Arborwear
Author Topic: TJ 230 pinion nut removal  (Read 359 times)
Offline BurkettvilleBob
« on: January 03, 2018, 06:37:26 AM »
Any secret to removing the pinion nut on this thing. My buddy is trying to change the seal on his rear diff and says the nut won't budge. He did remove the cotter pin.
Offline bushmechanic
  • Someone else has it worse than you.
Re: TJ 230 pinion nut removal
« Reply #1 on: January 03, 2018, 10:23:21 AM »
Nope no secret procedure there. A long bar will help and you may have to hold the yoke with a big pipe wrench.
« Reply #2 on: January 03, 2018, 12:20:33 PM »
Thanks for the reply, I didn't think there was. He's just a little fella, probably needs a bigger bar.
Offline Gearbox
« Reply #3 on: January 03, 2018, 03:44:40 PM »
May have used loc tite  a little heat will fix that 300 degrees .
Offline Neilo
« Reply #4 on: January 03, 2018, 05:02:44 PM »
Long bar. Make sure blade is down so machine doesn't move. Helps if the drive and socket are able to fit out towards the tire.
Rear diff pinion seal removal rockwell PR75
Started by Mooseknuckle on Forestry and Logging
Last post May 21, 2017, 07:03:45 PM
by pdxh20
pinion for woodmizer lt40
Started by Gustavo on Sawmills and Milling
Last post August 23, 2007, 07:10:26 PM
by Gustavo
240B Timberjack ring and pinion
Started by David-L on Forestry and Logging
Last post April 20, 2017, 06:38:23 AM
by David-L
jd 3305 winch pinion brakedown
Started by marinsisovic on Forestry and Logging
Last post April 04, 2016, 07:28:13 AM
by marinsisovic
