Arborwear
Author Topic: My homemade log arch. Design upgrades and paint  (Read 5959 times)
Offline Kwill
  • Cedar cutter
« on: January 06, 2018, 06:23:34 PM »
Got the log arch finished up today other than painting. Took it out to see just how well it would work. Hauled 2 cedar logs in with it and it worked great. The winch worked really good and didn't struggle at all. I'm going to make a few changes now that I've seen it with a log on. My front bars to keep the log from moving around needed to be longer. And now i can make my chains the right lengths. All in all a great project that worked out well.
Built my own log arch
In the process of building my sawmill
Offline moosehunter
  • Every once in a while
    • Saw it Coming
Re: My homemade log arch. First log pics
« Reply #1 on: January 06, 2018, 06:33:20 PM »
That looks like it would handle a pretty big log. Nice .
If it is true that we learn from our mistakes, I must be Brilliant!
Offline Kbeitz
  • Never enough time...
    • My Hobbies
« Reply #2 on: January 06, 2018, 06:38:34 PM »
I think your going to like that....
Love machine shop work
and Wood work shop work
And now a saw mill work
Online thecfarm
« Reply #3 on: January 06, 2018, 06:41:27 PM »
I always have to tear my eyes away from from that nice tractor.
Offline dbroswoods
« Reply #4 on: January 06, 2018, 07:28:08 PM »
Nice arch that will really be handy. Looks like you did a real nice job building it.
Offline Kwill
  • Cedar cutter
« Reply #5 on: January 06, 2018, 07:45:32 PM »
Thanks guys. Its not perfect but it will get the job done. I will be mostly using it to haul in cedar logs about the size of the 2nd log I brought in. I will use it bringing in fire wood logs too so i don't have to handle the wood so many times.
Offline Kwill
  • Cedar cutter
« Reply #6 on: January 06, 2018, 08:09:33 PM »
I really like that little tractor. Don't know how I did without it. Its nice not having to borrow the neighbors tractors anymore. I've done quite a few upgrades to it that have improved it greatly.
Offline JB Griffin
« Reply #7 on: January 06, 2018, 09:05:21 PM »
Did you add power steering to that little Ford?
2000 LT40hyd remote 33hp Kubota, 160 Prentice, Frick 2 saw gang edger, Wright W-37 ABG, Suffolk dual tooth setter, Cat claw single tooth setter,'96 F-250 7.3 PSD 4x4, CS-590 Echo, MF 20c, M681 Memo.
1.8 million bdft sawn with a Baker Dominator and counting.
Offline Kwill
  • Cedar cutter
« Reply #8 on: January 06, 2018, 10:05:30 PM »
Not yet. I have thought about it. Not to hard to do.
Offline WV Sawmiller
    • Green's Sawmill Services
« Reply #9 on: January 06, 2018, 10:10:21 PM »
   Good looking rig. Well done. I hope it does everything you want/need it to do. I still need to get me a good set of tongs.
Offline JB Griffin
« Reply #10 on: January 06, 2018, 11:12:25 PM »
Ya, without it loader work is a workout.
Offline Kwill
  • Cedar cutter
« Reply #11 on: January 06, 2018, 11:59:29 PM »
Thats what everyone says but I've done a lot of loader work with it and it isn't that bad.
Offline kelLOGg
  • Still learning more than I'm teaching
« Reply #12 on: January 07, 2018, 06:35:40 AM »
Nice job. Looks a lot like mine, tractor, too.
Bob
Cook's MP-32, 16HP, 20' (modified w/ power feed, up/down, loader/turner)
DH kiln, CatClaw, setter, tandem trailer, log arches, tractor, thumb tacks
Offline Peter Drouin
    • A&P Saw mill LLC
« Reply #13 on: January 07, 2018, 07:02:49 AM »
Good job, 8)
2008 LT40 super,2008 edger, Cat telahandler, JD 5410 And can cut up to 45' long
http://www.forestryforum.com/sanbornton     NH Timberland Owners Association supporter.
And a license NH soft wood grader.
Sawing since 1987
Offline Farm29
« Reply #14 on: January 07, 2018, 09:06:08 AM »
Good work paints over rated then if you want to add something later you have to grind it off  :). Having your own tractor is a lot nicer then borrowing I've down a lot of things the hard way so I don't have to borrow.  What are your plans with the cedar ?
96 lt40 Hyd 24 hp onan
460 rancher
Online thecfarm
« Reply #15 on: January 07, 2018, 09:10:26 AM »
My logging stuff don't get no paint. The metal I use is prepainted,I think it's called Rusted Brown.  :D
Online Crusarius
  • Lost in....
    • RockModified.com
« Reply #16 on: January 07, 2018, 10:44:58 AM »
Looking at the first pic I think it would be nice to make some type of cable system that connects to the 3 pt hitch for lifting the front of the log. I don't know whether it be helpful or a hindrance. But I like to come up with crazy ideas that nobody thinks will work :)
I do like the arch to :)
I knew what I thought I meant.
Offline Kwill
  • Cedar cutter
« Reply #17 on: January 07, 2018, 07:55:02 PM »
The cedar I'm going to mill when I get my mill built.
Offline Kwill
  • Cedar cutter
« Reply #18 on: January 07, 2018, 07:57:28 PM »
The arch will lift the whole log off the ground no need for the 3 point set up
Offline Darrel
  • Never throw an unopened log on the burn pile.
« Reply #19 on: January 08, 2018, 11:56:03 AM »
I like it! 8)
1992 LT40HD
Log Arch ready for paint
Started by Bucksaw on Sawmills and Milling
Last post January 25, 2017, 09:12:59 PM
by Darrel
Log arch design question
Started by NCDiesel on Sawmills and Milling
Last post April 25, 2013, 07:39:28 AM
by bandmiller2
Log Arch Design Critique
Started by Jjoness4 on Sawmills and Milling
Last post January 30, 2017, 07:39:21 AM
by Jjoness4
Looking for Design Input on my New Arch (updated with pics)
Started by ickirby on Forestry and Logging
Last post March 22, 2010, 08:08:31 AM
by tonto
