Author Topic: 48” 12 tooth blade  (Read 1154 times)
Offline SmartAlec
48” 12 tooth blade
« on: January 11, 2018, 03:54:38 PM »
Does anybody know what a 48” 12 tooth blade would be used for in northwestern Canada?
Offline Gearbox
Re: 48” 12 tooth blade
« Reply #1 on: January 11, 2018, 07:59:18 PM »
A very fast RPM saw . I'm just guessing .
Offline dgdrls
  • Learning the Art of Milling Logs, Lucas 8/27
« Reply #2 on: January 12, 2018, 07:34:41 AM »
low H.P.  Mill,
D
Offline SmartAlec
« Reply #3 on: January 12, 2018, 08:11:09 AM »
I was thinking the low horsepower as well, but that would be ridiculously slow and almost pointless wouldn’t it?
I guess you could saw bigger wood with less power
Offline Don P
    • Calculator Index
« Reply #4 on: January 12, 2018, 08:12:56 AM »
That could be it, I run 15 teeth of 30 on a 46" low hp setup, it would still cut circles around a band. Slow is relative. The swingblades run 5 teeth on a 24"
Offline DanG
« Reply #5 on: January 12, 2018, 08:34:42 AM »
Mobile Dimension runs 6 teeth on a 30" blade.
Offline SmartAlec
« Reply #6 on: January 13, 2018, 11:06:56 AM »
We run a 30 tooth 42” blade.  It cuts really well.  Dropping down to 12 teeth would be quite a difference. I’m not looking at putting that blade on our mill, but I thought a guy might use it for horse trading
Offline bandmiller2
« Reply #7 on: January 14, 2018, 08:24:17 AM »
In times past there were many saw builders and they would make saw to fit your operation. Today there are very few flavors when it comes to saws, you buy what they make or go without, and you consider yourself lucky to just find the proper bits and shanks. Most likely that disc with few bits was made for a lightly powered mill, today you would put on a larger engine. Perhaps it was for a water powered mill and that's all it would handle. Frank C.
Offline Al_Smith
« Reply #8 on: January 14, 2018, 08:52:15 AM »
All I've ever seen were big blades on small hardwood mills .However from pictures of giant bandsaws on the west coast the teeth were huge and large too for that matter .
I once came up back of a semi trailer full of big bands heading west on interstate 70 .Must have been 40-50 all coiled up .
Offline moodnacreek
  • Sawin by the notches
« Reply #9 on: January 14, 2018, 09:06:02 AM »
Payne will make just about any round saw imaginable.  Besides 2 mill saws , they did a 'peg' tooth cut off for my old slab wood saw.   The oldest saw in my collection is a 52" 4 1/2 style 30 tooth off a water powered saw mill some where in N.H. This 48" in question is certainly odd.
Offline SmartAlec
« Reply #10 on: January 14, 2018, 10:29:06 PM »
It could have been from a water mill or something. They aren’t even round. They have flats on the diameter between the teeth. I’ll see if I can get a picture
Offline SmartAlec
« Reply #11 on: January 14, 2018, 11:29:09 PM »
Circumference between the teeth
Offline PC-Urban-Sawyer
  • Been wasting time for sixty-eight years...
« Reply #12 on: January 15, 2018, 10:43:29 AM »
SmartAlec, you can fix a comment you wrote by clicking on the Modify link in the upper right hand corner of the comment window. I think you may have a limited time to do it but it works for me...
Herb
Offline Gearbox
« Reply #13 on: January 15, 2018, 08:18:22 PM »
It sounds like it is shaped like a MD only bigger . I wonder if it could be some kind of 3 saw mill for doing wider boards .
Offline SmartAlec
« Reply #14 on: January 16, 2018, 02:02:38 AM »
Thanks Herb.
Blade Tooth Set?
Started by Kirk_Allen on Sawmills and Milling
Last post March 09, 2004, 09:35:16 AM
by Kirk_Allen
Blade Tooth Setting
Started by EZ on Sawmills and Milling
Last post April 16, 2003, 05:59:08 AM
by ARKANSAWYER
Inserted tooth blade
Started by SCSawyer on Wanted
Last post August 01, 2007, 09:32:38 PM
by woody1
In need of an inserted tooth blade
Started by ahiggins1 on Wanted
Last post December 19, 2009, 01:13:26 AM
by ahiggins1
