Author Topic: Largest bar available for a Stihl MS661?  (Read 4998 times)
Offline randy_atx
  • Addicted to wood.
« on: January 12, 2018, 02:17:43 PM »
Greetings.  I currently have a 36" stihl bar for my 661 but I want to move up to at least a 48".  I can't locate a Stihl branded one that will work.  Can anyone point me to a lead?  Thanks
Stihl 661 CM with 36" bar, Alaskan MK III
Offline HolmenTree
Re: Largest bar available for a Stihl MS661?
« Reply #1 on: January 12, 2018, 10:57:43 PM »
Good luck finding a MS661/3003 Stihl mount bar over 36".
You have to go into the larger MS880/3002 mount 42" and beyond but they won't fit you 661.
Only option is a special order from Cannon with one of their Super Bars.
What are you cutting?
Offline randy_atx
  • Addicted to wood.
« Reply #2 on: January 12, 2018, 11:09:08 PM »
I've got some oak logs that are larger than what I can slab with by 36" bar and alaskan mill. I wanted to try and produce some wider slabs by upgrading the bar and customizing my current mill.
Offline YellowHammer
  • Always taking steps to save steps
    • Hobby Hardwood Alabama
« Reply #3 on: January 12, 2018, 11:27:51 PM »
I couldn't find a Stihl brand bar that size.  However, this one works petty well with a Stihl skip tooth chan.  52" long and fits my MS661 no probelm.  I use it to split big logs.
HobbyHardwoodAlabama.com
Offline DelawhereJoe
  • Trapped in Delawhere
« Reply #4 on: January 13, 2018, 12:27:58 AM »
Baileys online has a 42"  in .375 (3/8) oregon B&C combo for $140 + s&h or a 50" in .404 but currently out of stock on it.
Offline Al_Smith
« Reply #5 on: January 13, 2018, 05:12:14 AM »
FWIW I have an Oregon 42" .404 originally sized for an 066 Stihl  with the slot milled out now fitting an 084 Stihl .It's an older bar but I could get the numbers from the bar if you like .It was fairly cheap off of flea bay a few years back .Less than 50 bucks with a chain .
Offline randy_atx
  • Addicted to wood.
« Reply #6 on: January 13, 2018, 08:04:37 AM »
Thanks, YellowHammer.  The saw sitting on the shredder deck wasn't obvious to me at first.  That is a  nice looking setup.  Do you have the part number of the bar?  That would be helpful as this size bar would be ideal for what I am envisioning.
Joe, thanks for the Baileys info.  I may contact them to see if they know when the 50" would be off backorder.
Al, I wouldn't mind getting the numbers from you in case I need to go with that option.  Thanks!
« Reply #7 on: January 13, 2018, 08:53:34 AM »
I forgot to mention the chainsaw and bar was sitting in the mower deck from a day of splitting logs.
« Reply #8 on: January 13, 2018, 09:37:55 AM »
Last night I was unable to see the saw on the mower deck, but can definitely see it there this morning after getting sleep.
Offline 4x4American
  • Team red, white, blue and orange
    • Website Link
« Reply #9 on: January 13, 2018, 09:39:27 AM »
I tried to get one of them 3003 mount canon bars from baileys I think it was $350 but they were sold out or discontinued at the time
Boy, back in my day..
Offline HolmenTree
« Reply #10 on: January 13, 2018, 11:27:51 AM »
The last 3003 mount Stihl saw that could pull a 48"-50" chain with authority was the 056Mag2.
 It was discontinued over 25 years ago.
Those old bars are available on eBay sometimes.
Offline Jesper Jepsen
  • Owner of Mandoghus.dk
« Reply #11 on: January 13, 2018, 11:46:14 AM »
You don't want to mill oak with a 48" bar on a MS661 it hasn't the power needed, beyond 42" you are pretty much in double powerhead territory with a MS 661 and then you can go big. A MS 661 and MS 362 can get around 72" bar cutting  when running double head.
Offline HolmenTree
« Reply #12 on: January 13, 2018, 12:41:57 PM »
Well said Jesper, best advice posted.
Offline ZeroJunk
« Reply #13 on: January 13, 2018, 02:55:51 PM »
Curious how that works ?
Offline Al_Smith
« Reply #14 on: January 13, 2018, 03:48:24 PM »
I just looked on flea bay and there are a bunch of 42" Stihl mount bars for 066 size .I only found one used one in .404 size .There is a Canon too if you want to pay the tarrif .They are very  proud of those bars  but they say they are a very good .Then again in my case the bar would cost about twice as much as any saw I've ever bought .Tight wad ya know . ;D
Offline HolmenTree
« Reply #15 on: January 13, 2018, 04:18:19 PM »
You don't need matched powerheads milling on a double ended bar.
Me and my buddy ran a 066 and 044 on the same loop of chain milling lumber quite a few times.
They cut like crazy together even though both run different rpm at WOT by themselves. They even out real nice together.
Offline Dave Shepard
  • Geometrically proportional
    • My homepage
« Reply #16 on: January 13, 2018, 05:37:46 PM »
It's no different than Arnold Schwarzenegger and DannyDeVito on a tandem bike. Arnold might be doing most of the work, but the bike is going to go faster than if just one of them was on the bike.
Offline 4x4American
    • Website Link
« Reply #17 on: January 13, 2018, 05:59:13 PM »
Yup I have an 056 mag II, awesome saw still strong.
« Reply #18 on: January 13, 2018, 10:44:48 PM »
Doublehead milling
and this one shows and explain it.
« Reply #19 on: January 14, 2018, 08:51:43 AM »
I looked for a long time for a long bar for my saw, finally found it at a place called "The Little Red Barn" on the web.  The Forrester was half the price of the Cannons.  Most likely an inferior bar to the Cannon, but I don't have any complaints.   Up until then I was using a 32" and having to double cut to split big logs to bring them down to size for my sawmill.  Total pain in the rear.  I visited Customsawyer, where he used a 48" bar on a 66 to split an oak log for the Sycamore project to quarter saw.  Went pretty fast, and uneventful.  So I bought this 52" for the same purpose, and it works quite well.  One cut, done, uneventful and predictable. I don't use a bar this big for routine use, but for what I intended, it works great.
I wouldn't ever consider chainsaw milling entire logs with one, anyway.
If I go bigger, I may get a double ended bar, seems I'm running into more 50" to 60" diameter logs these days.  Jesper, that an informative video.
Mounting Cannon S2 (big Stihl) 42" bar on MS661 (small Stihl)
Started by neildorin on Chainsaws
Last post September 11, 2017, 06:01:44 AM
by Al_Smith
stihl ms661
Started by 630red on Chainsaws
Last post October 19, 2015, 07:23:55 AM
by HolmenTree
Stihl MS661
Started by sweetjetskier on Chainsaws
Last post November 10, 2013, 06:16:31 PM
by IndianSprings
Stihl MS261 - MS661 bar compatibility
Started by George Zarifis on Chainsaws
Last post October 20, 2015, 12:43:36 PM
by George Zarifis
