Arborwear
Author Topic: f 250  (Read 1772 times)
Offline Dave Shepard
  • Geometrically proportional
    • My homepage
Re: f 250
« Reply #20 on: January 08, 2018, 08:13:10 PM »
 My '02 F350 would push the pedal up and offer zero braking and you would just run over your own mailbox in slow motion.  :D
Offline 21incher
Re: f 250
« Reply #21 on: January 08, 2018, 08:26:39 PM »
The ABS on my 05 F350 works great on snow. Once the motor kicks in the pedal bounces but it stops really good when empty. With a load it never kicks in. If only I  could find calipers that last more then a couple years.
You should have it looked at. May only take a simple software update to fix.
Hudson HFE-21 on a custom trailer, Deere 4100, Kubota BX 2360, Echo CS590 & CS310, home built wood splitter, home built log arch, and a logrite cant hook.
    • My homepage
Re: f 250
« Reply #22 on: January 08, 2018, 09:12:20 PM »
I solved the problem at the junkyard.  ;D
Offline dgdrls
  • Learning the Art of Milling Logs, Lucas 8/27
Re: f 250
« Reply #23 on: January 08, 2018, 09:24:39 PM »
I've seen discussion  both ways,
To me, you have to have a full set of good snows first and foremost
then a little ballast if its a truck.
D
Offline coxy
Re: f 250
« Reply #24 on: January 10, 2018, 06:42:14 AM »
it don't even stop with chains on they should take them antilock brakes and shove them where the sun don't shine
Online snowstorm
Re: f 250
« Reply #25 on: January 10, 2018, 08:10:18 AM »
my 350 and 550 would pull to the right. took the abs fuse out and they stop like they should. brake calipers dont seem to last long before they stick. they did come from napa. that could be part of it
Offline Weekend_Sawyer
  • Jack of all trades, master of fun
Re: f 250
« Reply #26 on: January 10, 2018, 08:51:09 AM »
Dropping off or picking up?  :D
I have always found NAPA to be the higher quality after market parts store.
Jon
Imagine, Me a Tree Farmer.
Jon, Appalachian American Wannabe. ... and it looks like my dream will come true!
Online snowstorm
Re: f 250
« Reply #27 on: January 10, 2018, 09:32:22 AM »
Napa high quality? Maybe compared to some of the others. I asked carquest about brake calipers.  They said They get there's from the same rebuilds. I find most parts are less money or close at the Ford dealer. But I do have a fleet account
Offline chevytaHOE5674
Re: f 250
« Reply #28 on: January 10, 2018, 09:40:45 AM »
I've had worse luck with stuck calipers on the ones I got from the Ford dealer than the ones I've got from Napa. And at least Napa is only 5 miles down the road when I need to warranty one compared to 50 miles to the Ford dealer....
Must be a Ford thing because I've had more stuck calipers on my superduty than I had on all the other trucks I've owned combined.
    • My homepage
Re: f 250
« Reply #29 on: January 10, 2018, 10:50:38 AM »
Jon
Dropping off. I put that thing out of its, and my, misery.
Offline coxy
Re: f 250
« Reply #30 on: January 10, 2018, 10:54:12 AM »
    • My homepage
Re: f 250
« Reply #31 on: January 10, 2018, 11:15:34 AM »
At least they stock everything for Ford brakes. That's nice, considering you habe to work on  them every other weekend.  :D
Offline coxy
Re: f 250
« Reply #32 on: January 10, 2018, 04:01:16 PM »
that's not true there has been lots of things they don't stock for a ford they tell me never had anyone brake that :)    what do you drive a DODGE or CHITV  smiley_thumbsdown smiley_thumbsdown :D :D 8) 8) 8)
    • My homepage
Re: f 250
« Reply #33 on: January 10, 2018, 04:17:57 PM »
My local NAPA stocks all brake parts and u joints for Ford trucks. And if its sold out, they can have it the next morning. A friend of mine has 7 or 8 Super Dutys. Usually. one of them is running.  :D
Offline coxy
Re: f 250
« Reply #34 on: January 10, 2018, 04:27:41 PM »
you still didn't tell me what you drive  ;D
    • My homepage
Re: f 250
« Reply #35 on: January 10, 2018, 04:41:55 PM »
Jeep. They stock fan relays for all us WJ owners who don't want to take the entire front clip off to change the fan.  :D
Offline GRANITEstateMP
  • LIVE FREE OR DIE
Re: f 250
« Reply #36 on: January 10, 2018, 04:48:33 PM »
chevytaHOE5674,
  I work at a Toyota dealer, we do A LOT of calipers!  We run a lot of 4 piston calipers on our Trucks and SUV's we replace a lot of stuck calipers.  We get a little better luck out of the Toyota Reman units than the aftermarket ones.  When a Toyota reman is available it's usually in the same price range as the aftermarket.  We have the best luck with calipers from Autopart International aka Foreign Autopart
Bruno,
  I've got a guy over in Rye that has rebuilt 3 or 4 Chevy HD Speedo clusters for me.  He does a good job, replaces all the bulb...  Pretty sure it was around $200 each, maybe a little less???  It's been a while.  He also rebuilt a "fish stick" for my old Fisher 8ft HD plow.
Hakki Pilke 1x37
Kubota M6040
Load Trail 12ft Dump Trailer
2015 GMC 3500HD SRW
Offline coxy
Re: f 250
« Reply #37 on: January 10, 2018, 05:44:42 PM »
thats all you had to say is you drive a slowpar  I understand :-X :D :D
Offline Southside logger
  • Sawing so I can afford to farm.
Re: f 250
« Reply #38 on: January 10, 2018, 06:45:23 PM »
All this trash talk from a guy that runs around in a bikini!!   :D
'92 Franklin 170 grapple skidder
'92 Franklin 5000 wheeled buncher
Wicked Awesome Basset Hound * 2
JD 490D with 4 roller FabTek processer / hydraulic hose breaker
Hot wife
Wood Mizer LT35HDG25, Re-saw attachment
Official Member of the BBFC
Offline 21incher
Re: f 250
« Reply #39 on: January 10, 2018, 07:05:36 PM »
My F350 has gone through 12 calipers in 35k miles.  Ford quit making them, all l can find are rebuilds now. NAPPA  by me keeps them in stock. Buy online and pickup in the store saves 10%. :)
