Author Topic: Building a new home, returning to the farm.  (Read 17753 times)
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Re: Building a new home, returning to the farm.
« Reply #180 on: May 15, 2019, 01:29:57 PM »
 8)
Offline SwampDonkey
  • Large Tooth
« Reply #181 on: May 24, 2019, 05:24:41 PM »
Materials landed here this week. Lumber, OSB, siding, corners, J-channel, soffit, sill gasket, flashing, house wrap, roof vents, windows, door. Everything is tarped.
The steel won't be here until we have the roof on for the final measurements before cutting. But it will just be a matter of 24 hrs or less on delivery once they get word.
Begin construction June 3.
Grass seed is starting, foreground and upper right.
Move'n on.
Offline GRANITEstateMP
  • LIVE FREE OR DIE
« Reply #182 on: May 25, 2019, 01:48:02 PM »
Good for you SwampDonkey!
  I've enjoyed following your thread.  Always neat to see something take shape
  I will be starting another house in a couple weeks.  Me and an old friend, now business partner, did a spec house last year (as a side project) with the help of a local GC.  It went fairly well, learned a lot, and made a little, and now we're gonna give it another go.
  Best of luck with the rest of the build.
Matt
Hakki Pilke 1x37
Kubota M6040
Load Trail 12ft Dump Trailer
2015 GMC 3500HD SRW
2016 Polaris 450HO
Offline SwampDonkey
  • Large Tooth
« Reply #183 on: June 04, 2019, 03:12:28 PM »
Day 1 on the garage build.
Move'n on.
Offline Peter Drouin
    • A&P Saw mill LLC
« Reply #184 on: June 04, 2019, 06:04:19 PM »
Looking good.  smiley_thumbsup
A&P saw Mill LLC.
License NH softwood grader.
Offline SwampDonkey
  • Large Tooth
« Reply #185 on: June 05, 2019, 05:30:59 PM »
Day 2 progress on the garage. Ready for the steel roofing. Windows and entry door hung. Started the siding.
Move'n on.
  • LIVE FREE OR DIE
« Reply #186 on: June 05, 2019, 08:49:28 PM »
Good crew, they aren't messin around!
Hakki Pilke 1x37
Kubota M6040
2015 GMC 3500HD SRW
2016 Polaris 450HO
Offline SwampDonkey
  • Large Tooth
« Reply #187 on: June 07, 2019, 12:20:05 PM »
Day 4. Roof and siding complete. Ready to pour the floor and wire the electrical. :)
Move'n on.
Offline thecfarm
« Reply #188 on: June 07, 2019, 02:25:27 PM »
Done!! Looks good.
Online WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
« Reply #189 on: June 07, 2019, 08:44:43 PM »
Still have the Rav4?
Offline SwampDonkey
  • Large Tooth
« Reply #190 on: June 08, 2019, 03:30:15 AM »
Nope Camry. Traded the Rav4 for the Tacoma in 2014. :)
Move'n on.
Offline SwampDonkey
  • Large Tooth
« Reply #191 on: June 14, 2019, 01:50:02 PM »
In preparation for the floor pouring I levelled out the gravel using mason line and steel pins on the corners. It was only roughed in and packed after the form was poured. I did strips 2 feet wide as I levelled the gravel. I only had 3 wheel barrow loads too much to remove. It will be packed again, but only at the back wall for 4 feet, the rest is packed good already. There will be a 2" slope from back to front. It will be 4" reinforced concrete which is poured out over the door holes in the wall.
Move'n on.
Building another Farm Table
Started by 123maxbars on General Woodworking
Last post November 19, 2016, 09:59:30 AM
by 123maxbars
Building a campsite on my tree farm
Started by bigtrees on General Board
Last post June 25, 2018, 11:50:55 AM
by WV Sawmiller
Building a home
Started by sticks on Timber Framing/Log construction
Last post December 21, 2005, 07:13:04 AM
by Max sawdust
building a new home
Started by hillbilly on Timber Framing/Log construction
Last post December 10, 2005, 04:49:35 PM
by hillbilly
