Arborwear
Author Topic: Winter battery chainsawing....  (Read 446 times)
Online upnut
  • Wood Tick
« on: January 08, 2018, 05:03:44 PM »
The cold weather finally broke, so i headed out to the woodlot running trails for a change. Took the Stihl MSA 120 along just in case, ok I really wanted to see how it handled winter use. Mild temps (32 degrees) and no wind made a pleasant ride. Cut a 10" red elm, a dead top from another elm and a red cedar top out of the trails. The saw has seen virtually no use in three months, has not been charged, but still showed four bars (full) charge. The trail clearing took it down to two bars, and re-charging to full load took an hour and ten minutes. Just some real life experiences for those contemplating a battery chain saw...
Scott B.
I did not fall, there was a GRAVITY SURGE!
Offline thecfarm
Re: Winter battery chainsawing....
« Reply #1 on: January 08, 2018, 07:03:34 PM »
Not thinking about a chainsaw,yet,but a polesaw is on the list.
Offline kenskip1
  • Stihl Looking for the fountain of middle age.
« Reply #2 on: January 09, 2018, 06:46:06 PM »
Are you using a winter bar oil?Unless your saw has a oil preheater..
Stihl The One
Stihl Going Strong
Stihl Looking For The Fountain of Middle Age
Online upnut
  • Wood Tick
« Reply #3 on: January 10, 2018, 10:32:31 AM »
Yes, using winter weight bar oil, and the mild outside temp wasn't a true test of cold winter conditions. When the wind chill drops to way below zero I have a tough time getting motivated to try chainsawing just for fun... :D...Scott B.
New battery's
Started by Bruno of NH on General Board
Last post February 07, 2015, 04:40:34 PM
by whiskers
WM Battery
Started by Knute on Sawmills and Milling
Last post January 27, 2011, 06:44:17 PM
by Knute
2nd battery in car?
Started by Furby on General Board
Last post May 07, 2003, 03:50:19 AM
by ADfields
Best battery
Started by glgdiggs on Sawmills and Milling
Last post February 27, 2011, 08:07:44 PM
by bandmiller2
