Arborwear
Author Topic: Determining blade hook angle on used bands  (Read 1056 times)
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Re: Determining blade hook angle on used bands
« Reply #20 on: January 10, 2018, 09:42:21 PM »
terrifictimbersllc found the picture:  LINK
Offline newdesertfox
« Reply #21 on: January 15, 2018, 06:52:21 PM »
Got exactly that in from WM using that product number, random question, what is the section marked 1 1/8   10? the tooth profile is very unusual
Offline terrifictimbersllc
    • Terrific Timbers LLC
« Reply #22 on: January 15, 2018, 07:31:07 PM »
A blade Ive never seen🎃🎃.
Maybe look it up on Woodmizer blades page.
Someone else will know.
DJ Hoover, Terrific Timbers LLC,  Mystic CT   2001 WM LT40SHDD (42HP Kubota, Accuset2, FAO's, Lubemizer, debarker, hydraulics everywhere), Peterson WPF 10-30 with chain slabber. LogRite fetching arch, WM BMS250 sharpener/BMT250 setter.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #23 on: January 15, 2018, 07:38:19 PM »
I have no idea either.  At the present time I only use two of the profiles; the 10 (white), and the 4 (green).  As my 10 blades are rejected out I will only have 4 and 7 Turbo's.  At that time I will have no need for the profile gauge.   ;D
Offline LeeB
« Reply #24 on: January 15, 2018, 10:20:20 PM »
WM marketed an 1 1/8" pitch blade for a while and may still do so.
http://forestryforum.com/board/index.php/topic,34112.msg492920.html#msg492920
Offline DR_Buck
  • Nuff said.....
    • Got Logs?
« Reply #25 on: January 16, 2018, 11:41:06 AM »
This is the blade gauge set I got from Wood-Mizer.   I think I picked it up at Paul Bunyan a few years ago for about $9.   I only use 9 and 4 bands so I only keep those two templates on the key chain.
Hidden Acres Farm
Been there, done that.   Never got caught
Wood-Mizer LT40HDG38
Lucas Dedicated 60" Slabber
« Reply #26 on: January 26, 2018, 07:11:08 PM »
Finally had a rainy day to mark blades and came across a question... does the whole tooth fit tooth and gullet or just the tooth? I was marking out blades and they all seemed to fit the 10 degree side although the gullet wasn't fitting, and then after marking a few blades I randomly checked 4 degree (13, 9, and 7 didn't fit so didn't bother with 4 at first) and it also seems to fit although the 4 degree mark even the gullet fits -_- so how have other people used theirs and found the best effect? as there is a dig difference between a 4 degree and a 10
Hook Angle - Blade Tension
Started by highpockets on Sawmills and Milling
Last post February 15, 2006, 09:27:14 PM
by jpgreen
Hook angle and blade life
Started by coastlogger on Sawmills and Milling
Last post May 17, 2013, 01:42:46 AM
by coastlogger
Hook angle
Started by woodchip on Sawmills and Milling
Last post April 08, 2004, 06:47:07 AM
by woodchip
question
H.P. and Hook Angle
Started by dgdrls on Sawmills and Milling
Last post October 19, 2012, 07:24:38 PM
by francismilker
