Arborwear
Author Topic: Air drying lap siding  (Read 2236 times)
Offline Florida boy
  • Young sawyer with my first mill
« on: January 05, 2018, 11:23:11 AM »
So I am about to cut some lap siding for the pole barn I'm building. ( need to update that thread). Ive seen how most cut a cant down by wedging up one side every othe cut. Pretty much got that figured out. I wondering how people air dry it? I guess just stack it with stickers and hope if don't twist? Thanks for any advice given.
Offline Southside logger
  • Sawing so I can afford to farm.
Re: Air drying lap siding
« Reply #1 on: January 05, 2018, 11:33:49 AM »
I don't think that would work well. Personally I saw it to 1" boards, sticker and dry, then re saw them into siding. If you don't have that option then putting the siding up green may be a better option.
Perhaps running the stickers the long way would work to keep the twist out?
'92 Franklin 170 grapple skidder
'92 Franklin 5000 wheeled buncher
Wicked Awesome Basset Hound * 2
JD 490D with 4 roller FabTek processer / hydraulic hose breaker
Hot wife
Wood Mizer LT35HDG25, Re-saw attachment
Official Member of the BBFC
Offline moodnacreek
  • Sawin by the notches
« Reply #2 on: January 05, 2018, 07:34:08 PM »
With the Adirondack [aka brainstorm] siding cut from soft pine they just stick it. It warps, twists and cups but the carpenter makes it look amazingly good. I had wanted to include in my inventory and could get it inexpensive from another mill.  I never did because looks terrible dry and I know people would not buy it.  This stuff is cut 1"  at the bark to nothing at about 12". My idea was to put it on 12" sticks one row high braced up somehow.
Online bags
  • Location: Up high in the Colorado Rockies, Westcliffe ,CO.
« Reply #3 on: January 05, 2018, 08:48:34 PM »
I use 1/4" X 3/4" X the width of the siding between the angled cuts then a full length 3/4" X 3/4" stickers across the width of the stack on top of that--- repeat the next lift with 1/4" X 3/4" in the angles, and then full length on top them. Keep all the stickers "stacked" at about 16-18" apart.
Works pretty well on the spruce siding I mill up in this country where were pretty dry--- don't know how it will work down in your part of the world.
Offline moodnacreek
« Reply #4 on: January 05, 2018, 09:06:13 PM »
Bags, that sounds like good advice, extra work but that's what it takes to make a nice product.
Offline Darrel
  • Never throw an unopened log on the burn pile.
« Reply #5 on: January 05, 2018, 09:40:56 PM »
I've dried it by stacking two boards together. In other words, tilt the cant and make a cut then level the cant and make another cut and stack those two pieces of siding on top each other. I can get by with that because in the summer here the RH is <30% and as low as 10 or 12%.
1992 LT40HD
Offline btulloh
« Reply #6 on: January 06, 2018, 08:28:24 AM »
I've cut tapered lap siding from SYP and just stickered it like normal lumber.  It came out fine, but it was from nice logs with no tendency to bow or crook when it came off the saw.  I've put it up green also.  If it's got air on both sides it will do pretty well when put up green.  I do prefer to sticker and dry it for a while if possible.  Putting it up green this time of year would probably be better than doing that in the summer.
HM126
Offline Ohio_Bill
  • Wood is Good
« Reply #7 on: January 06, 2018, 11:31:18 AM »
I have put up all the horizontal lap siding green . The siding is not beveled and about 5/8 thick . We have done several houses and a lot of barns and buildings .
Bill
USAF Veteran  C141 Loadmaster
LT 40 HDD42-RA   , Allis Chalmers I 500 Forklift , Allis Chalmers 840 Loader , International 4300 , Zetor 6245 Tractor – Loader ,Bob Cat 763 , Riehl Steel Edger
Offline thecfarm
« Reply #8 on: January 06, 2018, 12:53:27 PM »
I walked by the old wood shed for years. Had clapboards on it. Or so I thought. It fell over and than I could see the ½ boards.
Offline Lawg Dawg
  • True South Sawmill Lumber
« Reply #9 on: January 06, 2018, 01:15:08 PM »
I cut straight boards and stick them like normal and install.  Face nail so you just miss the top of the board under, just like the old timers did!  :)
LT 40 Wide 999cc
John Deere 4000, Husky 268, 394xp, Shindiawa 591, 2 Railroad jacks, and a comealong.
True South Sawmill Lumber,  located  approximately 45 miles south of Charlotte, NC
Offline Ohio_Bill
  • Wood is Good
« Reply #10 on: January 06, 2018, 03:42:07 PM »
Lawg Dawg   , wonderful job of saving old  building .  Nice work Sir .
Bill
Offline Florida boy
« Reply #11 on: January 06, 2018, 06:34:30 PM »
Looks like I'll just cut 5/8 stock and nail it up no bevel. Just going to cover the top of the gable end of the shed any way.
Offline Dalrymple
« Reply #12 on: January 06, 2018, 06:59:21 PM »
3/4 minus the kerf on a manual band mill comes out about 5/8+ and easy math.  Nail it the way Lawg Dawg said.  Never understood the desire to taper it.
Offline tawilson
« Reply #13 on: January 06, 2018, 07:24:13 PM »
Well since you went that route I'll put up a pic of my first shed project. 5/8" also by 10 1/2" width a 2" overlap. That's my buddy Bob who helped me build it. He passed in October a couple weeks after we finished it.
2017 LT40HDG35 WIDE
« Reply #14 on: January 06, 2018, 09:23:36 PM »
[/quote]
[/quote]
The fact you use half the fiber to produce the same liner foot of coverage means that profit per unit is greater to the mill.  I sell tapered siding for less than non tapered and even with the additional work it is more profitable for me due to the fact I get almost twice the linear footage with the same board footage.
Hot wife
Offline carykong
  • Installing my roof ridge metal
    • Have Mill Will Travel
« Reply #15 on: January 06, 2018, 10:30:04 PM »
For small personal projects probly not worth your time to bevel and air dry. I just cut 5/8 thick and nail up green with 1.5” overlap.  Wait for siding to cure before final finish coat.
Offline Brucer
  • The Kootenay Sawyer - retired (for now)
« Reply #16 on: January 07, 2018, 01:07:53 AM »
I saw 5/8" x 8 exactly as Ohio_Bill and Lawg Dawg do. I stack it with 5/8" thick stickers spaced on 32" centres and let it air dry until I'm ready to use it.
... I cut straight boards and stick them like normal and install.  Face nail so you just miss the top of the board under, just like the old timers did!  :)
When you face nail this way, you can put the boards up green and let them shrink as they dry. Because there's only one row of nails through each board, there's no danger of the boards being pulled apart as they shrink.
Bruce    LT40HDG28 bandsaw with two 6' extensions.
Offline btulloh
« Reply #17 on: January 07, 2018, 08:14:33 AM »
Put the the bark side towards the inside.
Offline 78NHTFY
  • I'm old!
« Reply #18 on: January 07, 2018, 01:24:56 PM »
have posted b4 about cutting lap siding: I cut straight (no taper), dropping the head 1/2" each time to yield 3/8" boards.  I sticker and they dry in no time.  I did a test of tapered and straight: after stickering, I lost over 50% of tapered clapboards to warping, less than 10% with the straight clapboards.  Have used the lap siding (straight clapboards) on my house and new addition.  Works great.  Just make sure corner boards are 1" thick after planing so lapped clapboard isn't sticking past cornerboard.  All the best, Rob.
If you have time, you win….
Offline moodnacreek
« Reply #19 on: January 07, 2018, 05:17:09 PM »
There sure is more than one way to skin a cat.  On the homestead where I came from the siding was lapped , horizontal 6" tulip boards 4" to the weather not tapered. Each board had a very wide 'V' relief or notch cut on the back side to lay flat on the board under it. This siding was a finished product and at least 100yrs. old, painted many times. There are older houses just outside new York city that have wane edge lapped siding on the gable end ,painted. It's funny to see this in a rather formal area.
drying lap siding
Started by steve phillips on Sawmills and Milling
Last post July 27, 2012, 11:28:39 PM
by Planman1954
Drying beveled siding
Started by millwright on Drying and Processing
Last post September 25, 2015, 10:23:27 PM
by GeneWengert-WoodDoc
2 Part ?? Siding attachment for mill & Is pine a good choice for house siding?
Started by Piston on Sawmills and Milling
Last post May 24, 2015, 12:19:50 PM
by Piston
ERC siding & siding in general
Started by TexasTimbers on General Board
Last post May 08, 2007, 07:28:26 AM
by Cedarman
