KNOW WHAT?
Between February 12, 2018 and June 18, 2018, this space displayed 13 Million, 871 Thousand and 87 times.
BRUTE FORCE Authorized Dealer
Council Tool
Author Topic: Looking to source Pressure treated 6 x 6, no heart  (Read 634 times)
Offline SwampDonkey
  • Forester
  • Large Tooth
« on: January 11, 2018, 10:28:08 AM »
Anyone in northern Maine or New Brunswick with any good sources to get pressure treated 6 x 6 post for an open porch. 9-10' tall stuff. But, no heartwood. All I am used to seeing is boxed heart posts that split open 4 ways to Sunday when in the weather.
Pre-commercial thinning pays off. :)
'If she wants to play lumberjack, she's going to have to learn to handle her end of the log.'
Dirty Harry
Offline kantuckid
Re: Looking to source Pressure treated 6 x 6, no heart
« Reply #1 on: January 14, 2018, 07:02:51 AM »
Tell us when you see some... :D
Offline SwampDonkey
  • Forester
  • Large Tooth
« Reply #2 on: January 14, 2018, 07:13:57 AM »
That's what I was think'n.  ::) ;D :D :D
Although, I have seen some brown treated ones on Lowe's site. That doesn't mean they have them that way. :D
Dirty Harry
Offline Don P
    • Calculator Index
« Reply #3 on: January 14, 2018, 07:58:39 AM »
Foundation grade treated, I believe UC4 is the use category, is free of heartwood. That is still a boxed heart timber simply a young tree. Remember heartwood doesn't take treatment so the treatment goes all the way through the timber. Down here Cox would probably be the supplier in SYP, they can supply on up to marine retention 2.5pcf.
It sounds like you want FOHC timbers, probably available in dougfir, which is difficult to treat and so is usually incised. I've only run into those out west, generally brown treatment, shallow penetration and not handsome.
Laminated columns are one alternative;
https://coxwood.com/residential/product/durapine-columns/
Post frame suppliers might be able to get you a full height treated glulam post along these lines, don't know;
http://www.rigidply.com/GlulamPostsBeamsArches/Posts
I noticed on your side elevation the far right post needs to go to bottom of foundation depth.
Offline SwampDonkey
  • Forester
  • Large Tooth
« Reply #4 on: January 14, 2018, 10:04:38 AM »
I've decided to cover the posts, so will make due with the local stuff I guess. One thing I have found in the mean time is some decent steel post anchors and skirts, not this local aluminum and plastic junk. Ordered from Lee valley. I also got their hand rail brackets for the stair case inside the house.
Dirty Harry
CCA pressure treated..........
Started by gator gar on Sawmills and Milling
Last post April 06, 2010, 11:04:40 AM
by Meadows Miller
pressure treated ash shingles
Started by Josef on Drying and Processing
Last post September 26, 2015, 07:04:31 PM
by Josef
Pressure treated stickers?
Started by t_andersen on Drying and Processing
Last post August 13, 2005, 08:55:22 PM
by Don P
painting pressure treated
Started by bama20a on General Woodworking
Last post November 15, 2015, 01:18:12 PM
by terrifictimbersllc
