KNOW WHAT?
Between February 12, 2018 and June 18, 2018, this space displayed 13 Million, 871 Thousand and 87 times.
BRUTE FORCE Authorized Dealer
Council Tool
Author Topic: HELP! circle mill..no name. Backwards?  (Read 2084 times)
Offline StoneCreek
  • Reap what you sew.
« on: January 05, 2018, 11:49:11 PM »
I come from a large family who operated a community saw mill for 3/4 of the 20th century. I was too young to actually be around it when it became obsolete, shut down, sold off, and long gone. I am a builder and have always had a wood shop and made things.. I had a band saw briefly years ago. Wasn't impressed..really! I have always wanted a circle mill. I think it's just in my blood.
So. Last Saturday, I bought a decent setup at an auction. But was not present. Haha. Looked good in pic. Long story short. Somebody threw some John Deere green and yellow on it and well. Let's say, it needs a little TLC. But I'm in no hurry.
What I know about it...It has the letter "V" in the casting. There are no other markings or identifications. It's PTO SHAFT driven. The sawyer position and the whole direction of the feed of the saw seems to be backward of EVERYTHING I've watched, seen pics of, or read about.
Can someone help me out?
Offline JB Griffin
Re: HELP! circle mill..no name. Backwards?
« Reply #1 on: January 06, 2018, 12:13:50 AM »
What you have is a left hand mill. Somewhat common, not unheard of. Other than that I can tell you nothing, good luck.
2000 LT40hyd remote 33hp Kubota, 160 Prentice, Frick 2 saw gang edger, Wright W-37 ABG, Suffolk dual tooth setter, Cat claw single tooth setter,'96 F-250 7.3 PSD 4x4, CS-590 Echo, MF 20c, M681 Memo.
1.8 million bdft sawn with a Baker Dominator and counting.
Offline longtime lurker
« Reply #2 on: January 06, 2018, 05:38:09 AM »
Nothing wrong with a lefty. Your PTO hookup, does it have a gear box or twist belt or similar? Standard tractor PTO's turn the wrong way to drive a left hand mill and you need to be able to reverse the rotation, most left hand mills tend to be run off stationary motors.
Bad information about rotation direction. I knew that a mill was easily configured for PTO on one hand and required a rotational direction change for the other. I just got them wrong. Easy to tell I'm not used to PTO drives huh? Thanks to those who corrected me.
Offline Rigg
« Reply #3 on: January 06, 2018, 05:51:07 AM »
Looks like a JA Vance setworks.  I'm sure someone will know for sure.
Offline Chuck White
  • Sawing Mobile since 2005
« Reply #4 on: January 06, 2018, 06:55:44 AM »
Welcome to the Forestry Forum, StoneCreek!
~Chuck~
1995 Wood-Mizer LT40HDG2425 Kohler - Shingle & LapSider, Cooks Cat Claw Sharpener, 4-foot Logrite cant hook.
Basic mechanical skills are all that's required to maintain the Wood-Mizer.
I LOVE MY SAWMILL
Offline StoneCreek
« Reply #5 on: January 06, 2018, 10:57:49 AM »
Thank you for the comments and welcoming.  Despite single digit temps, I went out to the farm and took some better pics.  I will post those.  I was coming to the conclusion it was a "lefty". How much work would it take to change it to a right hand.  What do you all think of the carriage and the way it's set up otherwise, other than the logs taken out from under it and put on it to saw! lol Any and all help very much appreciated. I know nothing so...
Offline StoneCreek
« Reply #7 on: January 06, 2018, 11:09:37 AM »
Offline StoneCreek
« Reply #8 on: January 06, 2018, 11:12:01 AM »
It has a 42" blade and I would really like to know more about it specifically if anyone can help there. Maybe a place I could take it within 100 miles of Knoxville to have it hammered and buy the correct teeth.
Offline StoneCreek
« Reply #9 on: January 06, 2018, 11:16:06 AM »
Offline Corley5
  • Wolverine, Michigan
    • Whittaker Farms
« Reply #10 on: January 06, 2018, 11:39:47 AM »
Right hand mills turn the wrong direction to be powered directly from a tractor PTO.  Left hand mills can have the PTO shaft hooked directly to the mandrel.
Offline StoneCreek
« Reply #11 on: January 06, 2018, 12:01:12 PM »
CORLEY5. Oh I see.  Is that your tractor driving a mill? Do you have pics of the mill?
Offline Ron Wenrich
  • Forester
« Reply #12 on: January 06, 2018, 12:05:14 PM »
Nothing wrong with a left handed mill.  I sawed on one for 25 yrs.  To switch over, you would probably have to reverse your pulley system, and that would be a job.
What are you intending to saw on the mill?  How much?  Your maximum depth of cut on that blade would be around 16-17".
Offline Corley5
    • Whittaker Farms
« Reply #13 on: January 06, 2018, 12:08:42 PM »
That's mine :)  It's been disassembled, moved and is in storage awaiting reassembly.  There's pics in my gallery  http://www.forestryforum.com/gallery/thumbnails.php?album=246&page=1  I have a second left hand Corley 5 that we hauled home from south central Missouri.
Offline StoneCreek
« Reply #14 on: January 06, 2018, 12:35:11 PM »
Ron, yeah its a small blade.  I probably will look into a larger diameter.  I have a 70 horse 282 Massey I am going to pull it with.  What came on it, so I may saw some smaller soft wood until then
Offline moodnacreek
  • Sawin by the notches
« Reply #15 on: January 06, 2018, 05:43:36 PM »
Somewhere I'v seen the 2 reach rods before, maybe in C.H.Wendell,s book 'circular sawmills. Your saw looks like a style 3. That mill being a l\h could be tractor pto driven  like in the post with the IH tractor. The saw would have to be happy at 500rpm.
Offline Corley5
    • Whittaker Farms
« Reply #16 on: January 06, 2018, 07:14:13 PM »
Style 3s have two holes in the shank for the wrench pins.  I think you may have a 2 1/2.
http://www.simondsint.com/circularsaws/Pages/products.aspx?SITerm=701b714f-be4e-42d7-8db7-6d196e8fc8c9
Offline dgdrls
  • Learning the Art of Milling Logs, Lucas 8/27
« Reply #17 on: January 06, 2018, 07:41:00 PM »
Offline moodnacreek
« Reply #18 on: January 06, 2018, 08:43:28 PM »
Sorry about that style 3 comment. That would be 2 1/2.     When Simonds made style 3 super shanks they only had 1 hole but these are seldom seen.
Offline StoneCreek
« Reply #19 on: January 06, 2018, 09:02:23 PM »
I'm thinking 3 style with a regular bit..
Offline StoneCreek
« Reply #20 on: January 06, 2018, 09:06:15 PM »
OH! I see the hole is kinda centered in the apex of the arch.
So am I going to be able to replace these things or no?
Offline Corley5
    • Whittaker Farms
« Reply #21 on: January 06, 2018, 11:26:22 PM »
Menominee Saw, a forum sponsor over on the left, will set you right up :) 8)
Offline Ron Wenrich
  • Forester
« Reply #22 on: January 07, 2018, 07:01:12 AM »
You'll need a saw wrench to take out the shanks.  I always sprayed mine down with a penetrating oil like Rust Reaper and let it sit for a while.  Makes it easier to take them out.  I also always had extra pins handy for the wrench.  They break at inopportune times.
Offline StoneCreek
« Reply #23 on: January 07, 2018, 01:25:17 PM »
Okay...UPDATE! I've found MORE numbers! AND letters!  So, in other words, the "V" I referenced in the first few posts was NOT an initial for a name.. The "v" is on the head blocks.  There is a "B 40" on the mandrel. There is an "N 289" on one side of the head block adjustment lever and an "N 290" on the other side of the same lever.  SO.. My thoughts are, this was a kit.  All the pieces were labeled and it was put together.  I still can't find and names.  I did find numbers on the bits, and shanks.  IT IS a 2 1/2 shank regular.  However, there are several sizes of bits in the shanks.  I found #8's, #9's, and atleast one #10 bit in it. Pretty sure that wont work...well. It has 44 teeth and is 42" in diameter.  I also found numbers near the eye of the saw.
Offline dgdrls
« Reply #24 on: January 07, 2018, 03:01:07 PM »
2-1/2 pattern is the smallest gullet, thus more teeth.  You'll want to
get set-up with a matched set of bits and shanks.
What was the number at the saw eye?.
Best
D
Offline Ron Wenrich
  • Forester
« Reply #25 on: January 07, 2018, 04:30:21 PM »
Numbers on the saw should give you how the saw was originally manufactured.  They usually include a L or R to indicate how it was originally hammered.  Also will have a RPM number, and a serial number.
The numbers on the carriage and the like may be that you have parts of a bunch of mills that are put together to make a mill.  Nothing wrong with that, as most mills function the same.  Usually a mfg had all their parts start with a letter that signifies the company.  I don't know where you would find that listing.
Offline StoneCreek
« Reply #26 on: January 07, 2018, 09:16:13 PM »
Numbers on the saw
Offline doghunter
« Reply #27 on: January 07, 2018, 09:35:37 PM »
That's actually a really good mill to drive directly from a tractor pto. just hook the pto shaft directly to the mandrel.The saw is a 2&1/2 pattern it's a pine saw perfect for sawing medium sized pine logs. bits and shanks are readily available If you change saws the new saw will have to be hammered for a left hand mill.Good luck.
Offline JB Griffin
« Reply #28 on: January 07, 2018, 11:00:04 PM »
From what I can make out thats a 8/9 gauge saw. I don't know what the other number is.
Offline Darrel
  • Never throw an unopened log on the burn pile.
« Reply #29 on: January 08, 2018, 11:06:56 AM »
Welcome to the forum StoneCreek!  Looks like you have a very nice mill!
1992 LT40HD
Offline StoneCreek
« Reply #30 on: January 08, 2018, 08:12:07 PM »
What's the difference in regular and long tip saw bits?
Offline StoneCreek
« Reply #31 on: January 08, 2018, 08:22:23 PM »
And chrome?
Offline Ron Wenrich
  • Forester
« Reply #32 on: January 09, 2018, 05:56:48 AM »
There is a bit more steel on the long bit over the regular bit.  I went with a long bit right after they first came out.  They lasted a few more sharpenings, and they didn't need to be swaged.  They also stood up better to debris without breaking off corners.
Chrome is coated on the bits and they stay sharper for a longer time.  The problem with them is you when you need to sharpen, you will have to grind the plating off on the first sharpening.  After that, you'll be able to use a hand file.  But, the chrome will be hard on the files.  It sounds nice, but I'm not sure it is cost effective, especially for a small mill.  I used chrome on my edger saws.  I flipped back and forth with using chrome on my head saw.  But, I had a grinder to help in saw maintenance.
On your saw numbers, the 8 and 9 are the gauge of the saw.  The 9 is at the eye, and the 8 is on the rim, if I'm not mistaken.  I would think the other numbers are probably some sort of serial number.
Offline moodnacreek
« Reply #33 on: January 09, 2018, 08:10:39 AM »
The problem with long bits is the manufacturing. They are some times distorted off to one side and not repairable.  Chrome is my favorite [in regular] used with super shanks. I file with a diamond file mounted in a hack saw frame and use the Dexter file guide. Although I have several electric grinders and use them also, the file guide is more accurate. When the chrome bits get narrow I swage and side file, otherwise it wouldn't  pay. Your 2 1/2 saw may need stand all bits to get started.  Does your mandrel have babit  bearings?
Can band mill blades be run "backwards"?
Started by Joe Hillmann on Sawmills and Milling
Last post April 05, 2014, 10:20:04 AM
by barbender
Why are there more smaller Band Mill operators here then circle mill?
Started by MaddiesDad on Sawmills and Milling
Last post March 05, 2009, 03:18:06 PM
by TexasTimbers
Circle Mill
Started by Chuck White on For Sale
Last post February 13, 2009, 05:39:56 PM
by semologger
circle mill ?
Started by tbish on Sawmills and Milling
Last post February 22, 2013, 09:59:48 PM
by jimparamedic
