Author Topic: Cupped cherry slabs from solar kiln  (Read 3132 times)
Offline Glenn1
  • Drying lumber one board at a time
    • GPS Hardwoods
« on: January 01, 2018, 08:39:29 PM »
Hello all,
This summer, we cut about 600 bf of 9/4 cherry slabs.  Iíve been drying with my Nyle kiln for 2 years now so I didnít expect any problems.  I left the slabs in the kiln for 5 months and they may have left them in longer than necessary.  The solar kiln is not kept on my property as we have too many trees.  The cherry slabs came out cupped.  We also had some 9/4 walnut and they came out perfect.  Does anyone have a possible explanation?
Vacutherm IDry, Nyle 53 Kiln, New Holland Skid Steer, Kaufman Gooseneck Trailer, Whitney 32A Planer
Offline maderahardwoods
  • California Sawyer
    • Madera Hardwoods
Re: Cupped cherry slabs from solar kiln
« Reply #1 on: January 01, 2018, 09:26:14 PM »
Do you have the slabs weighed down?
Offline Don P
    • Calculator Index
« Reply #2 on: January 02, 2018, 08:09:02 AM »
My experience with cherry is that it does like to cup while drying but is pretty stable once it gets there. Walnut is more like white pine during drying, it just lays there.
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
« Reply #3 on: January 02, 2018, 08:19:29 AM »
I find cherry tough to dry without defect.  Also, if there is sapwood on one side, I get really bad bow.  One of the worst woods for me for cracking and checking and splitting.  It ALWAYS pith cracks very badly.  I do best when it is air dried to less than 20% before finishing it off in the kiln.
Offline YellowHammer
  • Take Steps to Save Steps
    • Hobby Hardwood Alabama
« Reply #4 on: January 02, 2018, 08:20:22 AM »
WDH beat me to it.....How much sapwood?  Was it balanced on each face?  Sapwood "pull" is real bad on cherry, and can really be aggravated once the wood gets below 7%.  Pith cracks also cause a lot of cup on cherry.
HobbyHardwoodAlabama.com
Offline Glenn1
    • GPS Hardwoods
« Reply #5 on: January 02, 2018, 09:16:04 PM »
Thank you for your responses.  Iíll remember to air dry it first the next time I have cherry slabs.
« Reply #6 on: January 02, 2018, 11:00:12 PM »
Put all the weight you can on it, even hen solar kiln or air drying.  It won't stop all cup, but it certainly helps.  Didn't you make some concrete slab weights?
Offline GeneWengert-WoodDoc
« Reply #7 on: January 03, 2018, 07:05:45 AM »
Cupping is a natural tendency of flatsawn wood.  It results because the bark side shrinks more than the heart side...sometimes 25% more.
Cupping is worse when we dry slowly. In air drying, the outer cells get drier than in a kiln, so they are stronger and resist warp.  Oftentimes in the kiln we use a high humidity (higher than the 65% average humidity in air drying) which prevents the outer cells from getting very dry and not much stronger.
 If we rewet partly dried lumber, cup will be worse.  Never allow partly dried lumber to get rewetted.
Cupping is worse as the lumber gets drier.
Cupping is slightly worse if it does not have weights, but not much.
Quartersawn, perfectly Quartersawn, does not cup.
Cupping is worse as the flatsawn lumber is sawn from closer to the pith.  This means small logs will have more cupped lumber.  Logs that do not have a large tie or cant from the center will have more cup. This means lower grade lumber will cup more, as most low grade comes from near the center of the log.
Offline Glenn1
    • GPS Hardwoods
« Reply #8 on: January 03, 2018, 08:25:18 PM »
Yes, I have four 4íx4í slabs that weight 1000 lbs each.  My solar kiln is 20 Miles from our farm and Iíve been using the concrete in the DH kiln and on a stack of air dried wood.  I could use more of them.
Offline Glenn1
    • GPS Hardwoods
« Reply #9 on: January 03, 2018, 08:37:08 PM »
If this is the case, then what are the advantages to using a solar kiln?  Iíve been air drying my wood for a couple of years and then putting it into the DH when mc is around 20%.  It has worked well for me.  I built the solar kiln for live edge 9/4 slabs.  Since slabs have sap and a pith, is cupping going to be a problem with other woods?  It did not seem to affect the LE walnut.
« Reply #10 on: January 03, 2018, 10:46:08 PM »
I've been drying 9/4 in my solar kiln almost exclusively for years now.  About a dozen species.  Cherry is the worst to cup, seems like, for example that photo I took was of an air dried stack, and you can see how bad the sapwood cupped.
The solar kiln seems to do a very good job and is noticeably faster than air drying and seems keep the defects level low.  I never noticed any unusual increase in cup. Unfortunately I don't track the atmospheric data in the solar kiln.  However, I don't let I'd get very moist, I like a low and dry heat.
Offline Ianab
« Reply #11 on: January 03, 2018, 11:37:25 PM »
Quote
Cutting 21 months off your drying time is a pretty big advantage, while the setup and running costs of a solar kiln are relatively low compared to other kiln styles.
And some species of wood are just a pain to dry, no matter what method you use.
« Reply #12 on: January 03, 2018, 11:41:03 PM »
Good ol' YH knows what he is talking about for sure.  If you read what I wrote, note that it is high humidity that results in more cup, so (as YH says) keeping a solar kiln as dry as possible without causing checking is perfect.  But, this low RH cannot be done with all species...it would ruin oak.  We would have to be careful with walnut to avoid end slits and honeycomb.
Again, the sawing technique has a great influence on cupping, as mentioned.  So does small logs.  Etc.
It is next to impossible to dry a piece flat that contains the pith.
Offline WDH
« Reply #13 on: January 04, 2018, 07:34:44 AM »
The pith in cherry is a major issue.  The juvenile wood cracks and splits as bad as any species that I have dealt with.  One of the worst.
Offline Glenn1
    • GPS Hardwoods
« Reply #14 on: January 04, 2018, 08:37:32 AM »
YH, I'm intrigued about having the kiln use "dry heat".  So here's a scenario.  It's July and you just put in a load of slabs.  Humidity and heat are very high.  Using the vents, how do you avoid the hot moist heat.  This is assuming that you did not put a DH unit in the solar kiln.
« Reply #15 on: January 04, 2018, 10:24:01 AM »
The average humidity in the summer in most of the USA and Canada is 65% RH average...drier in the afternoon and more humid in the early morning.  Also, the humidity is a bit drier on a sunny day and a bit higher on a cloudy day.  This is around 12% EMC, which is considered a fairly dry condition.  So, if a solar kiln is run with the vents wide open and with no solar input, the conditions in the kiln will be quite dry indeed.  To help, the fans should be run only during the daytime, avoiding the very high humidity before sunrise.
Now, add the solar heat, and the humidity in the kiln will be even lower.  Maybe too low.
So, we partially close the vents and allow some of the evaporated moisture from the lumber to stay in the kiln and increase the humidity.  Theoretically, we can keep the vents closed and achieve 100% RH even with solar heat, so we would get no drying at all.  Practically, there are leaks in the kiln, so it is never 100% sealed.
So, a solar kiln when the wood is fairly wet can essentially run at humidities between about 50% RH to 100% RH.  The vent operation, and how well sealed the kiln is, determine if the solar kiln has the desired RH average.
Offline moodnacreek
  • Sawin by the notches
« Reply #16 on: January 04, 2018, 08:52:57 PM »
I you think cherry is bad try elm.  Overhung first and last  stickers and tons of weight helps.
« Reply #17 on: January 04, 2018, 09:28:24 PM »
Glenn1, what Doc said smiley_thumbsup
« Reply #18 on: January 05, 2018, 10:50:42 PM »
Sweet gum (Sap gum and red gum) and cottonwood are just as bad as elm....maybe sweet gum is worse.
Offline moodnacreek
« Reply #19 on: January 07, 2018, 05:54:00 PM »
Wouldn't know sweet gum or sap gum if I cut one down. Our cotton wood is quaking aspen and it does go nuts. Is red gum what we call Pepperidge with spiral grain?
