Baltic Abrasives Technologies
Author Topic: Tractor tie down points  (Read 2419 times)
Offline maple flats
  • Life is what you make it!
Re: Tractor tie down points
« Reply #20 on: January 07, 2018, 10:34:05 AM »
Read the requirements as stated by DOT and your dept. of motor vehicles, which ever is stricter. Then it helps to have a copy of that section in your glove box, because many law enforcement officers write tickets because they mis read the law.
Offline Corley5
  • Wolverine, Michigan
    • Whittaker Farms
« Reply #21 on: January 07, 2018, 10:39:44 AM »
I don't think twisting the chain and putting a binder on both sides will pass inspection.  Maybe on a light load :-\?  From my understanding a chain and binder is required on each corner of the load.  Just twisting the chain doesn't meet that requirement.
Offline square1
« Reply #22 on: January 07, 2018, 11:12:47 AM »
As teakwood correctly ponted out, my 4000 pound tractor doesn't require a chain (or binder) twisted or not.
Offline Corley5
    • Whittaker Farms
« Reply #23 on: January 07, 2018, 11:40:58 AM »
Has an MiDOT officer told you that ??? :)
Offline square1
« Reply #24 on: January 07, 2018, 12:49:30 PM »
Somebody spit in your cheerios this morning?
 MDOT (not MiDOT) involvement stops at permitting oversize loads. MSP & USDOT regulations apply to load securement. Those regs only require chains and binders at each corner of wheeled / tracked equipment => 10,000 pounds.
/done
Offline Corley5
    • Whittaker Farms
« Reply #25 on: January 07, 2018, 01:03:35 PM »
  I don't like Cheerios ;D
  Codes are just a minimum requirement.  Just because it says that's all that's required doesn't mean that more isn't better. Just like a building code that calls for 2X4s doesn't mean that 2X6s aren't better ;D  We hauled antique tractors all over the US and out of Canada for several years and always used lots of chains and binders.  A Farmall H for example weighs 3875 lbs dry.  We put a chain and binder at four corners of one.  I'd rather be extra secure.
Offline starmac
« Reply #26 on: January 07, 2018, 04:02:48 PM »
Right along with that regulation that requires 4 chains for rolling stock 10,000 pounds and more, it requires 2 chains for under 10,000.
I have never, ever seen a trucker using straps on rolling stock other than light vehicles with the saddle straps that cradle the tires.
Even when I hauled utility trailers, those that had the tires on them were chained, without were strapped.
Straps will take paint off too, hauling new tractors, we used pieces of carpet under the chains, the same with hauling new trailers with straps.
Offline square1
« Reply #27 on: January 07, 2018, 06:20:48 PM »
Chain may be a best practice and in some instances (heavy equipment) the only tiedown system with a working load limit capable of meeting regulation but it is not the letter of the law.  Nether the regulation for <10,000 nor the one for =>10,000 lbs. specify chain, both simply state "tie downs". Appendix A, default WLL for unmarked tiedowns, lists everything from manilla rope to grade 100 chain including synthetic strapping. One 2" strap on the front and one 4" on the rear would be required for my 4,000 pound tractor. Would I do that? No. It would however be legal.
Offline starmac
« Reply #28 on: January 07, 2018, 07:11:56 PM »
Regardless of the law, I always used at least 3 chains on a tractor, reason being, I wanted at least one end to be cross chained. When I hauled new tractors, they generally dictated where the chains would be, and the number of them, 3 chains were always dictated on the lighter ones I hauled, they supplied the padding when needed.
Offline lopet
  • Do not climb any higher your comportable falling !
« Reply #29 on: January 07, 2018, 08:22:59 PM »
I was just waiting for that.  :) This is a little off topic, but isn't it funny how  a few letters ( I know it's four in this case ) can make a total different meaning out of something.  Sorry for yanking your chain square 1, just couldn't resist.
Offline square1
« Reply #30 on: January 08, 2018, 05:17:10 AM »
Are you sure it's a chain and not a strap? ;)
How do you set points?
Started by Mac 6-10 on Chainsaws
Last post November 13, 2013, 01:16:17 PM
by Al_Smith
Points gap
Started by Faron on General Board
Last post February 02, 2008, 08:52:02 PM
by olyman
How to geografical points?
Started by LeeB on General Board
Last post February 11, 2012, 12:51:29 AM
by Brucer
Jonsered 621 points
Started by husky2100 on Chainsaws
Last post March 21, 2014, 06:52:11 AM
by shinnlinger
