TURBOSAWMILL GIANT SALE ON NOW UNTIL OCTOBER 31st
Author Topic: Frick 00 Circle Saw  (Read 3626 times)
Offline Corley5
  • Wolverine, Michigan
    • Whittaker Farms
Re: Frick 00 Circle Saw
« Reply #40 on: January 03, 2018, 10:07:37 PM »
  My tach is an old mechanical that you hold against the center end of the shaft.  I ran my 50" style 3 @ 500RPMs with the 403 MM and at 540 with the 706.  I forget how many teeth it has.
  The last I sawed with the MM it wasn't pretty.  I thought it was the saw although I knew the engine wasn't up to par.  The saw wouldn't stay up.  The engine blew a head gasket and was spewing fire between the head and block and that was the end of it.  I rounded up a PTO shaft and hooked up the 706.  Night and day difference.
  Someday I'll get it set up again.  I like to saw :) good logs ;) ;D :)
Offline Ron Wenrich
« Reply #41 on: January 04, 2018, 05:51:36 AM »
Number of teeth in a saw has to do with diameter and the style of shank you're using.  An F pattern saw will have more teeth, because the gullet size is smaller.  Its been awhile since I run an F, but I'm thinking my 56" saw had 50 teeth.  The B pattern had 46.  The shank style is stamped onto the shank.  If you have a letter B or F, that's designed mainly for hardwoods.  The numbered ones like 2 1/2, 3, or 3 1/2 are for softwoods.
I've seen a 371 Detroit on small mills.  4 belts would be an absolute minimum for a mill.  I've used the dial tach like Corley describes.  Works well and maybe you could borrow one from another mill.  I've also seen the light one used and you can pick them up pretty cheap on Ebay.
I don't know if you've looked at Lunstrum's manual on circle mills that was written for the Forest Service.  It has a ton of information in it, and will help you answer a lot of questions.  It's free and here's the link:
https://www.fpl.fs.fed.us/documnts/misc/circsaw.pdf
Offline Rigg
« Reply #42 on: January 04, 2018, 06:29:25 AM »
Thanks.  I think mine is F style shank.  Its hard to read on the shank. I have a mix of winter and summer shanks.  Does that matter?
I have that book printed out.  I just haven't been sure if I should be changing my setup yet.
Offline Ron Wenrich
« Reply #43 on: January 04, 2018, 06:55:31 AM »
I don't think mixing the shanks makes too much of a difference if they're spaced out evenly.  I don't think that a summer shank and a winter shank weigh the same.  Too many of one type on one side could put your saw out of balance.
I ran all winter shanks and summer bits all the time.  What will happen if you have a winter shank and a standall bit is that you reduce the gullet size of your saw.  You can overload your saw and you'll hang your blade.  Or your dust will spill out of the gullets and it can push your saw and cause heat.
Offline Rigg
« Reply #44 on: January 04, 2018, 07:07:48 AM »
Thanks for all the help.
I had a box of standalls I wanted to put on but I think it was from reading your posts on here I knew I shouldn't put them on the winter shanks.
I wasn't sure what I should be running when I realized I had a mix of summer and winter.
My mill has been put together over the years by folks just making do with what they had at the time and trying to make a living.
Offline moodnacreek
  • Sawin by the notches
« Reply #45 on: January 04, 2018, 09:40:17 AM »
Rig, You have a lot of useful equipment on your mill.  When you get it all fixed up and get into the rhythm of sawing, with some nice logs, you will wear out 2 men trying to take the lumber and slabs away.
Offline HPPDRoss
  • Serving Thin Blue Line since 2009
« Reply #46 on: January 11, 2018, 10:56:47 AM »
Ive got an old semi truck with a 671 and a 10 speed transmission connected to my mill. I just cut the frame off at the back of the cab, cut the driveshaft and ran a pto shaft from the truck to the mill. It was alot cheaper for me doing it this way than buying a power unit. Just my 2 cents
Offline Rigg
« Reply #47 on: January 11, 2018, 01:59:08 PM »
Thanks.  I may have to do something like that.
I just finished cleaning air cleaner, fuel filters and changing the oil.
Ran a poplar log through and it was cutting a lot faster.  Didn't lose power at all really compared to what it was doing.
 I still have air in my lines though.   I feel like if I could figure that out I'd have all the power I'd need for awhile.  At least to cut enough lumber for a mill shed.
I'm going to keep an eye out for a 4-71 I think though.
Offline dgdrls
  • Learning the Art of Milling Logs, Lucas 8/27
« Reply #48 on: January 12, 2018, 08:15:48 PM »
Sounds like you're heading the right way Rigg,
I would also keep an eye open for a 53 Series Detroit
or an air cooled Deutz.  The Deutz will use less fuel and be
quieter,
Best
Offline bandmiller2
« Reply #49 on: January 13, 2018, 07:24:27 AM »
For a power unit keep your eyes open for an old shovel or crane, they had modular power units and most have had good duty throughout their life. Also they have good governors which is very important. Frank C.
Offline dgdrls
« Reply #50 on: January 13, 2018, 07:40:07 AM »
That is very good info,
Thanks bandmiller2
D
Offline starmac
« Reply #51 on: January 13, 2018, 03:12:58 PM »
I can't help on the saw, but did mess with those engines some years back.
You may already know this, but those engines will start a lot easier if you turn them back over to gas and clear the diesel out of the cylinders before shutting it down for the day.
We used to have to pull start a lot of equipment when operators did not change them back over, hard to pull start a saw.
Offline Rigg
« Reply #52 on: July 28, 2018, 05:59:11 AM »
I thought I would update this thread. My father in law came back and made a new video.
Large Frick Circle Mill
Started by SycamoreValley on Sawmills and Milling
Last post November 17, 2015, 09:29:03 PM
by SycamoreValley
Frick 00 circle mill slack in the headblocks
Started by Rigg on Sawmills and Milling
Last post July 28, 2018, 05:51:23 AM
by Rigg
Frick circle saw ways (tracks): Wood or steel
Started by oros35 on Sawmills and Milling
Last post May 11, 2015, 01:04:40 AM
by oros35
More SYP on the Frick
Started by ddcuning on Sawmills and Milling
Last post December 11, 2016, 08:39:07 AM
by 21incher
