KNOW WHAT?
Between February 12, 2018 and June 18, 2018, this space displayed 13 Million, 871 Thousand and 87 times.
Author Topic: f 250  (Read 2521 times)
Offline coxy
f 250
« on: January 07, 2018, 11:18:30 AM »
I have a 16 f 250 gas this morning the speedo didn't work and the mileage counter didn't work after about 7m the speedo started working and about 40m later the mileage counter started working anyone have an idea what it maybe
Online sandhills
Re: f 250
« Reply #1 on: January 07, 2018, 12:12:43 PM »
Sorry I can't give you a better answer but right now I blame everything on the cold  :)
Offline Kbeitz
  • Never enough time...
    • My Hobbies
Re: f 250
« Reply #2 on: January 07, 2018, 12:38:06 PM »
If it's still built like the old ones the cable spins a magnet. There is a cup around
the magnet. The cup gets dragged along by the spinning magnet. If it gets cold
enough the cup wont move. If the cup doesn't move the needle doesn't move.
Love machine shop work
and Wood work shop work
And now a saw mill work
Offline 21incher
Re: f 250
« Reply #3 on: January 07, 2018, 12:45:31 PM »
You answered your own question. It's a FORD. ;D ;D ;D
I had a new 89 F250 460 that did something like that. When you stepped on the brakes the dash went wild. Ford had 2 techs tear every wire harness on the truck open and after 2 days they found a short in one of them.  :)
Hudson HFE-21 on a custom trailer, Deere 4100, Kubota BX 2360, Echo CS590 & CS310, home built wood splitter, home built log arch, and a Logrite cant hook.
Offline moosehunter
  • Every once in a while
    • Saw it Coming
Re: f 250
« Reply #4 on: January 07, 2018, 12:47:31 PM »
No cable on a 2016. Either the speed sensor (it may use the abs system ) or the instrument cluster.
If it is true that we learn from our mistakes, I must be Brilliant!
Offline moosehunter
    • Saw it Coming
Re: f 250
« Reply #5 on: January 07, 2018, 12:57:42 PM »
Coxy, I see you are in NY. United Radio in Syracuse can rebuild/repair your instrument cluster if it isn't still under warranty.
By the way, over the years I have sent 10 times as many chevy clusters out for repair than all the other brands combined.
Online Dave Shepard
  • Geometrically proportional
    • My homepage
Re: f 250
« Reply #6 on: January 07, 2018, 01:04:10 PM »
You must not work on S series Internationals. :D
Offline coxy
Re: f 250
« Reply #7 on: January 07, 2018, 01:18:18 PM »
ummmm i unplugged the worthless abs and traction control :o maybe that's what is wrong  21 I would walk before buying another shipv or a dog  :D :D
Offline POSTON WIDEHEAD
  • Getting old but doing it with Friends.
Re: f 250
« Reply #8 on: January 07, 2018, 01:42:21 PM »
I think its just the cold weather Coxy.
Where's the Spoon?
Offline coalsmok
Re: f 250
« Reply #9 on: January 07, 2018, 07:40:20 PM »
Speedometer works off of the rear ABS sensors.  Had mine cut once lost everything until they were fixed
Offline newoodguy78
Re: f 250
« Reply #10 on: January 07, 2018, 10:22:43 PM »
Is it a possibility the sensor got a taste of all that. NYS road salt? That dang stuff wrecks everything
Offline rospaw
Re: f 250
« Reply #11 on: January 07, 2018, 10:27:13 PM »
Happened on mine with all you listed and the fuel gauge. Found out it was the button to reset the mileage. It sometimes hangs up and does not come out. Press it and let it "flick" back.
P.S. GOOD choice on the Ford!
Online Bruno of NH
Re: f 250
« Reply #12 on: January 08, 2018, 05:47:15 AM »
They gm clusters have gone out on 3 of my trucks
Fun stuff
thomas 8013 mill ,Mahindra 3540 cab tractor loader  Dump trailer  and lot of contracting tools
Offline thecfarm
Re: f 250
« Reply #13 on: January 08, 2018, 07:43:20 AM »
I've got a Colorado,chevy,bought it from a dealer used. Gas gauge did not work. They replaced the cluster,gas gauge works,the thing that keeps track of the milage don't.
Offline roger 4400
Re: f 250
« Reply #14 on: January 08, 2018, 09:16:04 AM »
I had a 2000 f250, it did the same 2 times. I do not know if 2016 and 2000 have the same speed system. The solution at that time was to go on the rear diff (on top) over it there is a plug that is a magnet and read how many time the ring gear turns. You unscrew  this plug ( 3/8 in. I think ) clean this little magnet that will have some metal shaving on it and it is why the speedometer cannot read the ring gear speed. My diff was a 4.10
Easy to do . Good luck.Roger
Mine was not working on even indicating wrong speed.Yours is a 2016 so I guess on warranty by Ford !
Baker 18hd sawmill, massey Ferguson 1643, Farmi winch, mini forwarder, Honda foreman 400, f-250, many wood working tools, 200 acres wooden lots,6 kids and a lovely and a comprehensive wife...and now a Metavic 1150 m14 log loader so my tractor is a forwarder now
Offline Southside logger
  • Sawing so I can afford to farm.
Re: f 250
« Reply #15 on: January 08, 2018, 10:06:42 AM »
I think those sensor wires are held in place with a bikini line, so that may be your issue?   :D :D 8)
'92 Franklin 170 grapple skidder
'92 Franklin 5000 wheeled buncher
Wicked Awesome Basset Hound * 2
JD 490D with 4 roller FabTek processer / hydraulic hose breaker
Hot wife
Wood Mizer LT35HDG25, Re-saw attachment
Official Member of the BBFC
Offline Gearbox
Re: f 250
« Reply #16 on: January 08, 2018, 10:13:15 AM »
If it is like my older one . When the speed sensor go the converter lock up quits to. good luck . They are easy to change . Just one bolt . Cheap to .
Offline coxy
Re: f 250
« Reply #17 on: January 08, 2018, 07:21:25 PM »
it seem to be working now but I'm going to take the fuse back out and see if it des it again  them anti lock brakes and traction control suck  ford will get it back there has to be a way to disable it  the button on the dash only disables the rear and when you try to fish tail it the ones in the front come on errrrrr
Online Dave Shepard
    • My homepage
Re: f 250
« Reply #18 on: January 08, 2018, 07:27:03 PM »
ABS on dry pavement sort of works. Dangerous on snow and ice.
Offline coxy
Re: f 250
« Reply #19 on: January 08, 2018, 07:38:54 PM »
tell me about it
