Baltic Abrasives Technologies
Author Topic: Late 80s Stihl Wood Boss wont run when hot  (Read 793 times)
Offline Roy H
« on: January 06, 2018, 09:00:11 PM »
I recently purchased an older Stihl 028 Wood Boss. For the first 10 minutes the saw runs like a pro. Then once hot, it wont run. Needing help on the problem. Thanks.
Offline starmac
Re: Late 80s Stihl Wood Boss wont run when hot
« Reply #1 on: January 06, 2018, 09:28:27 PM »
Possibly a tank vent problem?
Offline Roy H
« Reply #2 on: January 07, 2018, 10:15:45 AM »
Where is the tank vent located. I will try the gas cap trick later when out cutting. This saw is prior to the New EPA rules
Offline ZeroJunk
« Reply #3 on: January 07, 2018, 10:43:29 AM »
It most likely has a small diameter hose coming out of the tank on the left side top and slipping through a small hole in the carb housing toward where the spark plug wire comes up. Will have a worm screw in it. You can take the screw out and clean it.
Could also be the ignition coil/ module failing when it gets hot.
Offline celliott
« Reply #4 on: January 07, 2018, 10:57:09 AM »
Yup sounds like an ignition coil or tank vent problem. To test, when the saw stops running, crack the gas cap open. If it runs after that, tank vent is faulty. To test the coil, as soon as it dies, pull the sparkplug and test for spark. Careful the plug will be hot.
Chris Elliott
Clark 666C cable skidder
265rx clearing saw
Offline PAmizerman
  • Just Another Day In Paradise!!
« Reply #5 on: January 07, 2018, 11:40:05 AM »
My dad's 041 would do that. Installed a new carburator and fixed the problem.
Hydraulics everywhere
Traverse 6035 telehandler
WM bms250 sharpener
WM bmt250 setter
Offline limbwood
« Reply #6 on: January 07, 2018, 02:55:46 PM »
i think some of the early ones had points and condenser, you can put a nova chip in to fix that.
Offline loganworks2
« Reply #7 on: January 07, 2018, 08:32:41 PM »
My 041 would act like that. I put on new gas line, cleaned the carb, replaced the points and condenser cleaned the tank vent. It still would begin to die after running great for a few cuts. Could not figure it out and decided to change the plug. That did it the plug was breaking down after a few minutes of running.
stihl 028 wood boss
Started by crose on Chainsaws
Last post January 16, 2004, 04:48:21 PM
by Fish
Old Stihl 028 Wood Boss Bar Oiler Problem
Started by adam3654 on Chainsaws
Last post June 25, 2014, 02:42:47 PM
by adam3654
Put in a toilet got a Stihl 028 Super Wood boss
Started by Rusticcreations on Chainsaws
Last post June 08, 2016, 09:41:23 AM
by Mad Professor
question
Question about repair for my Stihl 029 Wood Boss
Started by Jim Spencer on Chainsaws
Last post January 09, 2008, 07:57:37 PM
by Jim Spencer
