« Reply #18 on: December 31, 2017, 02:51:43 PM »
in this pic, the large anvils are the uppers and little ones the downers. Just back off the appropriate ones.
Offline 4x4American
    • Website Link
Re: Setter
« Reply #19 on: December 31, 2017, 03:34:41 PM »
So you can upset and downset both sides of the blade in one pass?
My New Setter
Started by Fla._Deadheader on Sawmills and Milling
Last post February 20, 2003, 04:07:32 PM
by Fla._Deadheader
NEED A SETTER
Started by SAW MILLER on Wanted
Last post March 24, 2006, 08:21:11 PM
by SAW MILLER
question
Better setter
Started by uler3161 on Sawmills and Milling
Last post December 05, 2014, 06:18:06 PM
by uler3161
band setter
Started by slider on Sawmills and Milling
Last post February 14, 2012, 02:09:02 PM
by vfauto
