AVAILABLE
Author Topic: Woodmizer band sharpening and nails  (Read 2440 times)
Offline Brad_bb
    • My timberframe blog
« on: January 09, 2018, 12:17:21 PM »
When I first got my Woodmizer mill in 2014, I never got clear answers from Woodmizer on resharpening and nail strikes.  So my first bands that had nail strikes I sent back for resharp and when they came back it seemed like they didn't cut well at all.  So from then on I set nail strike bands aside and if I had just nicked one, I might try resharp, but most of the time if I could see the tip of the tooth not a point anymore, I figured they couldn't do anything with it and I junked it.  For the longest time I wondered if they really checked the set on the resharp bands as well and someone's recent post here confirmed that they don't.  I think they should.  I have a band that I just hit a nail with and it still cut be once a revolution it would jump because I think one or two teeth were bent out of the correct set.
So, if you hit a nail do you junk the band?  Am I correct in that they cannot grind back enough material to fix from nail strikes?
Offline uler3161
Re: Woodmizer band sharpening and nails
« Reply #1 on: January 09, 2018, 01:40:07 PM »
I do not junk the band unless it's already close to it's end of life. I do my own blades. It does take more effort to grind a tooth back and to get it reset though, especially if you have to downset and don't have a setter that does that.
1989 LT40HD, 12ft extension, WoodMaster 718, Fordson Major Diesel, Champ CB40 Forklift
Dan
Offline Jim_Rogers
  • Keep your chisels sharp.
    • jrsawmill.com
« Reply #2 on: January 09, 2018, 02:00:06 PM »
I was told to turn the blade inside out when you ship it back to resharp for sharpening after it has hit some metal. That way they know what's up with that blade and do a very close inspection of the blade.
If they determine that it could be sharpened the do. If they determine that it is junk then they replace it with a new blade at the box price.
I keep track of my blades by serial number written down on a tag. And I re-attach the tag to the blades when they come back from resharp. That way I know the history of the blade and whether or not if it has hit metal and been resharpened.
That's just me and the way I do it.
I do grind them some myself and will try and save a blade that has hit metal but sometimes it doesn't work out.
Jim Rogers
Offline Beavertooth
« Reply #3 on: January 09, 2018, 03:42:25 PM »
I was told by woodmizer resharp if there is more than 3 teeth in a row messed up they chunk it.
2007 LT70 Remote Station 62hp cat.
Offline Kbeitz
  • Never enough time...
    • My Hobbies
« Reply #4 on: January 09, 2018, 04:12:18 PM »
I run my blades until they snap. I sharpen them and if they don't cut good I sharpen
it again and again until I get it right. I never found a blade I could not get to cut
again. One I took 4 teeth clear off the blade. I just kept playing with it till I got it
working again. It might not be worth you'r time to do this but I have nothing but
time. I'll take the challenge. This goes with drill bits, saw blades and what ever
else I can mess with.
Love machine shop work
and Wood work shop work
And now a saw mill work
Offline fishfighter
« Reply #5 on: January 09, 2018, 04:26:42 PM »
I had some success and some failures. What I had did was just grind off the teeth that took the blunt of metal hit and resharpen the rest of the blade. Sometimes it works and some times it don't.  ;D
Offline Chuck White
  • Sawing Mobile since 2005
« Reply #6 on: January 09, 2018, 04:45:01 PM »
If I have a blade and 1 or 2 teeth are messed up to bad, I just take my Vice-Grips and snap them onto the tooth to straighten it up so that it actually becomes a raker and therefor, has no set!
~Chuck~
I LOVE MY SAWMILL
Offline Crossroads
  • lets make some sawdust
    • Kevin Bales faith family farm and portable sawmill
« Reply #7 on: January 09, 2018, 07:54:34 PM »
I send them in unless I see cracks in the blade. If I have a tooth bend out of shape to the point its leaving marks on the wood, I find it and tap it back in shape with 2 hammers, 1 as a backer and one as a tapper. Hitting small nails, Ive had good luck getting them back from resharp. I had one yesterday though that hit a 3/8 lag bolt. I dug the bolt out and was going to try to finish the cut with that blade. Went about 6 and hit another one :( that blade is toast.
I will start turning then inside out though, thanks for that tip.
2017 LT40 wide, Kubota l185dt, 2-036 stihl, 2001 Dodge 3500 5.9 Cummins
Offline bandmiller2
« Reply #8 on: January 09, 2018, 08:29:37 PM »
I set and resharpen my own bands and rarely have to scrap one due to nail hit. If you will spend a few minutes checking set and grinding most bands can be salvaged or at least demoted to crappy log status. Frank C.
Offline Peter Drouin
    • A&P Saw mill LLC
« Reply #9 on: January 09, 2018, 09:24:37 PM »
I sharpen my blades, Use WM double hard 55. When that happens if I can grind a little to fix it I will. If I have to grind all the hard off the top of the tooth to fix it I junk them. I do keep 10 or 20 bad blade for logs I know have iron in them.
I cut lumber full time for a living. For the price of a blade it makes no cense to fool with them.
Offline Brad_bb
« Reply #10 on: January 09, 2018, 11:16:39 PM »
So these responses lead to the next question...
Is there a good you tube showing how to sharpen or fix bands?  How do I find the offending tooth, any trick to it?  Gauge?  I understand how you sharpen an antique cross cut saw -filing the teeth to the same height  and then sharpening them, but how they are sharpened is different from how a band is sharpened, eh?
Offline Percy
  • Resident trouble maker
« Reply #11 on: January 10, 2018, 12:32:41 AM »
^^^^ this ^^^^
Offline fishfighter
« Reply #12 on: January 10, 2018, 05:39:17 AM »
I tried that and just finish breaking those teeth off. ;D Every time I had hit metal, I wipe out at lease 4 teeth in a row. :(
Offline bandmiller2
« Reply #13 on: January 10, 2018, 07:37:08 AM »
Brad, if I've hit a nail I first , wile the bands on the mill, check for the steel curls on the tooth tips then for over bent teeth. With the band tensioned on the mill, not running, I run a piece of sticking over the band. With some practice you can detect over bent teeth and reset them with a adjustable wrench. Frank C.
Offline Chuck White
« Reply #14 on: January 10, 2018, 07:42:42 AM »
If the tooth was bad to begin with, you're still not out anything!   ;)
Just don't want anything sticking out to put marks on the lumber!   :)
~Chuck~
I LOVE MY SAWMILL
Offline slider
  • sawyer,trucker,tree service
« Reply #15 on: January 10, 2018, 07:59:28 AM »
Brad, Cooks has a good youtube video on band service. Especially the part on dressing the stone which is key to getting the profile correct.
Like chuck i don't like tooth marks on the lumber .On framing lumber it's not a big deal but on the good stuff those marks just drive me nuts.
Finding the offending teeth is a challenge for me but if you have the time it's worth it.
Sometimes i just down set the whole band then reset and sharpen.
al glenn
Online terrifictimbersllc
    • Terrific Timbers LLC
« Reply #16 on: January 10, 2018, 09:34:11 AM »
When a blade hits metal I take it off and put a white wire tie on it, my code for metal.
At home, I clean all my bands with my drill press, and I set the metal ones aside together.  When I get to those, I lay them on the table saw, put on my glasses, and pull it around as I look at the teeth.  Like Bandmiller said metal damage often results first in curled over metal on the tooth face.  As I look at the teeth from the top with the right light it is easy to spot more heavy damage which is rounding over of the tip.   If I think this will take more than 2 or 3 passes on the grinder to remove, I will measure the band width and decide (usually) to discard the blade (more likely if the band width says it is half used up or more).
To repair the blade, I mark a spot with a sharpie inside and out, then go around first with my fingernail or if that gets hard, with a flat file, and flip off the curled over metal with a clockwise upward twist of the file.  Sometimes I also take a light file stroke on the face of the tip.   If I encounter anything that is more time consuming the blade gets trashed.
I don't have patience or time anymore to spend more than about 5 minutes on a blade saving operation outside of the regular clean-sharpen-set cycle.   The customer already paid for the blade and I don't have to make money this way.
Regarding finding over-set teeth, it would be great to be able to do this quickly on the mill when I pick up unacceptable kerf marks but the blade is still sharp.
I haven't had luck trying to feel for the overset tooth with an adjustable wrench, there's too much slop in mine.  I could probably lock my digital caliper and use it to scan the blade,  but it is a Starrett and I can't bring myself to be dragging blade teeth through it.   Doesn't work for me to be spending any time on this during sawing.
Back home, I can put a blade on the setter, back off the pushers, and watch the dials as the blade goes around. But this requires 2 passes watching one or the other dial. It's not that hard and I can bend the teeth back easy as I find them.
DJ Hoover, Terrific Timbers LLC,  Mystic CT   2001 WM LT40SHDD (42HP Kubota, Accuset2, FAO's, Lubemizer, debarker, hydraulics everywhere), Peterson WPF 10-30 with chain slabber. Logrite fetching arch, WM BMS250 sharpener/BMT250 setter.
Offline tawilson
« Reply #17 on: January 10, 2018, 09:52:07 AM »
Terrific, I have the same setter/sharpener as you. In the sharpener manual there's a page where they recommend using a Woodmizer wash tank which performs a few functions, including down setting, deburring and cleaning. I have searched and can't find anything anywhere on one. Do you or anyone else know of this?
2017 LT40HDG35 WIDE
« Reply #18 on: January 10, 2018, 01:22:39 PM »
What page?  You sure you're not looking at a ReSharp ad?   :D  Seriously I think I saw that too but can't see it in my manual here now.
Down setting and de-burring in a tank?  Guess I can imagine doing that in a tank with some strong acid but the tank would need to be plastic and the blades would be thinner when they come out.  :o :o
Offline tawilson
« Reply #19 on: January 10, 2018, 01:43:22 PM »
"When using a Wood-Mizer wash tank,  blades are run through a cycle that cleans,  deburrs, and washes the blade in solvent.  The wash cycle also includes a set of rollers to pinch the blades to flatten and equalise the set.  This allows for the blades to be properly set during the setting process."
There's more but here's a pertinent quote. I'll put up a screenshot of the page when I can.
Page 6-3.
2017 LT40HDG35 WIDE
Nails and Sharpening
Started by ValleyGuy on Sawmills and Milling
Last post April 09, 2013, 09:57:30 PM
by ValleyGuy
Band Sharpening
Started by reswire on Sawmills and Milling
Last post December 30, 2016, 11:11:48 PM
by reswire
band sharpening ?
Started by PoDunk on Sawmills and Milling
Last post February 24, 2010, 06:43:29 PM
by woeboy
Band sharpening in NC
Started by adam82 on Sawmills and Milling
Last post September 29, 2013, 11:34:43 AM
by adam82
