Author Topic: HELP! circle mill..no name. Backwards?  (Read 2350 times)
Offline StoneCreek
  • Reap what you sew.
Re: HELP! circle mill..no name. Backwards?
« Reply #20 on: January 06, 2018, 09:06:15 PM »
OH! I see the hole is kinda centered in the apex of the arch.
So am I going to be able to replace these things or no?
Online Corley5
  • Wolverine, Michigan
    • Whittaker Farms
« Reply #21 on: January 06, 2018, 11:26:22 PM »
Menominee Saw, a forum sponsor over on the left, will set you right up :) 8)
Offline Ron Wenrich
« Reply #22 on: January 07, 2018, 07:01:12 AM »
You'll need a saw wrench to take out the shanks.  I always sprayed mine down with a penetrating oil like Rust Reaper and let it sit for a while.  Makes it easier to take them out.  I also always had extra pins handy for the wrench.  They break at inopportune times.
Offline StoneCreek
« Reply #23 on: January 07, 2018, 01:25:17 PM »
Okay...UPDATE! I've found MORE numbers! AND letters!  So, in other words, the "V" I referenced in the first few posts was NOT an initial for a name.. The "v" is on the head blocks.  There is a "B 40" on the mandrel. There is an "N 289" on one side of the head block adjustment lever and an "N 290" on the other side of the same lever.  SO.. My thoughts are, this was a kit.  All the pieces were labeled and it was put together.  I still can't find and names.  I did find numbers on the bits, and shanks.  IT IS a 2 1/2 shank regular.  However, there are several sizes of bits in the shanks.  I found #8's, #9's, and atleast one #10 bit in it. Pretty sure that wont work...well. It has 44 teeth and is 42" in diameter.  I also found numbers near the eye of the saw.
Offline dgdrls
  • Learning the Art of Milling Logs, Lucas 8/27
« Reply #24 on: January 07, 2018, 03:01:07 PM »
2-1/2 pattern is the smallest gullet, thus more teeth.  You'll want to
get set-up with a matched set of bits and shanks.
What was the number at the saw eye?.
Best
D
Offline Ron Wenrich
« Reply #25 on: January 07, 2018, 04:30:21 PM »
Numbers on the saw should give you how the saw was originally manufactured.  They usually include a L or R to indicate how it was originally hammered.  Also will have a RPM number, and a serial number.
The numbers on the carriage and the like may be that you have parts of a bunch of mills that are put together to make a mill.  Nothing wrong with that, as most mills function the same.  Usually a mfg had all their parts start with a letter that signifies the company.  I don't know where you would find that listing.
Offline StoneCreek
« Reply #26 on: January 07, 2018, 09:16:13 PM »
Numbers on the saw
Offline doghunter
« Reply #27 on: January 07, 2018, 09:35:37 PM »
That's actually a really good mill to drive directly from a tractor pto. just hook the pto shaft directly to the mandrel.The saw is a 2&1/2 pattern it's a pine saw perfect for sawing medium sized pine logs. bits and shanks are readily available If you change saws the new saw will have to be hammered for a left hand mill.Good luck.
Offline JB Griffin
« Reply #28 on: January 07, 2018, 11:00:04 PM »
From what I can make out thats a 8/9 gauge saw. I don't know what the other number is.
2000 LT40hyd remote 33hp Kubota, 160 Prentice, Frick 2 saw gang edger, Wright W-37 ABG, Suffolk dual tooth setter, Cat claw single tooth setter,'96 F-250 7.3 PSD 4x4, CS-590 Echo, MF 20c, M681 Memo.
Over 2 million bdft sawn with a Baker Dominator and counting.
Offline Darrel
  • Never throw an unopened log on the burn pile.
« Reply #29 on: January 08, 2018, 11:06:56 AM »
Welcome to the forum StoneCreek!  Looks like you have a very nice mill!
1992 LT40HD
Offline StoneCreek
« Reply #30 on: January 08, 2018, 08:12:07 PM »
What's the difference in regular and long tip saw bits?
Offline StoneCreek
« Reply #31 on: January 08, 2018, 08:22:23 PM »
And chrome?
Offline Ron Wenrich
« Reply #32 on: January 09, 2018, 05:56:48 AM »
There is a bit more steel on the long bit over the regular bit.  I went with a long bit right after they first came out.  They lasted a few more sharpenings, and they didn't need to be swaged.  They also stood up better to debris without breaking off corners.
Chrome is coated on the bits and they stay sharper for a longer time.  The problem with them is you when you need to sharpen, you will have to grind the plating off on the first sharpening.  After that, you'll be able to use a hand file.  But, the chrome will be hard on the files.  It sounds nice, but I'm not sure it is cost effective, especially for a small mill.  I used chrome on my edger saws.  I flipped back and forth with using chrome on my head saw.  But, I had a grinder to help in saw maintenance.
On your saw numbers, the 8 and 9 are the gauge of the saw.  The 9 is at the eye, and the 8 is on the rim, if I'm not mistaken.  I would think the other numbers are probably some sort of serial number.
Offline moodnacreek
  • Sawin by the notches
« Reply #33 on: January 09, 2018, 08:10:39 AM »
The problem with long bits is the manufacturing. They are some times distorted off to one side and not repairable.  Chrome is my favorite [in regular] used with super shanks. I file with a diamond file mounted in a hack saw frame and use the Dexter file guide. Although I have several electric grinders and use them also, the file guide is more accurate. When the chrome bits get narrow I swage and side file, otherwise it wouldn't  pay. Your 2 1/2 saw may need stand all bits to get started.  Does your mandrel have babit  bearings?
Can band mill blades be run "backwards"?
Started by Joe Hillmann on Sawmills and Milling
Last post April 05, 2014, 10:20:04 AM
by barbender
Why are there more smaller Band Mill operators here then circle mill?
Started by MaddiesDad on Sawmills and Milling
Last post March 05, 2009, 03:18:06 PM
by TexasTimbers
Another Circle mill
Started by kyihcman on Sawmills and Milling
Last post September 01, 2016, 10:42:15 AM
by DMcCoy
Old circle mill
Started by gms1911 on Sawmills and Milling
Last post December 23, 2017, 02:26:57 PM
by moodnacreek
