Author Topic: When you hit a nail  (Read 1272 times)
Offline Pabene
When you hit a nail
« on: January 09, 2018, 07:54:58 PM »
What happens when your log band saw blade, hit a nail in the log?
Sometimes it can be good to think about the proportion of the things as are going on. Here are some data I calculated many years ago.
At normal blade speed one tooth on the blade, is running 5-6 complete “laps” within one second.
At a feed of 30’/minute, 25 teeth will pass the distance to cross cut a 4” nail. If your feed is slower more teeth will be tuched.
If you have a “bimetal” blade, it is HSS steel in the blade tips and the nail is a normal “soft” steel nail, you will see blue small chips from the nail sitting on the tips on at least 20 teeth.
I have, in most cases, been able to clean the teeth from chips and then sharpen the blade. In some case I have been forced to check the set and perform an other sharpening. Then the blade has cut as normal.
There are nails made of harder steel. Such nails will destroy the blades, in my opinion.
No one can listen, hear the sound when the blade starts to cut the nail, stop the saw and save the blade that way. To cross cut a nail like this takes about 0.1 second.
Offline Percy
  • Resident trouble maker
Re: When you hit a nail
« Reply #1 on: January 09, 2018, 08:08:21 PM »
I pretty much always say a bunch of bad words.
Offline Lawg Dawg
  • True South Sawmill Lumber
« Reply #2 on: January 09, 2018, 08:10:37 PM »
Yep, what he said..
2018  LT 40 Wide 999cc, 2019 t595 Bobcat track loader,
 John Deere 4000, 2016 F150, Husky 268, 394xp, Shindiawa 591, 2 Railroad jacks, and a comealong. Woodmaster Planer, and a Skilsaw, bunch of Phillips head screwdrivers, and a pair of pliers!
100,000 bf club member
Pro Sawyer Network
Offline bandmiller2
« Reply #3 on: January 09, 2018, 08:21:04 PM »
A lot depends on the angle you hit the nail. At right angle usually minor damage, check set and remove small curl of nail on the tooth tip. If you hit a nail at a low angle it will usually mess up the set on one side, band can usually be reset and sharpened. Drywall screws are pure poison to a band along with lag bolts and ceramic insulators. Frank C.
Offline JB Griffin
« Reply #4 on: January 09, 2018, 08:29:51 PM »
Frank, your on to something right there.
2000 LT40hyd remote 33hp Kubota, 160 Prentice, Frick 2 saw gang edger, Wright W-37 ABG, Suffolk dual tooth setter, Cat claw single tooth setter,'96 F-250 7.3 PSD 4x4, CS-590 Echo, MF 20c, M681 Memo.
Over 2.5 million bdft sawn with a Baker Dominator and counting.
Offline Southside
« Reply #5 on: January 09, 2018, 10:37:20 PM »
Not to mention the dreaded ring shank nail and those dang backstops!!
Offline Cedarman
    • Cedarusa
« Reply #6 on: January 10, 2018, 07:12:16 AM »
The only decision to be made when hitting a ceramic insulator is whether to take the blade to the junk blade pile now or later.
Offline slider
  • sawyer,trucker,tree service
« Reply #7 on: January 10, 2018, 07:27:03 AM »
Cedarman is 100% correct on that one.
al glenn
Offline ladylake
« Reply #8 on: January 11, 2018, 04:14:24 AM »
  2 of the worst I've hit , a ceramic insulator, sawed all the way through it , the blade was almost as smooth on the front as the back.  Later a pole bar nail a angle , every tooth was bent around in a U shape. I'd have thought they would have broke off before bending like that.  Steve
Timberking B20 14000 hours +  Case75xt grapple + forks+8" snow bucket + dirt bucket   770 Oliver   Lots(too many) of chainsaws, Like the Echo saws and the Stihl and Husky     W5  Case loader   1  trailers  Wright sharpener     Suffolk  setter Volvo MCT125c skid loader
Online Sixacresand
  • John and Nancy
« Reply #9 on: January 11, 2018, 08:38:04 AM »
The biggest concern is getting through the cut after hitting metal.
My new nail gun!
Started by Raider Bill on General Board
Last post August 02, 2008, 01:57:58 PM
by mometal77
It's not about the nail
Started by Okraswife on General Board
Last post June 07, 2013, 06:00:53 PM
by doctorb
One Big O Nail
Started by Kevin_H. on Sawmills and Milling
Last post November 12, 2004, 05:27:34 PM
by DonE911
First nail
Started by woody1 on Sawmills and Milling
Last post October 26, 2008, 08:31:11 AM
by woody1
