TURBOSAWMILL GIANT SALE ON NOW UNTIL OCTOBER 31st
Author Topic: Determining blade hook angle on used bands  (Read 1937 times)
Offline newdesertfox
« on: January 10, 2018, 12:13:48 PM »
How do you tell what the hook angle is on a blade? I purchased a used woodmizer that came with 30 blades unmarked in boxes, I've spent plenty of time on google over the last 2 months trying to determine it but never had any luck, basically whenever a blade gets dull I end up putting new blades on at random and seeing if it cuts hardwood or softwoods better but its incredibly annoying. Is there any way to ID the blades hook angle before putting it on the sawmill or am I gonna be stuck shooting blind till I get them all resharpened and hopefully marked
Offline kelLOGg
Re: Determining blade hook angle on used bands
« Reply #1 on: January 10, 2018, 12:33:01 PM »
There's been a lot said on the FF about that. Maybe this will get you started,
http://www.forestryforum.com/board/index.php/topic,97320.msg1511864.html#msg1511864
Cook's MP-32, 16HP, 20' (modified w/ power feed, up/down, loader/turner)
DH kiln, CatClaw, setter, tandem trailer, log arches, tractor, thumb tacks
Online LeeB
« Reply #2 on: January 10, 2018, 12:44:43 PM »
Many of the brands stamp the blade info on the blade near the weld, or at least WM and Lennox do.
Offline terrifictimbersllc
    • Terrific Timbers LLC
« Reply #3 on: January 10, 2018, 01:16:37 PM »
For Woodmizer blades, you need "Blade gauge", part 065691, $15.00.  It's a hexagonal metal tool about 8x8" which has the teeth profile in each of 6 sides.  4/32, 9/29, 10/30, 7/34 are the ones I have plus two others. Does not have the 7/39 "turbo".
You hold it into the teeth and see which profile fits. Would also be good for checking grinding with non-CBN methods.
i'll put up a photo when the gallery is back up.
DJ Hoover, Terrific Timbers LLC,  Mystic CT   2001 WM LT40SHDD (42HP Kubota, Accuset2, FAO's, Lubemizer, debarker, hydraulics everywhere), Peterson WPF 10-30 with chain slabber. Logrite fetching arch, WM BMS250 sharpener/BMT250 setter.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #4 on: January 10, 2018, 01:26:32 PM »
Never realized how much I use the Gallery.  :-\  I'll post a picture of that tool when the Gallery is available again.
« Reply #5 on: January 10, 2018, 01:32:38 PM »
Thanks, I'll look to see if I can find anything stamped on them. That tool sounds super handy, does anyone have a link to it? I tried googling it and I went through WM's website but found nothing
« Reply #7 on: January 10, 2018, 01:53:32 PM »
Thanks, from what I gathered you just have to call and order it as its not on their website. Found the WM markings near the welds, downside is the blades are so worn that 3 out of 4 I checked I can't read anything even after scrubbing the blade clean >.<
« Reply #8 on: January 10, 2018, 02:38:38 PM »
one other question if anyone knows, I found more blades with numbers, these blades are pretty clean in comparison to all the other boxes of blades (more blades have a good amount of superficial rust) but their serials are all similar, either Wood-mizer 2YGY137 or YGY126, I read the manual but can't make much of these, guessing their 13's but the 7 at the end, or 126 has me lost. Also when you send in to resharp, do the blades always come back shiny or if they are rusty do they come back that way? they didn't specify which boxes were dull blades and which were sharp so Im only guessing if Im putting worn out blades on the machine
« Reply #9 on: January 10, 2018, 03:18:15 PM »
If you have a login at Woodmizer you can click on "item lookup"  and enter that part number there.  it comes up as $15.00. Otherwise just phone in.  If you don't have a login you should get one as you have a WM mill.
« Reply #10 on: January 10, 2018, 03:39:38 PM »
Thanks, worked perfectly!
Offline Kbeitz
  • Never enough time...
    • My Hobbies
« Reply #11 on: January 10, 2018, 04:01:22 PM »
There must be more than one URL for Woodmizer. I tried both the part
number 065691 and Blade gauge both and keeps coming up part not found.
Love machine shop work
and Wood work shop work
And now a saw mill work
« Reply #12 on: January 10, 2018, 04:38:57 PM »
If it is the search box you tried, it won't come up there.  I only found it in the item lookup , which I needed to log in to see.  Even if I am logged in, it won't come up in the site search box.
Offline Kbeitz
    • My Hobbies
« Reply #13 on: January 10, 2018, 05:23:17 PM »
Thanks... I'm not a member so guess I wont get one...
Offline 1938farmall
  • Uff-da
« Reply #14 on: January 10, 2018, 05:31:43 PM »
newdesertfox - you shouldn't have to "guess" which bands are sharp vs. which are not.  there are dozens of posts explaining what a sharp band looks like.
aka oldnorskie
« Reply #15 on: January 10, 2018, 07:43:33 PM »
I figured it out today, as I said Im newer but what I didn't realize was the 3 boxes of blades I've been cutting with were all dull ones... so I've never worked with a sharp one to know haha, opened up another box that was clearly sharpened and it was like oh wow this is obvious...
« Reply #16 on: January 10, 2018, 08:20:33 PM »
I think you could get one if you called them.
If you cant, and want one I can buy one on my next order, and send it to you.
p.s. you'll have to disable the Dremel Alarm on it.  :D
« Reply #17 on: January 10, 2018, 08:32:40 PM »
I found it once logged in on the parts lookup and ordered it, will know shortly if its the right thing, are there pictures of what it is? WM had no pictures
Offline POSTON WIDEHEAD
  • Getting old but doing it with Friends.
« Reply #18 on: January 10, 2018, 08:54:12 PM »
It may not be you Magic but i was thinking you kept a piece of blades to lay on top of another blade to match the angle.
Magic has a Brand New Sticker
Offline DR_Buck
  • Nuff said.....
    • Got Logs?
« Reply #19 on: January 10, 2018, 08:55:16 PM »
I'd like to see this.  The one I got from Wood-Mizer several years ago is plastic, on a key chain.   One template for each blade angle.
Hidden Acres Farm
Been there, done that.   Never got caught
Wood-Mizer LT40HDG38
Lucas Dedicated 60" Slabber
Hook angle and blade life
Started by coastlogger on Sawmills and Milling
Last post May 17, 2013, 01:42:46 AM
by coastlogger
Hook Angle - Blade Tension
Started by highpockets on Sawmills and Milling
Last post February 15, 2006, 09:27:14 PM
by jpgreen
Hook Angle
Started by Randy on Sawmills and Milling
Last post March 06, 2005, 12:29:29 AM
by Kirk_Allen
question
H.P. and Hook Angle
Started by dgdrls on Sawmills and Milling
Last post October 19, 2012, 07:24:38 PM
by francismilker
